  4. Groshong's front clip has arrived!
29 Posts 15 Posters 1.3k Views
    Gonna do it the right away and actually replace the firewall?
      i've heard weld clip to car
        matts done his research, and decided to go with welding the clip to the car.
        Edit: forgot to mention, he will be paying a body shop to do this.
        • harwood39H Offline
          harwood39H Offline
          harwood39
          thats the way to go.
          2730 5th Ave S. Unit C
          Fargo, ND 58103
          701-429-3686
          • TsiTomT Offline
            TsiTomT Offline
            TsiTom
            nice...
            Tom Opgrand
            2011 Camry
              whos doing the work
                no idea. ask him!
                  A lot of body shops wont section the front end. I had a buddy awhile back whole need the drivers side front sectioned and most body shops wouldn't do it. It'd be a whole hell of a lot easier to replace the firewall.
                    i'll get him to explain it when he gets on here... he's already been quoted for it and has prepared to pay someone to do it... so i think he will stay that route
                    • darkelvisD Offline
                      darkelvisD Offline
                      darkelvis
                      The right way to do it would be to gut the car, brace it, drill out the spot welds on the firewall, do a firewall swap, then put everything back in. Cutting a car in half then putting a different half on is dangerous as hell.
                        Honestly the only problem I forsee is that the welds would be too tough, and would allow enough flew and preak something in a different part of the vehicle while cornering hard....
                        taken off of honda-tech
                        "I've thought for hours and so no reason why someone would want to do this other than to be a biter and a fad follower, but.....
                        Just clip the car, buy a JDM front clip with windshield pillars and front floor. Have a GOOD body shop clip the car just like they would a totaled CRX. Probably 20% of the people on this board are driving CRXs that have had front clips welded on and they don't know it. Its a common practice in the body world. What they will do is cut the floor somwhere probably around where your feat go (I'd guess there is a seam somwhere in there but really can't remember) and cut the A-pillar. They'll put a sleeve in the A pillar, slide the new clip on to that sleeve to make a stronger a pillar, and weld the new floor on. It will be as stong as new if not stronger. Unfortunately you'll be stuck with a car that looks like it should belong to a mail man or a stunna."
                          clipping a car is NOT a common practice in the body world!!!! It is NOT as strong if not stronger!!! You should find out who is going to do this, I am not the only one who is a bit curious.
                          • 9 Offline
                            9 Offline
                            92TSIpos
                            wouldnt the firewall swap be a little easier?
                              darkelvisD Offline
                              darkelvis
                              And Safer
                              • tntmstrT Offline
                                tntmstrT Offline
                                tntmstr
                                A bit off topic, but pimp my ride didn't like the clipped idea on an escort.... I just hope that we won't see groshong driving a Scion with a huge wing after all is said and done. 🙂 🙂 Best of luck on the swap, and mad props on trying something different... I hope it all works out safely and fully functional!!
                                Jason
                                Jason Christopherson
                                Store Manager
                                Tintmasters
                                Fargo, ND (701)239-TINT
                                www.tintmasters.net
                                  Jason
                                  That had something to do with only 9 little welds and a bunch of liquid nails holding the car together though...... I think he'll do better than that.
                                    darkelvisD Offline
                                    darkelvis
                                    Jason
                                    Speaking of that, there are now exact replicas (except smaller of course) of that scion sitting at wal-mart in the car toys isle. MTV has started making "Pimp My Ride" RC cars.
                                    Ok, back on topic.
                                    • tntmstrT Offline
                                      tntmstrT Offline
                                      tntmstr
                                      I sure hope he would do better.... It was just the first thing that came to mind when I read about welding the clip to the car....
                                      I have faith!
                                      Jason
                                      Store Manager
                                      Tintmasters
                                      www.tintmasters.net
                                        bomexcivic00
                                        This is matt posting on justin's name. I have done alot of research on this subject I have decided to more than likely clip the car but i have found some rust spots that are pretty bad so i might just firewall swap but the car needs a new front radiator support/headlight housing and drivers side panal above the front wheel. Just to clarify for you guys doubting me this is safe and very posable to do right. also be for you start the uninformed hating you sould take a look at Fallguy's car to see what he has done. (welding susp. parts on a unibody is bad HMMMM...). I hate to be a dick but you guys only say shit because i'm not some idolized tuner like dave or fallguy (no offence guys just the truth). and dark elvis what do you know about body work??? so if anybody comes up with something constructive to say please post.
                                        Ground Assault
                                        00' Honda Civic Si
                                        91' Nissan 240sx
                                        • TsiTomT Offline
                                          TsiTomT Offline
                                          TsiTom
                                          Best of luck to ya! Cant wait to see it when its finished! 🆒
                                          Tom Opgrand
                                          2011 Camry
