  4. Clutch Chatter
Clutch Chatter
24 Posts 10 Posters 812 Views
  • harwood39H Offline
    harwood39H Offline
    harwood39
    i take it i cant drive it in the condition that its in? i mean its just chattering
    2730 5th Ave S. Unit C
    Fargo, ND 58103
    701-429-3686
      what caused it...look at the odometer.....
        harwood39H Offline
        harwood39
        true, 122k
        Fargo, ND 58103
        701-429-3686
          I had one that made that noise. I broke the pressure plate into two pieces.
            harwood39H Offline
            harwood39
            ^^^wow
            i dont think its my pressure plate thats broken, i think its a worn bearing. But i could be wrong.
            Fargo, ND 58103
            701-429-3686
              It also could be one of the cv axles. The inner joint can do the same thing after some reptative hard lanches.
              • hondaking424H Offline
                hondaking424
                could be from all the fast shifting u do if your aways racing
                  harwood39H Offline
                  harwood39
                  This is ecactly what it is, checked it out today. Its the inner CV joint. Time to buy new axles. Now i just need to find some aftermarket ones, stock ones SUCK.
                  Fargo, ND 58103
                  701-429-3686
                    usually cv joints just make a clicking noise...well my monte carlo just made clicking noises anywaysa.
                      That's if it's the outer joints. I was refering to the inner ones. They wont click on you very often but they will cause all sorts of other problems when the get bad and bind up on you as is the caes here I believe.
                        What would you know about stock axles sucking?
                        I make 540 whp on stock axles and have raced on the same pair for 3 years. Tufte races on stock axles making 260 whp and hasn't broke one yet either.
                        Don't blame the stock part.
                          harwood39H Offline
                          harwood39
                          Ya, i need to get them by the 18th so i can have fun on the track day, dont want to be running on bad cv joints.
                          Fargo, ND 58103
                          701-429-3686
                            harwood39H Offline
                            harwood39
                            so should i run remanufactured ones(limited lifetime warranty)--$60, new ones(LLT)--$80, or Performance ones(3-month)--$200? All prices are for one side only
                            Fargo, ND 58103
                            701-429-3686
                              Remans. You make 12 whp.
                                lol ^
                                  get the cheapest ones........
                                  • F Offline
                                    F Offline
                                    fanaticrockford
                                    Check out http://raxles.com/
                                    I have heard only good things about them.
                                      Just go to your local arts store and buy a pair of Axles and put them in and call it good. If you fuck them up, then your doing something wrong. And they will be warrantied if you do.
                                        Talk to Tufte, he can hook you up with some nice remanned axles from Advance Auto Parts. They should have a decent warranty too.
                                          harwood39H Offline
                                          harwood39
                                          i looked at the axles at advanced auto parts, and i think i am going with those, limited lifetime warranty and everything, the are a little more than the auto zone ones by about $50
                                          I know raxles makes good products, but they are so expensive compared to autozone or advanced auto parts
                                          Fargo, ND 58103
                                          701-429-3686
