  4. Clutch Chatter
Clutch Chatter
24 Posts 10 Posters 1.0k Views
    I had one that made that noise. I broke the pressure plate into two pieces.
    • harwood39H Offline
      harwood39H Offline
      harwood39
      ^^^wow
      i dont think its my pressure plate thats broken, i think its a worn bearing. But i could be wrong.
      2730 5th Ave S. Unit C
      Fargo, ND 58103
      701-429-3686
        It also could be one of the cv axles. The inner joint can do the same thing after some reptative hard lanches.
        • hondaking424H Offline
          hondaking424
          could be from all the fast shifting u do if your aways racing
            harwood39H Offline
            harwood39
            This is ecactly what it is, checked it out today. Its the inner CV joint. Time to buy new axles. Now i just need to find some aftermarket ones, stock ones SUCK.
            Fargo, ND 58103
            701-429-3686
              usually cv joints just make a clicking noise...well my monte carlo just made clicking noises anywaysa.
                That's if it's the outer joints. I was refering to the inner ones. They wont click on you very often but they will cause all sorts of other problems when the get bad and bind up on you as is the caes here I believe.
                  What would you know about stock axles sucking?
                  I make 540 whp on stock axles and have raced on the same pair for 3 years. Tufte races on stock axles making 260 whp and hasn't broke one yet either.
                  Don't blame the stock part.
                    harwood39H Offline
                    harwood39
                    Ya, i need to get them by the 18th so i can have fun on the track day, dont want to be running on bad cv joints.
                    Fargo, ND 58103
                    701-429-3686
                      harwood39H Offline
                      harwood39
                      so should i run remanufactured ones(limited lifetime warranty)--$60, new ones(LLT)--$80, or Performance ones(3-month)--$200? All prices are for one side only
                      Fargo, ND 58103
                      701-429-3686
                        Remans. You make 12 whp.
                          lol ^
                            get the cheapest ones........
                            • F Offline
                              F Offline
                              fanaticrockford
                              Check out http://raxles.com/
                              I have heard only good things about them.
                                Just go to your local arts store and buy a pair of Axles and put them in and call it good. If you fuck them up, then your doing something wrong. And they will be warrantied if you do.
                                  Talk to Tufte, he can hook you up with some nice remanned axles from Advance Auto Parts. They should have a decent warranty too.
                                    harwood39H Offline
                                    harwood39
                                    i looked at the axles at advanced auto parts, and i think i am going with those, limited lifetime warranty and everything, the are a little more than the auto zone ones by about $50
                                    I know raxles makes good products, but they are so expensive compared to autozone or advanced auto parts
                                    Fargo, ND 58103
                                    701-429-3686
