  3. Track Talk
  4. Racing on memorial day.....
127 Posts 40 Posters 15.6k Views
  • homerH
    homerH
    homer
    Hey Homer, when I saw that you didn't burn out past the tree I said to myself (he's gonna spin out of the hole) How bad did you spin/how far off was your 60' from when you would normally hook on a clean track? Even doing the burnout and backing onto my clean strips my car was still spinning just slightly on the launch. If I didn't do the long burnout it would spin terribly.
    Dave:
    I don't have enough talent to do a drive by burnout, and it is illegal to cross the starting line while doing burnout in the NHRA classes I run. :rolleyes:
    I didn't spin on the lauch, first 2 passes were pretty mild, changed set up on the 3rd I ran at approx 7:45PM.
    Last pass I had a 1.18 60ft, and ran 5.83 @ 129mph at 1/8 mile, but could not get car to pull with power past 1/8 mile, so only ran 9.78 @ 140mph and it should have ran in the 9.30's closer to 155mph with how it was set up to run.
    Biggest reason (other than getting handle on tune-up) was to feel personally how much the track would take after 6hrs of street cars. I got my answer. 😕
    "Will Work for Food"
    • DaveHD
      DaveHD
      I guess I need to get rid of the independant rear suspension (and about 1000lb). After the first hour my car spun badly when I didn't burnout to clean the starting line (1.68 60'). After I did the long burnouts I ran 1.503, 1.508, etc. Dennis said my car was still spinning slightly, altho I really couldn't feel it (look forward to watching the video).
      Why was the car not pulling on top end? What does the white car weigh?
      homer wrote:
      Dave:
      • homerH
        homerH
        homer
        Car weighs 2724 with me in it.
        I wish I knew, was going into high gear about 800 rpms less than normal, (7000 instead of 7800), and had it set up soft, but should have pulled harder instead it nosed over about 800ft.
        Alcohol tuning is kicking our a$$ as well as problem with valve train geometry.
        , but good news is we have 48hrs to figure it out before the points meet at BIR Friday.
          It was nice to see everyone at teh track.
          Next time I will be driving my POS down the 1320 hopefully with a FMIC.:)
          • camzaro28C
            camzaro28C
            camzaro28
            i was wondering if anyone else was having with traction. after 3 passes i dropped the air pressure down from 32 to 22 and went from mid 1.9 60' to 2.2-3 60 fts. so i wasnt sure if it was that or if the track was gettin worn.
            couldnt muster better then 13.3 on the 2nd pass. rest were 13.4's with 2.0 and a bunch of 13.6's. car kept deciding to start in 2nd gear. even with that it was still spinning.
            next time out i'll be shootin for 11's but yall know how that goes :rolleyes:
            the white foxbody at the the end ran pretty good and so did ur car dave. that tranny of urs shifts nice. powerglide?
            jig 4 prez
              What was the DA?
              • DaveHD
                DaveHD
                Yeah, on street legal days the track slowly gets worse as more dirt gets on the track, and as the traction compound gets torn off. It didn't seem to affect Homers race car tho, but being lightweight, having the suspension/chassis setup and a healthy sized slick is probably why.
                Yes, I run a powerglide.
                • My NOvaM
                  My NOvaM
                  My NOva
                  hey dave what was it that u were asking about my powerglide? didnt fallguy want it? or something
                  Hey Tina come get some hamm
                  • DaveHD
                    DaveHD
                    You snooze you lose. He fixed my old TH350 instead. 😛
                    • PhatsP
                      PhatsP
                      Phats
                      92BlackTT wrote:
                      ^impossible on a stock sti...that is if we both talking about the same sti.
                      No not stock..........intake, turbo xs fuel mangement.......the map he was running was at 16 psi......soo, it shoulda been faster than that. Sure it's just 2 parts. but you know how that goes.
                      It was the black one with the charge speed front end, I believe.
                      02 GSXR-1000
                      97 540i
                      • 24valvenotak2
                        24valvenotak2
                        oh, Im thinking of a different black one.
                        63vette;288530 wrote:
                        • 2wheeler2
                          2wheeler2
                          2wheeler
                          ok, let's see
                          '02 GSXR 1000: 9.53 (motor)
                          '04 GSXR 750: 10.45 (stock, lowered, custom "no seat" mod)
                          '03 CBR 954 RR: 10.66
                          '97? GSXR 600: 11.7something
                          '08 Suzuki Hayabusa
                          '09 Yamaha Zuma 200cc
                          '95 E-350 7.5L
                          • homerH
                            homerH
                            homer
                            I had the small tires on it (29.5x10.5x15), actually thought the starting line was better Monday night than on Sat/Sun, since track temp was finally decent and there was less humidity in the air & I increased air pressure 1 lb to 8.5 lbs, since had too much wrinkle and was folding tires over when launching.
                            The LC6 held up nicely and track actually has too much rubber on it right now & needs to be scrapped. Alot of sand/dirt was on track from cars parking in the dirt/mud than making runs, but that was the fun part for me, seeing if we could stay in the groove & drive through it, (First pass obviously I didn't and peddled it a couple of times to drive back into it) & the groove was tight and their wasn't much room for error.
                            **First ** pass was a 10.21 @ 133.47, 2nd pass I didn't get a correct time but with Data Logger info and short times was a high nine leaving soft probobly at the same MPH. 3rd pass was decent up to 660' (9.78 @ 140mph) but car nosed over after that and we just missed the tune and are running too lean with the alcohol with 172 jets & I don't think the 4:88 gears are helping like we thought.
                            Didn't change suspension, just tire pressure, since only have ladder bar/coil over system and only changes to shock settings and spring rate that I can make will only help on rough tracks.
                            Hopefully we get it figured out since car is now slower than it was $7K ago & I am still slower than 2Wheeler :mad:
                            PS:
                            Bad93ex Says: What was the DA?
                            May 30, 2005
                            07:47:40 PM
                            2356 DA
                            71.7 Degrees F
                            45.8% Humidity
                            57.5 Degrees F Dp
                            0.47 Vp
                            0.925 ADR
                            • STiSchuckyS
                              STiSchuckyS
                              hmm. i have a boost controller set at 16 psi, headers and turbo back exhaust...maybe once he gets those, he'll be up there with me in the low low 13s.
                              • XJHEADX
                                XJHEADX
                                So the car weighs about 2374 then right??
                                • homerH
                                  homerH
                                  homer
                                  Ditto.......and 2/10ths quicker with a skinny driver :eek:
                                  • XJHEADX
                                    XJHEADX
                                    lol
                                    • camzaro28C
                                      camzaro28C
                                      camzaro28
                                      yeah i checked the DA around 11am and it was around 1800 and climbing.
                                      fargo what happend to ur car? guess it wasnt anything bad
                                      jig 4 prez
                                      • P
                                        P
                                        pin
                                        Total newbie to slicks here, but I got fed up when I spun on the 1-2 shift on one my last pass. This is on a Probe that is likely still putting down less than 180 ft-lb torque to the wheels on a dyno(if that matters).
                                        Barry
                                        • PSiedTSiP
                                          PSiedTSiP
                                          were you running slicks?
                                          spanish-rice;237125 wrote:
