  3. Track Talk
  4. Aug 6&7 Street Legal Times
73 Posts 25 Posters 9.0k Views
  • 91nbtsi9 Offline
    91nbtsi9 Offline
    Blah blah, if you guys ran some real boost....it is worth it!
      define real boost? 23 psi? 25 psi? 30 psi?
      or do you mean large turbo, cuz in that case Jeremy with the white STi doesn't really qualify either, he ran 12.2 w/ a 20G....turbos that I keep hearing are small seem to be keeping up with bigger turbos....
      • 91nbtsi9 Offline
        91nbtsi9 Offline
        Eh, 25 psi or so and up pretty much requires race gas...unless you like melted pistons. Turbo size is somewhat related, but not soo much. High boost on a little turbo will usually cause more detonation than a larger turbo. About your 2nd point, I assume you are referring to the big turbo being Jeremy (DSM), car is slower than before because he doesn't have everything else he needs to support the bigger turbo. That white STI was quick! I liked it:) Too bad you didn't get a clean pass Chuck, I think you would have ran pretty good.
        The main point, race gas is awesome, but not if you don't need it. If you aren't using a setup that requires it (high boost, high timing, etc.) then don't use it. Ok, I am done now.
          I was told he had a green which would be a 50 trim not a 20G.
            I'm going off what Tintmasters told me for his turbo size, never bothered to check it out myself.
              Either DSM's have went 10's on a 20G!
                not sure how to interpret that last statement tufte....but I think you meant to say that that DSM's have gone 10's in a 20G, well if thats the case, then why all the fuss about 60 trim or larger?
                • raviR Offline
                  raviR Offline
                  ravi
                  I finally broke into the 12's. Not a bad 60ft either. I can't wait to see my trap speeds after I put in my new injectors/intake/software.
                  Too bad I sold my wheels last tuesday, I had to run on my studless winter tires. They hooked up surprisingly well, Quattro AWD is the shit.
                  I can't wait until we get a decent day out there. I'm starting to get sick of this 90+deg weather everytime I'm out at Sabin. Maybe I need to start hitting the strip in the fall/spring not the summer. I need to see what this thing can do on a decent day. My new goal is sub 12.2
                  We'll see what happens. My best trap of the day was 111.
                  2008 Audi A4
                  2000 Audi S4
                  - Sold
                  12.4@116
                  • camzaro28C Offline
                    camzaro28C Offline
                    camzaro28
                    damn some of u put out suprisingly well numbers for the horrible heat
                    best of [email protected] with drag radials. then put on the ETstreets ( overkill, i know. just wanted to see how it did with them)
                    best of [email protected] pulled 2.0's everytime with one 1.944
                    if i still had my converter in, them tires wouldve really helped.
                    jig 4 prez
                      slowvo
                      Small Penis Syndrome = needs big turbo to compensate for...well...
                      acually, its just easier. spool up isnt a big deal when your on the track, and working a small turbo just creates alot of heat.
                      • 9 Offline
                        9 Offline
                        97lt1
                        I should be getting my ET Streets tomorrow, nice to see the 60 ft's you were getting with them. MAybe you could pull off a 12 with the ET Streets and a better converter.
                        I'm getting the ET streets at cost otherwise I wouldn't be getting them.
                        • 94NDTA9 Offline
                          94NDTA9 Offline
                          That reminds me, get them back to me when ever you can. I'm in no hurry though.
                            ^^Brian Lost your number^^^
                              I ran the usual 10.4's in the heat (no nitrous). I did manage a 1.49 60' on one pass, the rest were 1.51 or 1.52
                                the white STI has a 20g.....and lots of time on the dyno.
                                  What are you talking about fuss of 60 trim or larger?
                                    Whats he do for a job? I was told he's shelled out 8500 into his car?
                                    damn im at like 1/3 of that.
                                      he's an electrician...he also lives with his parents so he doesnt really spend any money on anything but his car......from what i heard he brought it to some place in chicago thats specializes in Subaru's and is supposed to be the best in the nation....and it helps that his parents are loaded too...but he usually buys all his cars and his car shit himself....his brother has the turbo'd rsx
                                        Basically giving a lot of people shit, because every time I've mentioned FP Green or Red series turbos I keep hearing "Get a real turbo" or "Those are tiny". My question was, if a 20G/Green/Red can run in the 12/11/10 second range, why bother with a larger, slower spooling turbo if we're all gonna be running the same speeds? I'd much rather have the quick spooling turbo personally. I'm not trying to start a big e-fight, you guys have been in the game longer than me, I just wanted to know why the huge turbo mentality.
                                        • 91nbtsi9 Offline
                                          91nbtsi9 Offline
                                          DaveH wrote:
                                          (no nitrous).
                                          Liar liar... 😛
