  4. 1992 accord w/JDM H22A For Sale
15 Posts 11 Posters 1.6k Views
    oomgloff2
    Im selling a 92 Accord that i put a 94 JDM H22A+the H22 transmission. $2,950.
    Motor: JDM 1994 DOHC VTEC H22A, from a JDM Prelude with aprx 30,000mi on motor and tranny. Rated at 200 HP @ 6800rpm. Motor is stock except for the H23 Manual timing belt tesioner i put in with a new timing and balancer belt.
    ECU: stock P13 with a chip that removes speed limiter, and has 9000rpm rev limiter.
    Car has 176,000 on it
    Good tires, good front brakes, brand new rear brakes, hella fog lamps, new cd player.
    name is Jared 701-729-6338
    pics of it. http://www.geocities.com/oomgloff2/DSCF0029.JPG
    http://www.geocities.com/oomgloff2/DSCF0033.JPG
    http://www.geocities.com/oomgloff2/DSCF0034.JPG
    http://www.geocities.com/oomgloff2/accordpipes3.JPG
    http://www.geocities.com/oomgloff2/h22inaccord3.JPG
    If cars weren't my hobbie I'd be rich.
    • darkelvisD Offline
      darkelvisD Offline
      darkelvis
      auto or manual? I'll give you $500. 3 grand is outrageous.
        slowvo
        if it werent for the body work....
        ide like it alot
          Wasnt this car at the track last week?
            darkelvis you don't know what the fuck your talking about. that motor alone probably cost more than that.
              didnt this car only make 154 to the wheels?
                200 at the crank 154 to the wheels isnt bad at all....
                  H22 swaps are cheap, so no, the motor didn't cost more than that.
                  If you were revving that h series to 9000 rpm I wouldn't touch that motor at all.
                  Revving H series motors past 8000 rpm is pretty iffy.
                    not really on a fwd 5spd...it should be in the 170s or 180s...it should be around 10% drivetrain loss prolly...and arent the jdm h22s around like 210-220?
                      darkelvisD Offline
                      darkelvis
                      Like Nick said, H swaps are cheap. Plus if that motor is being revved to 9K then it is going to shit out pretty soon. Since it is a MaD TyTe JDM SwAp Yo the engine probably DOESN'T really have on it what they say it does, they may say 30K but most JDM engines that come over to the states with "30K" are generally around 90-100K truthfully (do some fucking homework and you'll know what I'm talking about). Also, it may be 154 WHP which lots of people think "hey that's pretty impressive for a honda" which is true, BUT IT IS STILL ONLY 154 HORSEPOWER, which in reality is nothing. Plus the car is UGLY as hell and the body work to get it back to stock will probably cost more than the 3 grand this guy is asking. So, like I said before, I'll give you $500.
                      • FlowcusF Offline
                        FlowcusF Offline
                        Flowcus
                        Hmmm im 170 at the crank and 148 at the wheels.... i thought that was bad. ( based off someone elses dyno. )
                        I ride random bitches.
                          If only you knew how much drivetrain loss subaru had.....
                            auto cough auto 😉
                              torbs wrote:
                              auto cough auto 😉
                              ummm....I'd be willing to bet my auto has LESS drivetrain loss than most manual wrx's out there. And just for the sake of argument, I was refering to the 5spd when I made the original comment.
                                oomgloff2
                                Yeah the body isnt great but the paint was worse before the flat black and flames. I dont shift anywhere near 9 i rev to 7.5 at the most the tach goes to 8. i bought the chip to raise the 113 mph speed limiter.
                                I got 154 on that traveling dyno but that thing aint accurate, dynos all read different and he couldnt even keep this 133 mhz shitty laptop from restarting and his printer didnt work. here are more accurate h22 dyno runs http://honda-tech.com/zerothread?id=691830
                                Plus the motor and trany look like they dont have much more then 30 k on them, ive worked on alot of vehicles and motors with nearly 100k are usually dirtier, and have more visible wear, i was suprised on how clean this motor and tranny was when i got it.
                                JDM h22 motor and trannys go for 2 grand. which makes the car worth 950 in this case which is a deal. especially if you were to see what thos old accords are sellin for.
                                Yeah its a 5 speed non-LSD, it has closer gear ratios then USDM accord and prelude trannys.
                                I have a Gtech Pro RR and it measured the performance at 6.8 to 60 and 15.4 in the quarter mile, at interstate dragways i got 15.6 in the quarter but i dont have my reaction time down very well.
