  4. Quad 4 problems.
Quad 4 problems.
18 Posts 6 Posters 1.3k Views
  • wesholeW
    wesholeW
    Oh ya, And loose the fuckin Quad4 before your stuck with it. You thought a DSM was hard and expensive to keep on the road.
    • L
      L
      Lothurin
      Ahh thats bullshit, I've owned my 90 GTZ quad4 HO since 99 and i've never thrown anything into but a new powersteering belt and some sparkplugs that didn't even need changing. Oh wait i spend a whole whapping 2.33 cents on some vacuum hose.
      If u drive it like a idiot of course you'll have problems. your not drag racing the car so i don't see y u ever need to go past 4k RPMS
      Just because ur motor is 10+ years old don't mean it won't still run like its new. Its how much you beat the hell out of it. Btw my 90 GTZ only has 108,000 miles on it and still run like new.
      Lothurin
      Soul MotorSportz GM_FWD Jeff's Upholstery
      A+ Performance
      • wesholeW
        wesholeW
        You are one of the lucky ones. There is no engine out there that has a worse reputation than the quad4, BAR NONE! You can't tell me that they aren't notorious for head gaskets and even cracking heads. Even on a well maintained engine. I PERSONALLY have seen it 5 times with friends and family members alone not to mention all the other ones I've seen out there. I understand that you own one and will stick up for yourself because of this. I'm not going to get in a pissing match with you either. I've been in the automotive field for 12yrs. in one way or another and have sold parts for them and worked on them I am purely speaking on experience. Just callin it how I see it.
        • L
          L
          Lothurin
          Yeah no doubt they have their problems but there is parts out there already to fix those problems. I knew 2 guys that have Super Charged their quads. One is in cali and other is in canada and never had a problem yet. Personally i think the whole problem with them is the high compression they have just to make the 180 HP. But you and I both know GM can mess up a wet dream even if it was handed to them.
          I do believe that newer quad4 (92+) had the problems fixed and then GM messed up the 2.2s and they started to have the quad4 problems
          Lothurin
          A+ Performance
          • wesholeW
            wesholeW
            Agreed!
            • S
              S
              seanjohn
              I had a 92 GAGT quad4 H.O. and worked on it quite a bit. If the stuttering is all the time, sounds like it might be the headgasket. If it occurs only under heavy load (such as when trying to accelerate, especially from a high gear) then that is usually the coil packs. They're really easy to replace. LMK if you need anymore help.
                It is the DOHC version from 89 so I really don't know how much juice it has nor do I care. The motor is only supposed to have around 60K mi on it so I see it having a little life to it.
                • PSiedTSiP
                  PSiedTSiP
                  Lothurin wrote:
                  i'm pretty sure there was no Quad4 HO's in Grand Ams, mostly just berettas and i think Achieva SCX had the W41 (190). Grand Ams either had the SOHC or the 160 HP verion Quad4 LO
                  but i'm sure most everyone here will tell ya to junk the car. But since i own a 90 Beretta GTZ with a Quad4 HO i'm going to send you over to
                  http://www.quad4forums.com/
                  they will tell u anything u need to know and probably where to find some performance parts for more than u can buy a mildly used honda.
                  wrong there are in the early grand ams i know FOR SURE...and i think they put em in the 92-95 body style as well...cause i looked for one... http://www.edmunds.com/used/1991/pontiac/grandam/1229/specs.html?tid=edmunds.u.prices.leftsidenav..6.Pontiac* 180hp...quad 4 ho 🙂
                  http://www.edmunds.com/used/1992/pontiac/grandam/18094/specs.html?tid=edmunds.u.prices.leftsidenav..6.Pontiac* 180hp...quad 4 ho 🙂
                  spanish-rice;237125 wrote:
                    What the hell does it look like this 180 hp quad 4?
                    • PSiedTSiP
                      PSiedTSiP
                      http://members.aol.com/V63100/ben3.jpg
                      it does say High Output on it
                      • ticklemedalyT
                        ticklemedalyT
                        ticklemedaly
                        Quad 4 is the worst engine ever, no exceptions. If you owned one and didn't have any problems, you are lucky and the new owner is going to have all the problems that they have, being a technician, I deal with them all the time....
                        now, to this persons thread here, definately try the ignition stuff, but dont over look the ignition module, it is expensive as hell, but gm likes to go through them for sure. Ran into a lot of Quads with similar problems and all it was the module. But it probably needs a tune up in the first place so replace the plugs and make sure that the boots/tower is good. check for any corrosion and damage.
                        XBL G-tag: TickleMeDaly83
                          Plugs all have been recently changed.
                          I got to get the Talon up and running before I can get this thing going.
