  3. Track Talk
  4. Aug 6&7 Street Legal Times
73 Posts 25 Posters 8.4k Views
    Turbos that don't spool at idle just need antilag or a two step to help them along, that is all. 🙂
    Fast spool + wicked fast car = not gonna happen unless it's a v8. 😉
      91nbtsi wrote:
      There is no flip side.
      You can't build a car to be great at both drag racing and Auto-X. You can make one to do ok at both, or great at one or the other. I am so sick of hearing people whine about turbo spooling, if you want a little turbo that spools instantly when driving around the street, then don't whine when your car is slow. Same goes for the guy that wants to be fast at the drag strip, don't whine when your turbo doesn't spool at idle. I don't hear as many as the 2nd type of whiners, but it happens. An engine is simply an air pump, more air you put through, the more power you get out(along with more fuel), end of story.
      You are 100% correct, but could the argument not be made that if a Green can get you 11's and maybe even 10's, have minimal lag AND be a reasonable daily driver on a car that is pretty much built from the factory for road course/auto-x, that it would be a good choice for someone who isn't building a drag specific car, but rather something that will do well (not great, but decent) in all avenues of personal use and race?
      I agree that larger turbos will make more power at lower boost, the STi block has been proven to withstand 25psi on a bone stock bottom end and last for quite a while, heck my bottom end has been exposed to 24psi+ several times w/ no problems (other than 1 blown exhaust gasket). All I'm saying is that I understand why people get larger turbos when they are going for a racing type application, but it seems noone will even consider a smaller turbo w/ higher boost and less lag as a compromise, even if that compromise can yield (sometimes) similar results at the strip.
      To summarize, yes a big turbo is great for dragracing, but I drag race my car less than 1% of the time, therefore a "small" green or red seems like the logical choice.
      • 91nbtsi9 Offline
        91nbtsi9 Offline
        Yes, you have a good argument. BUT, for myself, and most others on this board, the car is just never fast enough!! Maybe you could put a 50trim(green) on your car, and call it good, I would not be able to do that. I am pretty sure I am going to get another DSM, I miss going fast. It will have a really big turbo, and really high boost;) Maybe I will get yours and Kark's approval to use race gas in even!
        Basically, it all depends on what you want out of your car. I started playing with smaller turbos, 60trims;) Just kept moving up.
          tjamz wrote:
          To summarize, yes a big turbo is great at all times, but I don't race my car at all, much less than 1% of the time, therefore a "small" green or red seems like the logical choice for girlie men.
            I'm in the same boat as Nate, you'll notice that the turbo in my car keeps getting larger every year.
            • 91nbtsi9 Offline
              91nbtsi9 Offline
              DaveH wrote:
              Haha, I like your addition to his quote there Dave. Nice touch;)
                Hahaha. Nice Dave.
                Bigger = better right?
                  I've always been a fan of race gas, I run 111 whenever I'm at the track and usually run a blend of 111 and 92 the rest of the time.
                    maybe I too will someday build a car that is designed to be a track monster, until then I will work at making my car as fast as it can be with the current parts.
                    • Turbo5OhT Offline
                      Turbo5OhT Offline
                      Turbo5Oh
                      you mean not everyones car is at full boost at 2700rpm? boy that must suck!
                      (just had to rub it in a little)
                      p.s. race gas is for girls
                      • 9 Offline
                        9 Offline
                        95TsiAWD
                        Yeah but also consider turbo 4 cylinders are revving out to 8k, 9k and even higher. We arent seeing full boost until 5k.. but that leaves us 3-4k of power range.
                        Yeah a v8 spools faster, but it wont rev out as much either, when it comes down to it, a turbo 4 cylinder and a turbo v8 have about the same 3-4k power range.
                        95 TSi AWD
                        Old Turbo #'s
                        522whp/414wtq
                        [email protected]
                        11.3@129mph
                        Procharged 99 Corvette
                        95 LS6 Mustang
                        01 300m
                        06 Suzuki LTR-450
                        • 91nbtsi9 Offline
                          91nbtsi9 Offline
                          I swear you and Kark were saying race gas was a waste of time...see below:
                          STiSchucky wrote:
                          some gay time like 13.4.
                          im never running race gas again. overrated shit.
                          tjamz wrote:
                          I've said that before too..........
                          That is what I thought 😛 Oh, and I consider 111 piss, C16 is race gas! Just kidding, but it is a world of difference between the two. I will never use 110 or 111 or whatever again, just the really expensive stuff that made my car run way better.
                          Schell, I would hope your car spools then because you only get to rev to what, 5500? heh.
                          You are just mad because your block would split in half if you tried to run enough boost that you needed race fuel 😄
                            Chuck, your missing the major point here of what i said pages ago especially regarding the FP Red, that turbo is a 60-1 based turbo they do not spoool that quickly, the Garrett GT30 BB series turbo's A. Spool faster, and B. Make more power than a 60-1 will unless you are running low boost levels say 15 psi or less.
                            • Turbo5OhT Offline
                              Turbo5OhT Offline
                              Turbo5Oh
                              torque is pretty sweet thing to have also
                                Nate..on the race gas thing, I said that the first time I ran, but at the time I was only running a boost controller and exhaust and thought I wasn't gaining anything from the race gas (which I probably wasn't, car wasn't knocking, I was only running 16psi on stock turbo, etc...) Once I stepped up to a larger turbo (though still small by your guys standards) and got on the dyno I realized that the diff between 111 and 92 in regards to safe power was about...oh....45 whp. I became a believer after that.
                                Nick T.: Yes, the Red is BASED on the 60-1, but the current version of the Red designed & flanged for the WRX/STi spools ages before a traditional 60-1 would. They are currently ball bearing and full boost is achieved by ~4300 RPM on a 2.0 Liter and ~3900 RPM on a 2.5 Liter.
                                Schell: I agree, torque is nice....thats why I have a suby...heh
                                • 91nbtsi9 Offline
                                  91nbtsi9 Offline
                                  Yes it is, which is why I had 426 lb-ft of it in my talon, well more than that but when I tried to dyno on a good tune, my clutch was shot.
                                    On the topic............ Best I could run on pump gas on saturday was a 12.0 @ 114 w/ a 1.66 60ft. Then on sunday on the leaded 111 gas and more boost, best I could run was a 11.59 @ 121 w/ a 1.70 60 ft. Note that there had been NO tuning done before the drags at all. So I had to do some on the track. But with the hot ass weather I was always getting knock in 4th gear, sometimes even 3rd gear.
                                      Joe's GT3076 see's full boost right around if not before 4000rpm.
                                      From looking @ the FP's for the WRX they appear to be dry housings which would mean they are standard conventionl bearing not BB
                                        you should always go one step bigger than what you want lol...after having the 50trim im thinkin maybe nothin smaller on the 240 when the time comes...im lookin at a GT3071R 🙂 people have been making close if not 400whp on pump gas @ about 19psi or so
                                          Your car looked and sounded really good with more boost. 🙂
