  4. GRRR, if its not one thing.. 90 Sunbird overheating, help?
10 Posts 6 Posters 490 Views
  • JohnWJ Offline
    JohnWJ Offline
    JohnW
    OK so now my girlfriends car, which we are currently trying to sell, is overheating. It just started doing this today. The coolant level is good and doesn't show any signs of oil contamination, and the oil smells like oil, not burnt coolant, so i don't think the headgasket went. I am thinking maybe the water pump has stopped working, which will require a timing job pretty much to fix. Is there anything else maybe simpler I could check for? any help is appreciated. Is there any way to tell if the water pump is bad other that just taking it off and replacing it? thanks. yeesh, hopefully this won't take long so I can get the dsm running before too long.
    90 Civic DX hatch
    D16a6/y8 mini me
      if it is the 3.1L v-6 look at the intake gasket. it went out on my grand prix and the people at sellands said that that is extremely common on all versions of this motor and usually happens around 100k miles. they quoted me $600. it would over heat just everyonce and a while and then on a cool day it would overheat extremly fast
      • 9 Offline
        9 Offline
        97lt1
        If your water pump was bad it would be leaking out of the weep hole
        Is your thermostat opening
        white smoke out of the exhaust
        You could pressure test the cooling system
        air in the system
        just some suggestions and things to look for
        • JohnWJ Offline
          JohnWJ Offline
          JohnW
          hey thanks, ill take a look at a couple things in the morning, its a 2.0l 4cyl if that matters. the shop manual is at my moms place so that doesn't help either.
          90 Civic DX hatch
          D16a6/y8 mini me
          • ticklemedalyT Offline
            ticklemedaly
            Ya, there are way too many things you need to look for in the cooling system, you have to eliminate all of them when you deal with an overheating issue. Just do it quickly before you ruin the head.
            Ryan
            XBL G-tag: TickleMeDaly83
            • M Offline
              M Offline
              mym6
              Does it overheat only when sitting still or even on the hwy? If it only overheats while sitting still it could just be the fan.
              • JohnWJ Offline
                JohnWJ Offline
                JohnW
                found one culprit. radiator fan no workee.
                90 Civic DX hatch
                D16a6/y8 mini me
                • M Offline
                  M Offline
                  mym6
                  until you fix the fan, you could run the heat at full blast 😛
                    86fc3s wrote:
                    81 Eclipse GSX OF DEATH (and broken-ness)
                    it could also be the fact that you claim to have an 81 eclipse. but then again, what do i know? 😛
                    • JohnWJ Offline
                      JohnWJ Offline
                      JohnW
                      own3d.
                      (and fixed)
                      90 Civic DX hatch
                      D16a6/y8 mini me
