  3. Track Talk
  4. Racing on memorial day.....
127 Posts 40 Posters 15.6k Views
    What was the DA?
    • DaveHD
      DaveHD
      Yeah, on street legal days the track slowly gets worse as more dirt gets on the track, and as the traction compound gets torn off. It didn't seem to affect Homers race car tho, but being lightweight, having the suspension/chassis setup and a healthy sized slick is probably why.
      Yes, I run a powerglide.
      • My NOvaM
        My NOvaM
        My NOva
        hey dave what was it that u were asking about my powerglide? didnt fallguy want it? or something
        Hey Tina come get some hamm
        • DaveHD
          DaveHD
          You snooze you lose. He fixed my old TH350 instead. 😛
          • PhatsP
            PhatsP
            Phats
            92BlackTT wrote:
            ^impossible on a stock sti...that is if we both talking about the same sti.
            No not stock..........intake, turbo xs fuel mangement.......the map he was running was at 16 psi......soo, it shoulda been faster than that. Sure it's just 2 parts. but you know how that goes.
            It was the black one with the charge speed front end, I believe.
            02 GSXR-1000
            97 540i
            • 24valvenotak2
              24valvenotak2
              oh, Im thinking of a different black one.
              63vette;288530 wrote:
              • 2wheeler2
                2wheeler2
                2wheeler
                ok, let's see
                '02 GSXR 1000: 9.53 (motor)
                '04 GSXR 750: 10.45 (stock, lowered, custom "no seat" mod)
                '03 CBR 954 RR: 10.66
                '97? GSXR 600: 11.7something
                '08 Suzuki Hayabusa
                '09 Yamaha Zuma 200cc
                '95 E-350 7.5L
                • homerH
                  homerH
                  homer
                  I had the small tires on it (29.5x10.5x15), actually thought the starting line was better Monday night than on Sat/Sun, since track temp was finally decent and there was less humidity in the air & I increased air pressure 1 lb to 8.5 lbs, since had too much wrinkle and was folding tires over when launching.
                  The LC6 held up nicely and track actually has too much rubber on it right now & needs to be scrapped. Alot of sand/dirt was on track from cars parking in the dirt/mud than making runs, but that was the fun part for me, seeing if we could stay in the groove & drive through it, (First pass obviously I didn't and peddled it a couple of times to drive back into it) & the groove was tight and their wasn't much room for error.
                  **First ** pass was a 10.21 @ 133.47, 2nd pass I didn't get a correct time but with Data Logger info and short times was a high nine leaving soft probobly at the same MPH. 3rd pass was decent up to 660' (9.78 @ 140mph) but car nosed over after that and we just missed the tune and are running too lean with the alcohol with 172 jets & I don't think the 4:88 gears are helping like we thought.
                  Didn't change suspension, just tire pressure, since only have ladder bar/coil over system and only changes to shock settings and spring rate that I can make will only help on rough tracks.
                  Hopefully we get it figured out since car is now slower than it was $7K ago & I am still slower than 2Wheeler :mad:
                  PS:
                  Bad93ex Says: What was the DA?
                  May 30, 2005
                  07:47:40 PM
                  2356 DA
                  71.7 Degrees F
                  45.8% Humidity
                  57.5 Degrees F Dp
                  0.47 Vp
                  0.925 ADR
                  "Will Work for Food"
                  • STiSchuckyS
                    STiSchuckyS
                    hmm. i have a boost controller set at 16 psi, headers and turbo back exhaust...maybe once he gets those, he'll be up there with me in the low low 13s.
                    • XJHEADX
                      XJHEADX
                      homer wrote:
                      Car weighs 2724 with me in it.
                      So the car weighs about 2374 then right??
                      • homerH
                        homerH
                        homer
                        Ditto.......and 2/10ths quicker with a skinny driver :eek:
                        • XJHEADX
                          XJHEADX
                          lol
                          • camzaro28C
                            camzaro28C
                            camzaro28
                            yeah i checked the DA around 11am and it was around 1800 and climbing.
                            fargo what happend to ur car? guess it wasnt anything bad
                            jig 4 prez
                            • P
                              P
                              pin
                              Total newbie to slicks here, but I got fed up when I spun on the 1-2 shift on one my last pass. This is on a Probe that is likely still putting down less than 180 ft-lb torque to the wheels on a dyno(if that matters).
                              Barry
                              • PSiedTSiP
                                PSiedTSiP
                                were you running slicks?
                                spanish-rice;237125 wrote:
                                • B
                                  B
                                  So the best I was able to muster out of the GSX this weekend was a 15.1. Anytime I tried to launch hard the clutch would spin. So I had to launch at like 2500-3000 rpms. Consequently my BEST 60' of the day was a 2.27, and that was my 15.1@92. With a different clutch I should be able to easily shave off .5-1.0, but I don't think we'll ever know.
                                  • wesholeW
                                    wesholeW
                                    Blake, I FEEL YOUR PAIN! I'm not going to say anymore. those that were there know what I'm talking about.
                                    • DaveHD
                                      DaveHD
                                      heh, well I guess 29.5x10.5 is small compared to what some people run. 😛 I can't get anything bigger than a 28 under my wheel well.
                                      The track was sticky at first, but it deteriorated quite badly. You car would prob lift the wheels and hook on a gravel road. LOL I know my car would just spin, and Ethan said that he lost all hope of launching his bike well after a hour or two. What is your weight bias front/rear? I noticed that you had ladder bars on there, why not 4-link? (obviously the ladder bar works I guess). The odd thing is that my car had no traction issues other than right on the starting line. I saw that you got loose in the middle on the one pass, my car just drove down the track with no issues. I wasnt spraying so my 1/8 mile mph was only 103-105.
                                      **First **pass was a 10.21 @ 133.47, 2nd pass I didn't get a correct time but with Data Logger info and short times was a high nine leaving soft probobly at the same MPH. 3rd pass was decent up to 660' (9.78 @ 140mph) but car nosed over after that and we just missed the tune and are running too lean with the alcohol with 172 jets & I don't think the 4:88 gears are helping like we thought.
                                      PS:
                                      May 30, 2005
                                      07:47:40 PM
                                      2356 DA
                                      **71.7 Degrees F **
                                      45.8% Humidity
                                      57.5 Degrees F Dp
                                      0.47 Vp
                                      0.925 ADR
                                      • P
                                        P
                                        pin
                                        Yes, hence the mention of slicks in my post.
                                        Barry
                                        • PSiedTSiP
                                          PSiedTSiP
                                          oh i didnt even realize that at the track...i assumed that by your post but i wasnt sure...
