  4. maint req light? and cd player problems
16 Posts 9 Posters 1.0k Views
    i've seen some hondas/acuras that have the main. req. light just come on out of the blue and nothings wrong....
    as for ur cd player....its a Alpine...i know alot of people who have had many problems with Alpines.....just hit the reset button and it should work again.
    • harwood39H
      harwood39H
      harwood39
      wow, that sux, they helped me, what autozone did you go to, who was it?
      2730 5th Ave S. Unit C
      Fargo, ND 58103
      701-429-3686
      • bluejaysB
        bluejaysB
        bluejays
        it was the one on 13th ave. there is one guy i normally deal with when i go there that is cool, but he wasn't working. this guy was just a prick, but w/e.
          go to the one on university
          • L
            L
            legacy-user-131
            by maintence required light do you mean the indicator that goes from green to red? if so there is a button you push w/ your key to reset it. it's changed after a certain number of miles to let you know you need to change your oil.
            94 Prelude SI
            • bluejaysB
              bluejaysB
              bluejays
              i have no idea if it is green or not before. all i know is that its an amber color now. i think it normally flashes when i turn on the car now it just stays on. where would this button be that i have to press with a key?
              • L
                L
                legacy-user-131
                according to a thread on honda-acura.net
                "you can turn it off by turning the key to the acc position and reaching under the steering wheel column and holding down a small sqaure button until the light turns off."
                never done it before, so i don't knwo how accurate that is
                94 Prelude SI
                • TsiTomT
                  TsiTomT
                  TsiTom
                  My accord was the same way...there is a difference between this "maintenance required" idicator and the actual check engine light. The indiator will go from green to amber and then to red (red meaning your way past scheduled maintenance). But I have no idea how to reset the inticator in integra's. All it took for me was my key...just like resetting the trip.
                  Tom Opgrand
                  2011 Camry
                  • My NOvaM
                    My NOvaM
                    My NOva
                    auto zone is only on university ave one on 8th n. and one on 15th s. go to the one s. theyll help u out with the obd2 and as for ur cd player i would have to look at it in person to fix
                    Hey Tina come get some hamm
                    • S
                      S
                      slowvo
                      2 pages on how to reset a service light, and 1 good response.
                      i say go to autozone too, their scanner will reset it
                      • A
                        A
                        adog
                        There is a button underneath the dash which rests that light, which is your Acura's friendly way of reminding you to change your oil. The Maintenace Required light is triggered by mileage, I believe, and it does not indicate a malfunction.
                        • bluejaysB
                          bluejaysB
                          bluejays
                          where under the dash is it? i couldn't find a button, but i will look again in the daylight tomorrow.
                          • ticklemedalyT
                            ticklemedalyT
                            ticklemedaly
                            Yes, this^^^^^^^^^^^^^
                            Hondas use a maint req light to remind the user that it is time to change the oil. Dependant on the vehicle, it usually comes on every 7500 miles, which is hondas oil change service interval. On the integra, newer ones like yours, there is a small square button on the bottom of your dash that you need to hold down to reset it. just get upside down and use a flash light, itll be right in front of your face.
                            XBL G-tag: TickleMeDaly83
