  4. need input
need input
37 Posts 14 Posters 4.0k Views
  • legacy-user-544L Offline
    legacy-user-544
    so i want to buy a 2g dsm. i know a large part of the fargostreet community owns a dsm so im sure that you guys can tell me what the goods and the bads of owning a dsm are, and what to look for when buying one.
    thanks in advance.
      Buy mine.........
      • Y Offline
        Y Offline
        yose
        buy a neon
        My Ride
          coming from a guy who owned one, but probably knows a lot less than most people on here about them.. they CAN be fairly reliable cars if you treat them right. however, most people dont. just keep in mind that if you go racing all over the place, itll break a helluva lot faster.
          just go through the car like you would any other. make sure it shifts well, no fluid leaks, fluids were changed regularly, belts are fine (timing belt should be replaced at 90k miles), etc. make sure you hit boost nicely and there arent any leaks. if you can take it for an afternoon, $30 for a full inspection is one of the best things you can do.
            legacy-user-544
            99slowGSX wrote:
            Buy mine.........
            specs and pics por favor. thanks amicheze for the feedback. anybody else have anything to say?
            • D Offline
              D Offline
              dsmquest
              My advise would be go and buy/rent a compression tester to check the compression, and always check the cv joints for rips or leaks. Anything with less than 100,000 mi is good, i dont know to much about the 420a if a non turbo is what your looking for. Try the many dsm sites if you havent already lots of good info there. Good luck
              1992 Eagle Talon TSI AWD
              1991 Eclipse GST (piecing together)
              1990 Eagle Talon TSI FWD (Parts Car)
              1989 Nissan 240SX (DD)
              1988 Chrysler Conquest TSI (traded)
              1987 Mitsubishi Starion
              • legacy-user-33L Offline
                legacy-user-33
                My friend at work is selling her silver 99 Eclipse OZ edition for $7,500. Same as a GST, except its n/a, correct me if im wrong..
                -Tin-
                -IS300-Black on Gold-
                • TsiTomT Offline
                  TsiTomT Offline
                  TsiTom
                  DSM's are a love/hate relationship....the 95 and 96 7 bolts are probably prone to problems than any. But if you find a 2g that has a 6 bolt swap then id say your set. Just do some research and be as cautious as you would with buying any car. If you find one thats mildly modified make sure everything is sound. Otherwise good luck!
                  Tom Opgrand
                  2011 Camry
                  • YellowEvoY Offline
                    YellowEvoY Offline
                    YellowEvo
                    Same as a GST but n/a... i'm lost....
                    2003 Mitsubishi Evolution 8
                    2011 Ford F150 Ecoboost
                      OZ edition has the "turbo" wing, side skirts, different rims.... but a 420a motor. $7500 for an OZ edition is a rip off. You should be able to find a fair condition turbo dsm (stock) for that.
                      Buy mine. It will come with a new turbo.
                      Engine:
                      6 Bolt Full 4G63 Motor Swap / Complete Rebuild
                      Bored .020 Over
                      Eagle Rods
                      Ross Pistons 8.5:1
                      ARP Head Studs
                      Metal Headgasket
                      Balance Shaft Eliminator
                      1mm Oversized Stainless Steel Valves
                      1G Intake Manifold
                      Aeromotive Fuel Pressure Regulator
                      Aeromotive FPR Engine Bay Mounted Gauge
                      -6AN Stainless Steel Fittings and Hoses
                      PTE 680cc Injectors
                      Walbro 255lph High Pressure Fuel Pump
                      Ported 2G Manifold (I also have a Stainless Steel Tubular Manifold, but it cracked, have to send it in for Warranty)
                      Bullseye Power T04B 50 Trim Turbo
                      Stainless Steel -AN Oil Return
                      Stainless Steel -AN Oil Feed
                      Straightline Specialties 3" Intake
                      Real K&N Air Filter
                      3" O2 Dump Tube O2 Housing
                      True 3" Down Pipe
                      Apex'i 3" Cat-Back
                      Generic Bar and Plate 31x12x3 Intercooler
                      Straightline Specialties "Backdoor" Intercooler Piping
                      Greddy Type-RS Blow Off Valve
                      Generic Catch Can
                      Shaved and Polished Valve Cover
                      Straightline Specialties Boost Controller
                      Transmission:
                      Double Syncro'd 2nd, 3rd, 4th Gears
                      ACT 2600 Clutch
                      Evo Shift Forks
                      Evo Shift Rails
                      B&M Short Throw Shifter
                      Greddy Counterweight Shift Knob
                      Electronics:
                      S-AFC II
                      Straightline Specialties Vent Bezel
                      Aiwa MP3 Deck
                      Gen. 2 Reverse Indiglo Gauges
                      Autometer Ultra Lite A/F Gauge
                      Autometer Ultra Lite Boost Gauge
                      Autometer Ultra Lite Oil Pressure Gauge
                      Lo-Tek Full Replacement 3 Gauge A-Pillar
                      Dual 6.5" 3-Way Speakers
                      Exterior:
                      Carbon Creations Carbon Fiber OEM Style Hood
                      Real Sparco Hood Pins
                      Dual "Real" HID Projector Housings / Headlights
                      Ace 5 Spoke 17" Rims in Nexun Rubber (less then 500 miles on them)
                      Replacment Black Convertible Top
                      Clear Bumper Sidemarkers
                      Suspension:
                      Sparco 1.8" Drop Lowering Springs
                      New Rotors and Pads
                      $12000 / obo
                        4AN Stainless Steel Fittings and Hoses
                        PTE 650cc Injectors
                        Injen Intake
                        Apex'i Down Pipe
                        Apex'i 3" Cat-Back
                        Straightline Specialties Intercooler Piping
                        ACT 2600 Clutch
                        S-AFC II
                        3 Gauge A-Pillar
                        Greddy Profec B v.2 Electronic Boost Controller
                        Tein Suspension
                        Excel Rims
                          Stop copying me
                            Jim wrote:
                            Stop copying me
                            you cant copy my times.............slow boy
                              you can keep your times and stay behind me on the freeway foo... frumroll
                                i will frumroll anytime.........
                                  Ok enough whoring it. And now .... back on topic
                                    Do it!!!
                                    • StormwalkerS Offline
                                      Stormwalker
                                      Oh wow, frumrolls have spread here as well.
                                      And Starion/Conquest > *
                                      www.tcstangs.com
                                        tcstangs was here.
                                        Home of the frum roll
                                          legacy-user-544
                                          back on topic please. i dont want a spyder jim, so sorry on that. anybody else got any for sale?
