  4. Motor choice
Motor choice
56 Posts 22 Posters 2.0k Views
  • bluejaysB Offline
    bluejaysB Offline
    bluejays
    well what are you hp goals? if you want anything over 280ish, go with the b series, otherwise go d series. also if you go b series the b18c1 can rev to 10k with minor head work, where as the b18b needs major low end work done before it can rev over 8ish i believe. so if you want something to rev high you want a b18c. one more thing to concider when turboing either block is b18b has like a 9:1 compression ration and i think the b18c has 10:1 (someone correct me if i'm a little off). so you can run more boost through a STOCK b18b. really, the fact that you have to tune around vtec isn't that big of a deal. so you need to make some decisions of what you want hp wise and if you don't know then i'd just go b series, because there is always room to grow.
    ps. you could always go k series or h series too.
      k series would put him over his goal $$$ with just the engine... h series might be doable
        If your only looking to spend $3k total after install your pretty much stuck w/ a LS swap.
        • krzydrftr93K Offline
          krzydrftr93
          sorry Joel miss understood you but i like what bluejays said about the b18c1. The ls swap with vtec head sounds like a lot of work to me and chipping ecu or something so it works right. HMMM i would like to have over 280 someday and teh gearing on the d15 motor in it sucks balls, I personally like the gearing on my friends 94 prelude si. Its alright anyways.
          Keep the opinions coming. How much would i be looking at for a b18c1 complete swap and installed.
          Matt
          92 Civic HB
          JDM d15b w/14b@8psi
            www.hmotorsonline.com
              aliengotpsi
              fuck the B motor unless your gonna go for big power, stay with the D16 Z6 and turbo it id talk to tufte, thompson about what engine to get... they are the only 2 ppl in town that has made a honda go 11's
              but if money wasnt an object id COPY GSR's Engine with higher compression..
              Tufte's Stock 1.6 turbo made 267 hp 10 psi
              Thompson Unstock 1.8 turbo made 540 hp 25 psi
              Kevin Smith
              Straightlinedetailing.com
                yeah the turbo single cam is great, but you have to look at it from a reliability/driveability stand point also... most people don't want to go through the hassle of having to change a cluth/transmission/engine every other time we race...
                • bluejaysB Offline
                  bluejaysB Offline
                  bluejays
                  personally from what it sounds like he wants to do, i would go b series. he said he wanted more then 300 hp and that is out of the d series range ESPECIALLY if you want something semi reliable. which block he wants is all personal preference though. if you want to rev to the sky go with the b18c. if revs don't really matter much for you, i would go b18b.
                    this is totally a "ricer" mentality, the idea that high-revving equates to powerful :rolleyes:
                    believe it or not, there are many turbo guys on honda-tech that are making peak power below 6k. proof? look at kevin's dyno graph's when he had a stock intake manifold.
                    how much power he wants to make and how much tuning he wants to go through are the major factors in deciding what kind of turbo he wants. a larger turbo (57trim) will make more power at 10psi than a t25, obviously because it's a larger turbo and pushes more volume.
                    granted, the big turbo will push much more air (read: is capable of higher engine rpm), but the gears are still so close, so it would only pull for so many rpms. to truly take advantage of a huge turbo, one would want to gear the transmission to engage into the next gear at an rpm that creates enough exhaust pressure to spool the turbo again after shifting; but, then you would lose practical driveability...
                    yeah, i'm done rambling
                    cliff notes: how much power does he want and how much tuning is he willing to pay for?
                    • bluejaysB Offline
                      bluejaysB Offline
                      bluejays
                      i was just referring to that being the only major difference between the ls and gsr block. in no way did i say you need to rev 13k rpms to make power. that and the b18b is stronger supposedly. ricer? psh
                        unless i'm quite mistaken, the main reason that the b18c1 is more rev-happy, is due to it's shorter stroke (87.2mm vs 89)
                          krzydrftr93
                          so is that better then
                          Matt
                          92 Civic HB
                          JDM d15b w/14b@8psi
                            krzydrftr93
                            i would like right around the 300hp range sooner or later. I dont want to have to spend a lot on tuning the thing all the time. I just want it to run good and be quick. i would be satisfied if i hit 13 with it in a year or so. summer of 06 i would prolly just do little miner mods like the intake, full exhuast, plugs, wires fuel stuff, ignition and what not.
                            Matt
                            92 Civic HB
                            JDM d15b w/14b@8psi
                            • bluejaysB Offline
                              bluejaysB Offline
                              bluejays
                              fyi, bolt ons don't do hardly anything to any honda engines except k series
                                seanjohn
                                Everyone I have ever talked to who has done a b-series swap almost always says they wish they would've stay'd d-series and turboed it. Thats my opinion.
                                  seanjohn
                                    BUT... bottom line is if you want over 300whp........ you'll either need to b-series turbo, or a well built d-series.
                                      seanjohn
                                      I completely agree. The fact of the matter is that you can have as many d-series motors as you are willing to pick up out of people's driveways....b-series are still expensive to replace. Blow up a d-series?!?!?....who cares. In a turbo app there isn't many up's to have the b-motor.
                                        agreed. however it also depends on the person, if you decide to test the limits of the stock d-series make sure that you are willing to put in the time to swap motors/trannies/clutches... if you're not willing to do that, this may not be the route for you.
                                        • bluejaysB Offline
                                          bluejaysB Offline
                                          bluejays
                                          what i was saying was, simple bolt ons ie: headers, exhaust, cai doesn't increase hp very much on any B, D, H, F series honda engine.
                                          as far as going D or B if he plans on going with around 300 hp. i have this feeling its going to end up costing him more in parts and labor with a D series in the end, because 300 hp is about as much as you can push out of the D and thats built. now if you blow that up you have to buy another have it built and put in again. 300 hp out of a B series is relatively descent power for a B. your not pushing it to its limits so parts breaking isn't quite as much of a problem.
                                          just out of curiosity what has tufte all replaced on his D? and what has gsr all replaced on his B?
