  4. Motor choice
Motor choice
56 Posts 22 Posters 2.0k Views
    www.hmotorsonline.com
      aliengotpsi
      fuck the B motor unless your gonna go for big power, stay with the D16 Z6 and turbo it id talk to tufte, thompson about what engine to get... they are the only 2 ppl in town that has made a honda go 11's
      but if money wasnt an object id COPY GSR's Engine with higher compression..
      Tufte's Stock 1.6 turbo made 267 hp 10 psi
      Thompson Unstock 1.8 turbo made 540 hp 25 psi
      Kevin Smith
      Straightlinedetailing.com
        yeah the turbo single cam is great, but you have to look at it from a reliability/driveability stand point also... most people don't want to go through the hassle of having to change a cluth/transmission/engine every other time we race...
        • bluejaysB Offline
          bluejaysB Offline
          bluejays
          personally from what it sounds like he wants to do, i would go b series. he said he wanted more then 300 hp and that is out of the d series range ESPECIALLY if you want something semi reliable. which block he wants is all personal preference though. if you want to rev to the sky go with the b18c. if revs don't really matter much for you, i would go b18b.
            this is totally a "ricer" mentality, the idea that high-revving equates to powerful :rolleyes:
            believe it or not, there are many turbo guys on honda-tech that are making peak power below 6k. proof? look at kevin's dyno graph's when he had a stock intake manifold.
            how much power he wants to make and how much tuning he wants to go through are the major factors in deciding what kind of turbo he wants. a larger turbo (57trim) will make more power at 10psi than a t25, obviously because it's a larger turbo and pushes more volume.
            granted, the big turbo will push much more air (read: is capable of higher engine rpm), but the gears are still so close, so it would only pull for so many rpms. to truly take advantage of a huge turbo, one would want to gear the transmission to engage into the next gear at an rpm that creates enough exhaust pressure to spool the turbo again after shifting; but, then you would lose practical driveability...
            yeah, i'm done rambling
            cliff notes: how much power does he want and how much tuning is he willing to pay for?
            • bluejaysB Offline
              bluejaysB Offline
              bluejays
              i was just referring to that being the only major difference between the ls and gsr block. in no way did i say you need to rev 13k rpms to make power. that and the b18b is stronger supposedly. ricer? psh
                unless i'm quite mistaken, the main reason that the b18c1 is more rev-happy, is due to it's shorter stroke (87.2mm vs 89)
                • krzydrftr93K Offline
                  krzydrftr93
                  so is that better then
                  Matt
                  92 Civic HB
                  JDM d15b w/14b@8psi
                    krzydrftr93
                    i would like right around the 300hp range sooner or later. I dont want to have to spend a lot on tuning the thing all the time. I just want it to run good and be quick. i would be satisfied if i hit 13 with it in a year or so. summer of 06 i would prolly just do little miner mods like the intake, full exhuast, plugs, wires fuel stuff, ignition and what not.
                    Matt
                    92 Civic HB
                    JDM d15b w/14b@8psi
                    • bluejaysB Offline
                      bluejaysB Offline
                      bluejays
                      fyi, bolt ons don't do hardly anything to any honda engines except k series
                        seanjohn
                        Everyone I have ever talked to who has done a b-series swap almost always says they wish they would've stay'd d-series and turboed it. Thats my opinion.
                          seanjohn
                            BUT... bottom line is if you want over 300whp........ you'll either need to b-series turbo, or a well built d-series.
                              seanjohn
                              I completely agree. The fact of the matter is that you can have as many d-series motors as you are willing to pick up out of people's driveways....b-series are still expensive to replace. Blow up a d-series?!?!?....who cares. In a turbo app there isn't many up's to have the b-motor.
                                agreed. however it also depends on the person, if you decide to test the limits of the stock d-series make sure that you are willing to put in the time to swap motors/trannies/clutches... if you're not willing to do that, this may not be the route for you.
                                • bluejaysB Offline
                                  bluejaysB Offline
                                  bluejays
                                  what i was saying was, simple bolt ons ie: headers, exhaust, cai doesn't increase hp very much on any B, D, H, F series honda engine.
                                  as far as going D or B if he plans on going with around 300 hp. i have this feeling its going to end up costing him more in parts and labor with a D series in the end, because 300 hp is about as much as you can push out of the D and thats built. now if you blow that up you have to buy another have it built and put in again. 300 hp out of a B series is relatively descent power for a B. your not pushing it to its limits so parts breaking isn't quite as much of a problem.
                                  just out of curiosity what has tufte all replaced on his D? and what has gsr all replaced on his B?
                                    ^ i think you underestimate honda motors.
                                    also, bolt ons never do shit....
                                      to make any power with a turbed honda u MUST sleeve the block then it wouldnt matter what motor u went with because u could push 25+ psi and if u want more just go with a bigger turbo..
                                      b16-2000$
                                      sleeves-1000$
                                      supporting mods- lets just say 1000$
                                      huge turbo-1000$
                                      labor and shit- idk ask somebody that knows
                                        nick made 267whp out of a stock D-series why would building it only be able to yield 300hp? Building a D-series is cheap as hell cause you can get D-series for cheap as hell...
                                          b16-2000$
                                          sleeves-1000$
                                          huge turbo-1000$
                                          untrue.... there are a plenty of guys running ridiculous hp numbers on stock sleeves now 400-500whp. go hop on honda-tech and look. they're been using forged internals, but have been keeping the stock sleeves.
