  3. Wanted Ads
  4. Dual 12 inch sub box wanted
23 Posts 5 Posters 1.3k Views
    if you listen to a lot of rap thats the only way id say to get a ported box...if you listen to a lot of fast hittin shit like rock etc get a sealed...
      Yup, I've used both. Had a ported enclosure for 4 years. I've had a sealed box since December and found that I prefer ported enclosures.
        the box is 14in deep X 38in. wide X 18in tall.
        the ports are 12in. deep x 4in wide.
          would you want it?>
            mwc1 wrote:
            would you want it?>
            I'm gonna rip out my box tonight to measure the trunk. I think 38 inches will be too wide though. The box I have now is about 32-34 inches wide at barely fits.
              well put it in the back seat!
                and what kinda subs are you using?
                  great idea...I'll strap the kid's car seat to the top of the box :rolleyes:
                    haha....kid will get a free massage then!
                      He already does 😄
                      JL 12w0's
                        haha well i think he's old enough to sit in the front seat......you should check the specs on them subs for the right size of ported box...if its to big for them...they wont sound to good.....you can always cut off some of the port to tune it.
                          HandoEX wrote:
                          Ported Enclosure Range: 1.75-2.75 cu.ft. (49.5-78.0 liters)
                          ^copied from sub mfgrs web-site.
                          If my measurements are correct a box that is 14 inches x 18 inches x 38 inches (externally) is 4.925 cubic feet. this is the volume of the outside of the box, not including the thickness of the mdf. So, at a guess, the internal volume of the box is 4.5....Divide that by 2(2 subs)=2.25 internal cubic feet per sub....right in the recommended range for ported box using the subs I have.
                            well perfect then! - im glad your good at math! haha
                              you also have to remember the displacement of the subs and the ports...subtract that from the overall volume...and if its 3/4'' MDF subtract that from all the sides and from the divider that will go in the center as well...
