  4. My toys are on their way!!!!
26 Posts 12 Posters 1.1k Views
    matt has a Clean ass racing hatch for sale, already stripped. EF. red.... 3k
    • darkelvisD Offline
      darkelvisD Offline
      darkelvis
      too much, and I want a 92-95
        darkelvisD Offline
        darkelvis
        Bump, its here. 🙂
        legacy image legacy image legacy image legacy image
          what size/brand wastegate do you plan on running. What BOV will you be running?
            darkelvisD Offline
            darkelvis
            Tial 38 mm. Greddy type s or rs
              run rs, if you plan on flowing that much, that will be your best bet. plus I think it sounds a little cooler
                darkelvisD Offline
                darkelvis
                the type S is capable of holding 20 psi before it leaks, and it is cheaper (if i can still find one when i need it)
                  Greddy doesn't make the Type S anymore... Type RS replaced it
                    My Type S has never leaked above 20 psi. It has seen 30+ psi before as well.
                      darkelvisD Offline
                      darkelvis
                      I know, which is why I said I'll use one if I can find one when I need it.
                      gsr-I've heard different people have different results above the 20 psi mark, some leak some don't. I'm assuming that it is user error on the ones that leak. 🙂
                        most of the DSM guys use em without problems too..kevin ran what 30+psi on his?
                        • TsiTomT Offline
                          TsiTomT Offline
                          TsiTom
                          20psi on mine...not that I get it that high very often....but it holds without a problem 🙂
                          Tom Opgrand
                          2011 Camry
