  4. Groshong's front clip has arrived!
29 Posts 15 Posters 1.3k Views
    i've heard weld clip to car
      matts done his research, and decided to go with welding the clip to the car.
      Edit: forgot to mention, he will be paying a body shop to do this.
      • harwood39H Offline
        harwood39H Offline
        harwood39
        thats the way to go.
        2730 5th Ave S. Unit C
        Fargo, ND 58103
        701-429-3686
        • TsiTomT Offline
          TsiTomT Offline
          TsiTom
          nice...
          Tom Opgrand
          2011 Camry
            whos doing the work
              no idea. ask him!
                A lot of body shops wont section the front end. I had a buddy awhile back whole need the drivers side front sectioned and most body shops wouldn't do it. It'd be a whole hell of a lot easier to replace the firewall.
                  i'll get him to explain it when he gets on here... he's already been quoted for it and has prepared to pay someone to do it... so i think he will stay that route
                  • darkelvisD Offline
                    darkelvisD Offline
                    darkelvis
                    The right way to do it would be to gut the car, brace it, drill out the spot welds on the firewall, do a firewall swap, then put everything back in. Cutting a car in half then putting a different half on is dangerous as hell.
                      Honestly the only problem I forsee is that the welds would be too tough, and would allow enough flew and preak something in a different part of the vehicle while cornering hard....
                      taken off of honda-tech
                      "I've thought for hours and so no reason why someone would want to do this other than to be a biter and a fad follower, but.....
                      Just clip the car, buy a JDM front clip with windshield pillars and front floor. Have a GOOD body shop clip the car just like they would a totaled CRX. Probably 20% of the people on this board are driving CRXs that have had front clips welded on and they don't know it. Its a common practice in the body world. What they will do is cut the floor somwhere probably around where your feat go (I'd guess there is a seam somwhere in there but really can't remember) and cut the A-pillar. They'll put a sleeve in the A pillar, slide the new clip on to that sleeve to make a stronger a pillar, and weld the new floor on. It will be as stong as new if not stronger. Unfortunately you'll be stuck with a car that looks like it should belong to a mail man or a stunna."
                        clipping a car is NOT a common practice in the body world!!!! It is NOT as strong if not stronger!!! You should find out who is going to do this, I am not the only one who is a bit curious.
                        • 9 Offline
                          9 Offline
                          92TSIpos
                          wouldnt the firewall swap be a little easier?
                            darkelvisD Offline
                            darkelvis
                            And Safer
                            • tntmstrT Offline
                              tntmstrT Offline
                              tntmstr
                              A bit off topic, but pimp my ride didn't like the clipped idea on an escort.... I just hope that we won't see groshong driving a Scion with a huge wing after all is said and done. 🙂 🙂 Best of luck on the swap, and mad props on trying something different... I hope it all works out safely and fully functional!!
                              Jason
                              Jason Christopherson
                              Store Manager
                              Tintmasters
                              Fargo, ND (701)239-TINT
                              www.tintmasters.net
                                Jason
                                That had something to do with only 9 little welds and a bunch of liquid nails holding the car together though...... I think he'll do better than that.
                                  darkelvisD Offline
                                  darkelvis
                                  Jason
                                  Speaking of that, there are now exact replicas (except smaller of course) of that scion sitting at wal-mart in the car toys isle. MTV has started making "Pimp My Ride" RC cars.
                                  Ok, back on topic.
                                  • tntmstrT Offline
                                    tntmstrT Offline
                                    tntmstr
                                    I sure hope he would do better.... It was just the first thing that came to mind when I read about welding the clip to the car....
                                    I have faith!
                                    Jason
                                    Store Manager
                                    Tintmasters
                                    www.tintmasters.net
                                      bomexcivic00
                                      This is matt posting on justin's name. I have done alot of research on this subject I have decided to more than likely clip the car but i have found some rust spots that are pretty bad so i might just firewall swap but the car needs a new front radiator support/headlight housing and drivers side panal above the front wheel. Just to clarify for you guys doubting me this is safe and very posable to do right. also be for you start the uninformed hating you sould take a look at Fallguy's car to see what he has done. (welding susp. parts on a unibody is bad HMMMM...). I hate to be a dick but you guys only say shit because i'm not some idolized tuner like dave or fallguy (no offence guys just the truth). and dark elvis what do you know about body work??? so if anybody comes up with something constructive to say please post.
                                      Ground Assault
                                      00' Honda Civic Si
                                      91' Nissan 240sx
                                      • TsiTomT Offline
                                        TsiTomT Offline
                                        TsiTom
                                        Best of luck to ya! Cant wait to see it when its finished! 🆒
                                        Tom Opgrand
                                        2011 Camry
                                          darkelvisD Offline
                                          darkelvis
                                          Don't get mad at me, I am just saying that logically, when you cut a car in half you trash it's structural integrity. I'm not trying to be a dick, I'm just saying that for safety sake, do the firewall swap.
