  4. SRT4 vs Tiburon
SRT4 vs Tiburon
81 Posts 14 Posters 5.2k Views
  • G
    G
    GraveDigger
    I wasn't trying to prove or say anything with it. You don't get it that the tiburons S/C don't need to run as much PSI. He turned his up to like 18-19psi, and the tiburon still won. How much is that SRT-4, like 30,000. I know that Tibby only has like 6,000 or so on it, so it all equals out. That SRT4 wasn't stock either by the way, hence the GReddy boost controller. All I am getting at, now that your arguing about it again, is that for under 30,000, I can have more WHP than a stock EVO, which usually ends up coming to like 32,000 - 34,000 after all said and done. It's a good video jim, you should just let it finish man. In the first race, the Tiburon misses 3rd and still owns.
    GraveDigger
      fully loaded SRT4 is $22825. Fully loaded Tiburon is 22085 for an auto, 22135 for a 6 speed. IDK what you are talking about here. For $690 you aren't going to run down any SRT4's. Get both of them to 30k w/ mods and I'd be willing to bet there wouldn't even be a contest. No offense, cuz I am glad you are trying something a little different, I just don't see how it's going to be as easy as you think to build huge HP. Even if/when you do reach the WHP of the Evo or STi or any AWD car for that matter, odds are that you won't put up the times that they do. Why? Because you will have to deal w/ weight transfer to the rear of the car which will make getting traction on the line all that much harder. What I'm saying is don't count your chickens before they've hatched.
      • G
        G
        GraveDigger
        I know man, all I wan't is like 275 or so WHP, which is easily done with one kit. Actually, the manual tibbys with that same RIPP S/C setup are laying down like 312 WHP. Yeah there will be traction issues because I am FF, but it would still be great, and I could own EVO and STI from a roll, just like jim. Your an auto also arent you tj?
        Now that I think about it, no I won't have traction issues, my luanches let me only go so high, and I think, that will actually help me. I see all these people that launch way high, and just sit and spin all day. I don't think it will be that bad.
        GraveDigger
        • JimJ
          JimJ
          Kinda wierd reasoning here... PSI doesnt equal flow. You could be running 25psi on a tiny turbo, or high boost on a tiny supercharger, and not equal what a big turbo would even at low boost. You can't compare the SRT-4's turbo with the Alpine supercharger... I don't know jackshit about superchargers, but the Alpine kit uses Eaton M63 supercharger... I'd be willing to bet it's a good deal larger then the 16G used in the SRT-4. Throw in more displacement and two more cylinders....
          A boost controller really isn't much of a mod, compared to an entire supercharger kit (and then some). There's no doubt that a Tiburon could make 250whp... but anything above that is going to take some serious cash. The SRT-4 or Evo on the other hand, already have engines that have been proven to make 400+ hp.
          • G
            G
            GraveDigger
            Someone made a comment about the tib only running 6psi, like it was a low slow number, so I said that it's not the same scale pretty much. I just said the boost controller because I saw that for sure. They are not big, but it has more. I can't for sure make it out, but it looks like it says IMBC, or just MBC, WGA, 3inch exhaust and intake. All the tiburon has is S/C bolt-on. You should be able to d/l it now good, I just got it again at like 170k/s.
            GraveDigger
            • JimJ
              JimJ
              OK I just watched the video. 11.5psi the first run against the Tiburon.... that is super low boost for the SRT-4. When he turns it up just a bit higher, they are DEAD even. Only when he gets off the gas does the Tiburon pass him. IMO that's not ownage... Not bad for a car with just a boost controller and exhaust. In response to your comment about 6psi as "low" boost for the tiburon.... The tiburon's engine internals weren't built for much more then 6psi (the same will almost all NA engines)... so that would be about the limit for it.
              SRT-4 Mod List:
              Boost Controller
              Turbo Back
              Intake
              Tiburon Mods List
              Engine/Drive-train:
              Alpine aqua-cooled S/C 6-7 PSI
              MBRP Exhaust
              NxtGen Headers
              AEM CAI
              Ground Wire Kit
              290 CC Injectors
              Nology Hot Wires
              Denso Irridium Spark Plugs
              NxtGen A/F Tuner (Piggyback)
              B&M short shifter
              Clutchmasters Stage 4 Clutch
              Fidanza Lightened Flywheel
              NxtGen Alcohol Injection Kit
              Overdrive Pulley
              • G
                G
                GraveDigger
                It also doesn't have any FI stock. Tiburons can run up to 14 psi on those S/C's. 6psi is good for that S/C. It's not the same scale. The engines can also take 300+ on stock internals, not to bad of a platform if you ask me. Thanks for putting senior ricer on my profile. I really enjoy it. It's to bad that I don't like rice, and I am not rice at all. The neons are done, get over it, and if anyone wants to help me finish smashing the rest, be my guest.
                GraveDigger
                  Senior Ricer haha thats great...i dont think any tiburon would own a STI or Evo from a roll either...especially not yours!
                  • JimJ
                    JimJ
                    The amount of boost isn't on the same scale? Boost is boost, turbo just generates it from exhaust gases, s/c from a pulley. I didn't do the user title, and I'm sure it was a joke.
                    I'd enjoy seeing a Tiburon boost 14psi. I am 100% sure that engine would not last.
                    • G
                      G
                      GraveDigger
                      Go back over to newtiburon.com and enjoy.
                      GraveDigger
                      • JimJ
                        JimJ
                        I've been there. Boost your car to 14psi. I dare you! haha. Actually I triple dog dare you.
                        • NickBN
                          NickBN
                          NickB
                          so when you getting your supercharger then
                          • NickBN
                            NickBN
                            NickB
                            Yeah it was even better when we got it to be bold
                            • G
                              G
                              GraveDigger
                              As soon as I get done working my ass off for my money. You shouldn't even be talking, you have an accord, that will never probably even get to 250whp.
                              GraveDigger
                              • NickBN
                                NickBN
                                NickB
                                like they don't make supercharger kits for accord smart ass
                                • JimJ
                                  JimJ
                                  Haha, you shoudl get a kit, run high boost till it blows and take it to gateway and have your grandma take it in.
                                  That'd be funny shit.
                                  • NickBN
                                    NickBN
                                    NickB
                                    ahemm what do you drive again?
                                    • G
                                      G
                                      GraveDigger
                                      My grandma on my dads side just passed away about 4 months ago. That's drake that has his grandpa pay for everything. I drive a better car than you, what's you point? Because of you 2, this thread has also turned into a pointless flame war. It was just a video.
                                      GraveDigger
                                      • JimJ
                                        JimJ
                                        Nah i meant, they wouldn't think a grandma would be boosting a tiburon. I dont relaly know anythinga bout peoples grandparents.
                                        • NickBN
                                          NickBN
                                          NickB
                                          i believe it was a joke..sorry about your grandma tho..oh great here it goes he drive a better car than me now...im gonna stop now
