  3. Wanted Ads
  4. B series swap
B series swap
25 Posts 8 Posters 1.2k Views
    harwood39 wrote:
    a complete b18a swap is only $50 less than a b16 swap and no vtec. I no that an ls/vtec is an awsome swap.
    wtf?
    edit: b16 engine = 1k or so for motor
    b18a = $500 ....$50???????
    • harwood39H Offline
      harwood39H Offline
      harwood39
      complete swap prices, ecu, axles, tranny, mounts, harnesses, ect. are only $50 differant. go to hmotorsonline.com and look.
      btw, i would like to find a JDM motor due to the lower miles usually and the higher power and compression numbers.
      2730 5th Ave S. Unit C
      Fargo, ND 58103
      701-429-3686
        I don't know where you're going to find a b16 for a 1000 or a b18a for 500 to be completely honost. it's a hell of a deal if you do. you know what do what you want to do, cause you're just going to change your mind next week anyways.
          why does it matter if you get a jdm motor or not if you are just going to build it? i dont care what that site says...go find a junked, but good running LS integra for $500ish...it can be done, and there, you got most of what you need
            as i said...i dont know shit bout honda's really just general knowledge...those were gusses (however, did see a whole b18a setup for a CRX sell for like $650 on MNSC...somthin like that)
              You need to realize what you need to even do the swap to start off with.
              1. B16 swap for 92-95 civic requires hydro transmission. Minimum motor price around $2200 w/ trans. $2500 with LSD.
              2. Car does not require ANY aftermarket mounts.
              3. Car requires 94-up Integra axles.
              4. Car requires 94-up Integra shift linkages.
              And B16s fucking suck anyways.
                harwood39H Offline
                harwood39
                torbs, i agree with blake on this one (EXCEPT FOR THE FACT THAT I AM GOING TO CHANGE MY MIND), if you can find me a b16a2 or a b18b for that cheap, with everything need to do the swap, and it has only about 35,000 miles on it, let me know ASAP. Honestly you dont think im goint to buy a b-series, put it on an engine stand, and build it this year do you? if you do you are way off. I dont plan on doing internals for a while if i even do them. Plus you get a 100% start up garantee if you order one from a respected sight over getting a junked vehicle. Plus you dont know the tru condition of a junked motor, it could have a cracked block. now do you get where im coming from?
                Fargo, ND 58103
                701-429-3686
                  when i say junked, i mean totaled or cosmetically damaged...hell, you can buy a whole nice one for 2 grand...anywho, now that you have yet again changed your mind, turbo the fuckin d-series...AMEN
                    harwood39H Offline
                    harwood39
                    torbs, if you can find me a b-series that is in a junked car that i can get it out of let me know. I would do it, but i cant find any either. and i am NOT buying on off of ebay. Plus it has to be in great shape mechanical wise. I have found a couple that are just a longblock and need rebuilding. I dont want one of those.
                    Fargo, ND 58103
                    701-429-3686
                      Ah harwood I think your dreaming, time to wake up.
                      Like every one has said, your looking to spend around 2000 at minimum for a good b16.
                        turbo turbo turbo turbo (say like "toga" from animal house 😄 )
                          I have a B18B swap and everything you'll need to make it work in your car. PM me if you're ACTUALLY interested and actually HAVE MONEY.
