  4. 240SX Problems
240SX Problems
69 Posts 13 Posters 3.7k Views
  • S
    S
    SleeperMx6
    gonna be at the dome tomorrow, I wanna see this thing...
    • K
      K
      second that one
      • PSiedTSiP
        PSiedTSiP
        its kinda ghetto-ish right now...im not sure im gonna bring it out right away...i wanna get it running good right away
        spanish-rice;237125 wrote:
        • S
          S
          SleeperMx6
          order those gaskets tonight. get it done on monday.
          • McAdamM
            McAdamM
            McAdam
            yup, you can get a turbo flange gasket for anything with a T25, which should mean anything with even a T2 series. 1985 to 1988 200sx turbos came with T2's on them. maybe they might stock a gasket for that. otherwise, 300ZXTT's, 1988 to 1989 30ZXT's and 2nd gen eclipses should be T2 series turbos.
            on the timing, just adjust the CAS I beleive.
            the brakes, I think there is a special procedure for bleeding ABS systems, look around online for that. I THINK you just have to unplug the ABS module and bleed it like that, not sure tho.
            Id be interested in seeing your car somethime soon see what kind of a job they did on it. I have seen MANY SR20DET swapped 240sx';s, both S13 and S14's.
            McAdam
            • T
              T
              thezachattack240
              For all your 240 questions, hit up zilvia.net, freshalloy.com, or 240sx.org. Those forums are excellent sources of information. I think on zilvia they have a sr20det faq in the tech talk section. Heavythrottle.com has some good information too as well as tons of parts.
              My cardomain site
              • PSiedTSiP
                PSiedTSiP
                yeah im a member at zilvia...it looked like the best place to go for help...they seem to help a lot
                yeah id love to have you come take a look at my car to see how it was done...good or bad...itd be interesting to see...from what i can see it looks good but what do i know about em?
                • T
                  T
                  thezachattack240
                  I could do that sometime. Where did you get it from?
                  My cardomain site
                  • PSiedTSiP
                    PSiedTSiP
                    i bought it from NY
                    • T
                      T
                      thezachattack240
                      ic...well send me a pm and see if we can arrange something.
                      My cardomain site
                      • PSiedTSiP
                        PSiedTSiP
                        ok i found a gasket in town...(unless someone has a T25 flange gasket laying around they dont need)...does someone wanna put it in for me? i am feeling pretty lazy...GSR where you at...?
                        • 24valvenotak2
                          24valvenotak2
                          ^ Sally! ^
                          63vette;288530 wrote:
                          • PhatsP
                            PhatsP
                            Phats
                            i'm sorry i should pay more attention to this forum....yeah we just swapped a sr into a 89 fastback, and one of the guys has a red top in a 92 coupe and the silvia front end
                            if you still need it i'll be back in town today, i'll check back b-4 i head down, i've got the sr service manual, so that'll help us with the timimg.
                            02 GSXR-1000
                            97 540i
                            • PSiedTSiP
                              PSiedTSiP
                              its at SLS right now actually...you can stop there and take a look if you please
                              • PhatsP
                                PhatsP
                                Phats
                                oh, well i'm sure it's in good hands either way, just trying to ehelp, i may go check it out, but it looks llike i'll get there kinda late.
                                02 GSXR-1000
                                97 540i
                                • PSiedTSiP
                                  PSiedTSiP
                                  ok update..
                                  Gasket is fixed and it actually sounds normal...a regular DSM T25 gasket wouldnt work but got a 300zx gasket...
                                  I just timed the motor, put new plugs in it(might be one range too hot?), and installed a walbro 255lph HP pump(yeah i dont like S14s anymore)...
                                  when I go WOT it stutters at around 5k...it sounds like its popping and shit...no knock or anything...I also just noticed today that when I am at WOT it only says 69-70% on the AFC...i checked out the injectors to make sure they were still all good...it has the Z32 maf and stock unchipped ECU...i know thats a problem but it still should be good once i get above 2k or so...help me out...
                                  • PhatsP
                                    PhatsP
                                    Phats
                                    Make sure that that maf, is wired right, same wioth the afc, the obvious would be to say tps, but ........yeah
                                    02 GSXR-1000
                                    97 540i
                                    • PSiedTSiP
                                      PSiedTSiP
                                      well i just took it out again after double checking the timing and it pulled a shitload better but it still liked to pop at 6500 in any gear...i think im gonna look at the timing again just to make sure its exact...this time i did see 75% from the TPS so idk...
                                      • PhatsP
                                        PhatsP
                                        Phats
                                        Oh... if you think your TPS is messed. Just unplug it and drive the car will run fine, but a bit richer if the problem is the same. could very much so be the TPS.
                                        If you unplug the TPS and you get a rough/worse idle and a bit more hesitation all round or a tiny lack of power all round then the TPS is not the problem
                                        02 GSXR-1000
                                        97 540i
                                        • PSiedTSiP
                                          PSiedTSiP
                                          with that being said it could be a dead spot and not completely bad...cause like i said it reads up to 75% or so...
