  4. need input
need input
37 Posts 14 Posters 4.6k Views
  • Y
    Y
    yose
    buy a neon
    My Ride
    • amichezeA
      amichezeA
      coming from a guy who owned one, but probably knows a lot less than most people on here about them.. they CAN be fairly reliable cars if you treat them right. however, most people dont. just keep in mind that if you go racing all over the place, itll break a helluva lot faster.
      just go through the car like you would any other. make sure it shifts well, no fluid leaks, fluids were changed regularly, belts are fine (timing belt should be replaced at 90k miles), etc. make sure you hit boost nicely and there arent any leaks. if you can take it for an afternoon, $30 for a full inspection is one of the best things you can do.
      Fargostreet Trolls wrote:
      i must be stupid
      • legacy-user-544L
        legacy-user-544L
        legacy-user-544
        99slowGSX wrote:
        Buy mine.........
        specs and pics por favor. thanks amicheze for the feedback. anybody else have anything to say?
        • D
          D
          dsmquest
          My advise would be go and buy/rent a compression tester to check the compression, and always check the cv joints for rips or leaks. Anything with less than 100,000 mi is good, i dont know to much about the 420a if a non turbo is what your looking for. Try the many dsm sites if you havent already lots of good info there. Good luck
          1992 Eagle Talon TSI AWD
          1991 Eclipse GST (piecing together)
          1990 Eagle Talon TSI FWD (Parts Car)
          1989 Nissan 240SX (DD)
          1988 Chrysler Conquest TSI (traded)
          1987 Mitsubishi Starion
          • legacy-user-33L
            legacy-user-33L
            legacy-user-33
            My friend at work is selling her silver 99 Eclipse OZ edition for $7,500. Same as a GST, except its n/a, correct me if im wrong..
            -Tin-
            -IS300-Black on Gold-
            • TsiTomT
              TsiTomT
              TsiTom
              DSM's are a love/hate relationship....the 95 and 96 7 bolts are probably prone to problems than any. But if you find a 2g that has a 6 bolt swap then id say your set. Just do some research and be as cautious as you would with buying any car. If you find one thats mildly modified make sure everything is sound. Otherwise good luck!
              Tom Opgrand
              2011 Camry
              • YellowEvoY
                YellowEvoY
                YellowEvo
                Same as a GST but n/a... i'm lost....
                2003 Mitsubishi Evolution 8
                2011 Ford F150 Ecoboost
                • JimJ
                  JimJ
                  OZ edition has the "turbo" wing, side skirts, different rims.... but a 420a motor. $7500 for an OZ edition is a rip off. You should be able to find a fair condition turbo dsm (stock) for that.
                  Buy mine. It will come with a new turbo.
                  Engine:
                  6 Bolt Full 4G63 Motor Swap / Complete Rebuild
                  Bored .020 Over
                  Eagle Rods
                  Ross Pistons 8.5:1
                  ARP Head Studs
                  Metal Headgasket
                  Balance Shaft Eliminator
                  1mm Oversized Stainless Steel Valves
                  1G Intake Manifold
                  Aeromotive Fuel Pressure Regulator
                  Aeromotive FPR Engine Bay Mounted Gauge
                  -6AN Stainless Steel Fittings and Hoses
                  PTE 680cc Injectors
                  Walbro 255lph High Pressure Fuel Pump
                  Ported 2G Manifold (I also have a Stainless Steel Tubular Manifold, but it cracked, have to send it in for Warranty)
                  Bullseye Power T04B 50 Trim Turbo
                  Stainless Steel -AN Oil Return
                  Stainless Steel -AN Oil Feed
                  Straightline Specialties 3" Intake
                  Real K&N Air Filter
                  3" O2 Dump Tube O2 Housing
                  True 3" Down Pipe
                  Apex'i 3" Cat-Back
                  Generic Bar and Plate 31x12x3 Intercooler
                  Straightline Specialties "Backdoor" Intercooler Piping
                  Greddy Type-RS Blow Off Valve
                  Generic Catch Can
                  Shaved and Polished Valve Cover
                  Straightline Specialties Boost Controller
                  Transmission:
                  Double Syncro'd 2nd, 3rd, 4th Gears
                  ACT 2600 Clutch
                  Evo Shift Forks
                  Evo Shift Rails
                  B&M Short Throw Shifter
                  Greddy Counterweight Shift Knob
                  Electronics:
                  S-AFC II
                  Straightline Specialties Vent Bezel
                  Aiwa MP3 Deck
                  Gen. 2 Reverse Indiglo Gauges
                  Autometer Ultra Lite A/F Gauge
                  Autometer Ultra Lite Boost Gauge
                  Autometer Ultra Lite Oil Pressure Gauge
                  Lo-Tek Full Replacement 3 Gauge A-Pillar
                  Dual 6.5" 3-Way Speakers
                  Exterior:
                  Carbon Creations Carbon Fiber OEM Style Hood
                  Real Sparco Hood Pins
                  Dual "Real" HID Projector Housings / Headlights
                  Ace 5 Spoke 17" Rims in Nexun Rubber (less then 500 miles on them)
                  Replacment Black Convertible Top
                  Clear Bumper Sidemarkers
                  Suspension:
                  Sparco 1.8" Drop Lowering Springs
                  New Rotors and Pads
                  $12000 / obo
                  • SmitEvoS
                    SmitEvoS
                    4AN Stainless Steel Fittings and Hoses
                    PTE 650cc Injectors
                    Injen Intake
                    Apex'i Down Pipe
                    Apex'i 3" Cat-Back
                    Straightline Specialties Intercooler Piping
                    ACT 2600 Clutch
                    S-AFC II
                    3 Gauge A-Pillar
                    Greddy Profec B v.2 Electronic Boost Controller
                    Tein Suspension
                    Excel Rims
                    • JimJ
                      JimJ
                      Stop copying me
                      • SmitEvoS
                        SmitEvoS
                        Jim wrote:
                        Stop copying me
                        you cant copy my times.............slow boy
                        • JimJ
                          JimJ
                          you can keep your times and stay behind me on the freeway foo... frumroll
                          • SmitEvoS
                            SmitEvoS
                            i will frumroll anytime.........
                            • JimJ
                              JimJ
                              Ok enough whoring it. And now .... back on topic
                              • MisterCMKM
                                MisterCMKM
                                Do it!!!
                                thrash;315544 wrote:
                                Ford is back :)
                                • StormwalkerS
                                  StormwalkerS
                                  Stormwalker
                                  Oh wow, frumrolls have spread here as well.
                                  And Starion/Conquest > *
                                  www.tcstangs.com
                                  • MisterCMKM
                                    MisterCMKM
                                    tcstangs was here.
                                    Home of the frum roll
                                    Ford is back :)
                                    • legacy-user-544L
                                      legacy-user-544L
                                      legacy-user-544
                                      back on topic please. i dont want a spyder jim, so sorry on that. anybody else got any for sale?
                                      • SmitEvoS
                                        SmitEvoS
                                        Kevin has white eclipse for sale......
                                        • legacy-user-544L
                                          legacy-user-544L
                                          legacy-user-544
                                          thats it? you guys suck or you just arent trying.
