  4. My toys are on their way!!!!
26 Posts 12 Posters 1.1k Views
    you should get one of the AWD civic wagon's that would be P I M P!...
    • 91nbtsi9 Offline
      91nbtsi9 Offline
      I hate secret projects..like it matters anyways! Everyone is going to know what it is sooner or later.
        matt has a Clean ass racing hatch for sale, already stripped. EF. red.... 3k
        • darkelvisD Offline
          darkelvisD Offline
          darkelvis
          too much, and I want a 92-95
            darkelvisD Offline
            darkelvis
            Bump, its here. 🙂
            legacy image legacy image legacy image legacy image
              what size/brand wastegate do you plan on running. What BOV will you be running?
                darkelvisD Offline
                darkelvis
                Tial 38 mm. Greddy type s or rs
                  run rs, if you plan on flowing that much, that will be your best bet. plus I think it sounds a little cooler
                    darkelvisD Offline
                    darkelvis
                    the type S is capable of holding 20 psi before it leaks, and it is cheaper (if i can still find one when i need it)
                      Greddy doesn't make the Type S anymore... Type RS replaced it
                        My Type S has never leaked above 20 psi. It has seen 30+ psi before as well.
                          darkelvisD Offline
                          darkelvis
                          I know, which is why I said I'll use one if I can find one when I need it.
                          gsr-I've heard different people have different results above the 20 psi mark, some leak some don't. I'm assuming that it is user error on the ones that leak. 🙂
                            most of the DSM guys use em without problems too..kevin ran what 30+psi on his?
                            • TsiTomT Offline
                              TsiTomT Offline
                              TsiTom
                              20psi on mine...not that I get it that high very often....but it holds without a problem 🙂
                              Tom Opgrand
                              2011 Camry
