  3. Run Your Mouth
  4. Am I the only one?
Am I the only one?
49 Posts 14 Posters 4.8k Views
    Yes!!!!!!!!!!!!!!!!!!!!!!!!!
      and i find expensive honda swaps pointless...its like spending 3-4 grand for less than 200 flywheel hp...its like my stock dsm makes nearly the same hp and WAY more torqe for FAR less money...and as far as im concerned a stock dsm will last you nearly as long as a honda as long as you treat it right...and beat up the hondas while your at it too hehe!!!
      • harwood39H Offline
        harwood39H Offline
        harwood39
        im on torbs side. too much for no power. if anything put that 3-4k into a nice turbo setup for a d-series and beat a swaped civic.
        2730 5th Ave S. Unit C
        Fargo, ND 58103
        701-429-3686
        • bluejaysB Offline
          bluejaysB Offline
          bluejays
          whatever happend to doing what you want? remember there are more then one way to make a car fast. what is cheaper is also whats done most often. i for one, don't like doing what everyone and their mom are doing. and seriously try making 500 hp on a d series i dare you.
            You can do what you want but if you are on a budget it is not the best way to go. Yeah if you are shitting out $100 bills go ahead then and swap in a $7k K20A then but for the common people it just isn't a great way to go.
            What is the most horsepower a d series has made? Nick is halfway there with a stock block.
            • bluejaysB Offline
              bluejaysB Offline
              bluejays
              i agree, for a broke college/high school student spending thousands of dollars on a swap isn't the way to go. calling it pointless or dumb or a waste of money is a bit ignorant though.
              • darkelvisD Offline
                darkelvisD Offline
                darkelvis
                Bluejays, 500 hp on a D series has been done many times.
                  darkelvisD Offline
                  darkelvis
                  LONG POST AHEAD.......
                  And just because someone is going to be bitchin about proof. Here is a quote from another forum, this is just one 500 hp D series that took me about 2 min. of searching to find:
                  "I'm selling my 1989 CRX Si with a built and turbo'd D16Y8 in it. The setup is TurbodCX's (on honda-tech) old setup. It made 502whp and 370ft lbs of torque on 33psi with race gas. Right now it's running off of the 20psi wastegate spring, and is tuned on 93 oct. pump gas. The car runs great, I've barely driven it since it's been finished, but now I'm heading off to school and just don't have the time or money to put into it any more. I'm looking for trades or money, I spent over 7,000 dollars on the engine and turbo setup alone. PM me with reasonable offers, serious inquiries only
                  Interior:
                  Autometer Boost and Oil Pressure Gauges
                  Mint condition Si seats
                  Only damage to the interior is on the back of the door panels (common in CRX's)
                  Exterior:
                  Just recently painted black
                  15x6.5 Rota Slipstreams
                  205/50/15 BFG's in front
                  195/50/15 Pirelli winter tires in the back
                  Under the Hood:
                  Built D16Y8 with ported and polished head
                  Ferrea Valvetrain
                  Zex Cam
                  Golden Eagle intake manifold
                  ARP Studs
                  Golden Eagle Sleeves
                  75mm Bore
                  Arias 8:1 Forged Pistons
                  Crower Billet Steel Rods
                  ACL Bearings
                  Fully Balanced Bottom End
                  Blue Anodized Under Drive Crank Pulley
                  Drag Exhaust Manifold
                  Tial HP 38mm Wastegate W/ 20psi spring
                  Blowzilla Turbo W/ .70 S Comp. .63 Exhaust
                  3” Down Pipe
                  30x6x3 Spearco intercooler painted black
                  TurboXS blow off valve
                  Clutchspecialties 4 puck sprung clutch
                  Hondata S200B
                  And now to the pics:
                  Note from darkelvis: some exterior pics were removed to not take up as much space. 🙂
                  • bluejaysB Offline
                    bluejaysB Offline
                    bluejays
                    well, i stand corrected, but my point was b series can hold more hp more reliably thats all.
                      darkelvisD Offline
                      darkelvis
                      Not true, a built D will hold up just as well as a built B.
                      Building a honda engine is the same no matter what engine it is.
                      eg: forged internals, upgraded cam, upgraded valvetrain, sleeves.
                      Once a D or B is built they will pretty much take anything that you can throw at them. 🙂
                      The only real difference is the B can flow more CFMs. Which will be able to make it produce more horsepower overall, but every day someone builds a stronger D. Plus D's generally come in lighter cars which makes up for the small ammount of difference with the weight to power ratio.
                        so the only way to go is turbo? ok i guess u can go and tell skunk 2 to quit working on there all-motor 9 sec car.
                          I can see traction being a HUGE problem in that CRX.
                            B series for life. 😉
                            • bluejaysB Offline
                              bluejaysB Offline
                              bluejays
                              agreed
                                darkelvisD Offline
                                darkelvis
                                spoolude, I never said that skunk2 needs to quit, and I never said that turbo is the only way to go. People can do whatever they want with their engines, I am just saying that there isn't a reason to do a B swap when a D can do the same or more for the same ammount of money. Oh yea, and if you are talking about their 9 sec n/a RSX that they just recently unveiled, guess what they built the K that came with the car which has NOTHING to do with swapping engines.
                                Bad93ex (re traction) that is what slicks, traction bars, and an LSD are for. 🙂
                                Underdog for life!!!!
                                  bluejays wrote:
                                  agreed
                                  You dont get it do you?
                                  His car came with a B series.
                                  I was just flipping through the pages of SCC and came across a fine example. Though it is not a B series engine they swapped a H22a into a CRX. Even with intake and exhaust with some fuel management the thing could only muster a 14.1 pass. But wait with nitrous and some slicks it ran a 13.5.
                                  Sport Compact Car,Sept. 2005, Vol. 17 No. 09, pg.94-102
                                    bottom line...... dsm'rs will be hardcore dsm'rs..... honda guys will be hardcore honda guys.......... yes bang for your buck dsm's will win...... but there are trade offs for everything.
                                      darkelvisD Offline
                                      darkelvis
                                      ummmmm, blake, why did dsm's come up in this?
                                      Oh yea, and to those who are reading this, I HATE HONDAS, I just work on them because I know them. 🙂
                                        What did the red 1g in that mag run? Something in their times seems off to me (too high). Bad driver???
                                        • 3_Series3 Offline
                                          3_Series3 Offline
                                          3_Series
                                          im suprised lankordie hasn't chimed in on this one yet
                                          2002 Subaru Legacy
                                          1993 BMW 325i (sold)
