  4. F1 engine test
F1 engine test
12 Posts 9 Posters 2.4k Views
  • XJHEADX
    XJHEADX
    All I can say is "WOW"
    Link
    • 91nbtsi9
      91nbtsi9
      I think I have seen that before, that is awesome. Sounds a little rev happy:)
      • slow90gsxS
        slow90gsxS
        slow90gsx
        if that dosent put a smile on your face there is something wrong!
        • 94NDTA9
          94NDTA9
          Freakin awesome. So much technology. Inconel headers are sexy as hell.
          Here is another video you might like
          RIGHT CLICK SAVE AS!
          • PSiedTSiP
            PSiedTSiP
            that was sweet
            spanish-rice;237125 wrote:
            • legacy-user-33L
              legacy-user-33L
              legacy-user-33
              If you have the big bucks, you can buy used Ferrari parts from Michael and Rubin's car at Ferrari's f1 website.
              -Tin-
              -IS300-Black on Gold-
              • stephen bradleyS
                stephen bradleyS
                stephen bradley
                I will take two of them 🙂
                • Unknown
                • Sweet-WRX-LovinS
                  Sweet-WRX-LovinS
                  Sweet-WRX-Lovin
                  ///\ What he said ///\
                  One time...
                  • S
                    S
                    Schwanger
                    This isn't an F1 it's a Formula SAE car. It uses an I4 motorcycle engine. I think this car used a Honda F4i motor.
                    • stephen bradleyS
                      stephen bradleyS
                      stephen bradley
                      Old motor 03 but you get the idea.
                      Output of the BMW P83 is over 900 bhp.
                      • Maximum engine speed is 19,200 rpm.
                      • In a race, engine speed is limited to 19,000 rpm.
                      • Idle speed is 4,000 rpm.
                      • The engine weighs less than 90 kilograms.
                      • It completes a distance of 500 kilometres before undergoing revision.
                        Total production of the BMW P83 is 200 units, ten of which the team takes
                        to each race.
                      • Before being phased out the engine will have received 1,388 upgrade
                        modifications.
                      • It comprises around 5,000 individual components, 1,000 of them different.
                        The air intake volume is 1,995 cubic metres per hour.
                      • Maximum piston acceleration is 10,000g.
                      • Piston speed peaks at 40 metres per second and averages 25 metres per
                        second.
                      • Exhaust temperatures of up to 950 degrees are reached.
                      • Maximum air temperature in the pneumatic system is 250 degrees.
                      • The ultra-high-speed 130R turn at Suzuka with its lateral load of 4g poses
                        the greatest challenge to the oil system.
                      • The BMW P83 endured the highest full-throttle proportion on the Monza
                        circuit at 73 per cent per lap.
                      • At the Monaco Grand Prix, the transmission and engine have to withstand
                        an average 3,100 gear changes.
                      • The engine block and cylinder head are made of cast aluminium and are
                        manufactured at the BMW Formula One foundry in Landshut using a
                        special thin-wall casting method.
                      • BMW Munich handles, among other things the manufacture of the
                        crankshaft (steel), camshaft (case-hardened steel) and camshaft covers, as
                        well as processing of the cylinder head and crankcase. The oil system and
                        engine electronics also stem from BMW Munich
                      • Unknown
                      • 91nbtsi9
                        91nbtsi9
                        First F4i engine I have seen using two headers with that big of collectors... I think you might be incorrect, take another look.
                        • PSiedTSiP
                          PSiedTSiP
                          shit dsms can rev that high too...a guy at devils run seems to think its a common thing to rev into 5 digits with a dsm that has a backseat full of "nitro"
