  4. Router/Switch
Router/Switch
19 Posts 10 Posters 1.4k Views
  • StangerBanger96S
    StangerBanger96S
    StangerBanger96
    alright sounds good i figured a router would do it but wasnt sure. Any comments on why specs on routers say "wireless router with 4port switch" though? I dont know much about networking stuff so to me that just says its a switch with wireless capabilities and i dunno.......it says router but describes the wired ports as switches. thanks again
    • integra_gsr98I
      integra_gsr98I
      A wireless router w/ 4 port switch means that the device IS a router, but that it also has a switch built into it. The "wireless" means that it has an access point built into it as well.
      • T
        T
        toxshox
        Router: A piece of hardware that acts kinda like a stand alone computer. It uses one internet ip address when hooked directly to the modem. To the internet company, if they are stupid, it will look like one computer. From the router there are usually at a minimum 4 connections to hook other computers up to. These 4 connections are part of your local network and have addresses such as 192.168.XXX.XXX. Your computers will share the router to access the internet using these different local addresses. You need to set up the router to access the internet just like you did with the computers you had set up already(or manually set it up if you had the computers previousely set up automatically). Then the computers you have hooked into it will need to be setup automatically...depending on the type and brand of router you get. When you buy the router, get one with a firewall...otherwise people can hack your network and get into your computers.
        Switch: A unit used for expanding a network that is already in place, such as behind a router.
        Your network should be like this.
        Modem -> Firewall/Router -> then switches -> computers
        Don't get confused...the router should have a switch built in. This is because otherwise it would only have one connection on back that would require the end user to also buy a switch. For the sake of simplicity and to no confuse the end user further, they have incorportated a firewall, router , and switch in one unit. They are hooked up internally like this.
        modem connection in -> firewall -> router -> switch -> 4 connections out
        I hope that helps ... probably confused ya more now.
        • jct_4628J
          jct_4628J
          jct_4628
          If your on the slower connection from my experience they dont allow routers. You have to be on the faster connection for them to work. That could have changed though.
          Jason
          -06 WRX
          -95 CBR 600F3
          701-541-2568
          • JimJ
            JimJ
            The connection speed has nothing to do w/ if your able to use a router or not... if you really wanted you could route a 56k modem connection...
            • StangerBanger96S
              StangerBanger96S
              StangerBanger96
              im on the fastest connection
              So would:
              http://www.bestbuy.com/site/olspage.jsp?skuId=5250774&productCategoryId=pcmcat25300050001&type=product&cmp=++&id=1051384663529
              solve my problem (hopefully?)
              • TakeYourTopOffT
                TakeYourTopOffT
                TakeYourTopOff
                if you want a wireless router I have one i was going to put on ebay but i'll sell it to you for 10 bucks
                it's a dlink b has a 4 port swicth of corse built in firewall
                I wouldn't run broadband without a router/firewall if i had the money i'd run a dedicated firewall into a router any questions on it just ask
                legacy image legacy image
                Personal Web Site
                • PSiedTSiP
                  PSiedTSiP
                  So would:
                  same router i have and love it...ive had 4 wireless routers...1 actiontec, 1 d-link, and 2 linksys routers and im still running my linksys 🙂
                  spanish-rice;237125 wrote:
                  • T
                    T
                    toxshox
                    So would:
                    solve my problem (hopefully?)Looks like a good one to me too...
                    • JimJ
                      JimJ
                      Just don't buy D-Link... I've never had anything good come from D-Link... out of the cheaper brands, I like Netgear and Linksys the most....
                      • PSiedTSiP
                        PSiedTSiP
                        i hated netgear the most...it seemed like it always dropped connection and had HORRIBLE range...
                        • TakeYourTopOffT
                          TakeYourTopOffT
                          TakeYourTopOff
                          LMAO I have had the opposite luck D-Link has rocked adn Linksys sucked big time... only reason i have an extra won is i upgraded to the d-link extreme g wireless
                          Personal Web Site
