  3. Run Your Mouth
  4. New to Fargo Argument
135 Posts 24 Posters 12.9k Views
    add fuel
    pull timing
    have you datalogged at all? Whats the AFR when you are detonating?
      btw, this is where someone will usually say I'm picking on the newbie (toxshox)....sorry, I don't like it when wrong info is given about wrx's, I think I've been around them long enough to make my points clearly and accurately.
      • STiSchuckyS
        STiSchuckyS
        tjamz wrote:
        add fuel
        pull timing
        high 10s. close enough
          that should be fine....hmmmm.....try pulling timing, do a datalog of the run, you should be able to see knock count at what RPM and Load you were running at. You might wanna look at the fuel map as well and just make sure there isn't a "lean" spot in it anywhere (something that only lasts for maybe 1-2 points on the map right around the point where you start noticing knock). If you notice a lean spot on the map, add fuel in that spot and make another run....better yet, do a datalog and send me a copy of it along w/ a copy of your maps (Stage 2 and the map that was tuned by RS)
          • STiSchuckyS
            STiSchuckyS
            kevin thinks its also im runnin to much boost on 92 oct.
              yeah, that would do it too
                how much boost?
                  If its over 19-20 its too much
                  • STiSchuckyS
                    STiSchuckyS
                    it is :).
                      yeah...you might wanna back that boost down unless you wanna rebuild that motor soon....subies HATE detonation, even the 2.5's
                      • STiSchuckyS
                        STiSchuckyS
                        simple urban myths. nah jk, ive been running stock settnig the whole time. i tried a 2 hammers on the way to the shop tonight and got it so i put it back on map 0. i named stage 2, track day only stage. even tho stage 0 pulls pretty nice, in terms of 92 oct. wise
                          Still, if you're running that much boost on 92.....its gonna be expensive fast....unless you were j/k about the whole deal, then nevermind
                            DAMNIT KIRK, we took a perfectly good argument and went all off topic and made it into a discussion about car parts, nice going fag.
                            • STiSchuckyS
                              STiSchuckyS
                              fuck you fag!
                              k we need to continue the wrx vs gsr fight..umm
                              go wrx. gsrs fat!
                              • STiSchuckyS
                                STiSchuckyS
                                btw how much boost is suitable for map 0 92 oct?
                                  STiSchucky wrote:
                                  fuck you fag!
                                  go wrx. gsrs fat!
                                  Yeah!! And um....he dresses funny! And....and....and.....well, I don't wanna say what else....
                                    18ish maybe a hair more, depending if you get boost spikes or not.
                                    • STiSchuckyS
                                      STiSchuckyS
                                      nah i dont get boost spike, more of a boost death.
                                      • 91nbtsi9
                                        91nbtsi9
                                        wow, you guys should go hold each others hands somewhere else and talk about tuning your cars....:)
                                        • integra_gsr98I
                                          integra_gsr98I
                                          "i love you" - kirk to chuck
                                          "no i love you" - chuck to kirk
