  3. Run Your Mouth
  4. blown motor.
blown motor.
28 Posts 13 Posters 3.0k Views
    why do you say you blew your motor if you don't know what happened.... what are the symptoms. what exactly went down.
      well i was driving down uni and my car started to die for no reason, so i tried to start it again and it did the same thing. so i pulled over and the car sounded like it overheated, but it didn't so i tryed to start it again and it died right away. and a friend of mine said it sounded like it had seized>
        well find out.... stick a ratchet on the cranky pulley, and see if it'll turn....
          i think i will try that when i get the car to my house
          • harwood39H Offline
            harwood39H Offline
            harwood39
            it could also have been some valve train shit that went bad. That happened on my Z. I was cruisin by best buy, and all the sudden it died, but there was metal on metal grinding too. I pull over, open the hood, and the main seal/bearing had also failed and the crank dropped. lots of smoke from oil getting on hot stuff.
            2730 5th Ave S. Unit C
            Fargo, ND 58103
            701-429-3686
            • stephen bradleyS Offline
              stephen bradley
              that sucks man, but you need to hope for the best until you find out otherwise.
              • Unknown
                that's true, but other then that i can get a new motor now
                  sounds like you blew a seal or somethign....is there oil everywhere???.......probably seizing.
                    no oil everywhere, idk what's wrong with it!!!!!!
                      Sorry but these motors just don't blow themselves up. Honda makes some of the most reliable motors out there, and there's a very slim chance that it just took a shit for no reason. Was it full of oil? What did you do prior to it dieing and shit?
                        Nice luck you had! Had to happen when you go t your license back.......
                          I Get Dibs On The Blown One Freitag!!! 😄
                            it had oil in it, and there was a lifter or two that was loose, so i'm not too sure what it was.
                              i'm going to look at two motors on monday and i will be buying one!!!
                              • cavalier_babeC Offline
                                cavalier_babe
                                [QUOTE=treimche]Sorry but these motors just don't blow themselves up. Honda makes some of the most reliable motors out there, and there's a very slim chance that it just took a shit for no reason. QUOTE]
                                ya gotta remember... it's frietag! haha.. haven't you blown like.. 4 motors now?? gotta stop doin that Free!!!!
                                  to late i already asked long time ago..
                                  so fretag u going to let me have it
                                    idk what i'm doing with it yet
                                      try 3 motors and many transmissions!
                                      • M Offline
                                        M Offline
                                        mym6
                                        Sounds like you need to change how you drive or check your oil more 😛
                                          i couldn't agree with you more!!!
