  4. My toys are on their way!!!!
26 Posts 12 Posters 1.3k Views
  • darkelvisD Offline
    darkelvisD Offline
    darkelvis
    Bump, its here. 🙂
    legacy image legacy image legacy image legacy image
      what size/brand wastegate do you plan on running. What BOV will you be running?
        darkelvisD Offline
        darkelvis
        Tial 38 mm. Greddy type s or rs
          run rs, if you plan on flowing that much, that will be your best bet. plus I think it sounds a little cooler
            darkelvisD Offline
            darkelvis
            the type S is capable of holding 20 psi before it leaks, and it is cheaper (if i can still find one when i need it)
              Greddy doesn't make the Type S anymore... Type RS replaced it
                My Type S has never leaked above 20 psi. It has seen 30+ psi before as well.
                  darkelvisD Offline
                  darkelvis
                  I know, which is why I said I'll use one if I can find one when I need it.
                  gsr-I've heard different people have different results above the 20 psi mark, some leak some don't. I'm assuming that it is user error on the ones that leak. 🙂
                    most of the DSM guys use em without problems too..kevin ran what 30+psi on his?
                    • TsiTomT Offline
                      TsiTomT Offline
                      TsiTom
                      20psi on mine...not that I get it that high very often....but it holds without a problem 🙂
                      Tom Opgrand
                      2011 Camry
