  4. Engine rebuild kit
Engine rebuild kit
21 Posts 9 Posters 697 Views
    are your pistons scored, or your cylinder walls messed up?
    • harwood39H Offline
      harwood39H Offline
      harwood39
      im just going to replace everything since it will be apart, i havent cracked it open yet besides the pan. with the amount of small shavings throughout the motor its prolly all fucked.
      2730 5th Ave S. Unit C
      Fargo, ND 58103
      701-429-3686
        harwood39H Offline
        harwood39
        oh, also found out the rear seal was going bad cause there was a small amount of oil covering the flywheel and flywheel cover.
        Fargo, ND 58103
        701-429-3686
          so first a motor swap...now a reuibld....this is going to go on forever!!! damn
            spend the extra dough and build it..
              go b-series so i can buy your head!!!!!!!!!
              • ticklemedalyT Offline
                ticklemedaly
                I have nothing against hondas D16Z6 motor, loved mine, but they arn't potent enough. Get a B18C motor, you wont regret it, plus the cost of building your Z6 will be up there in the range of a good used B18 motor. If you dont take my advice, Quality Engine does a great job at motor work. Id take it to them for the whole setup, theyll even order the parts you would need after they determine what damage is done.
                Ryan
                XBL G-tag: TickleMeDaly83
                  in no possible way will a rebuild on his block cost what a b18c1 motor will.
                    ticklemedaly
                    let see.....500-800 in parts for parts, plus labor to R&R the motor, then any additional parts that need/want to be removed, then the cost of taking the motor in to have it rebuild....Id say it is up there....NOW, if you do the work yourself, then of course there is no way itll run that high.....but, how many motors has he rebuilt hisself, and does he have access to easily have the motor R&R'd? I dont know, Im just talking from myself as a professional technician point of view.
                    Ryan
                      b18c1 swaps are 3200 bucks.
                        aliengotpsi
                        i'll sell you my Z6 for $1000.00 proven to go fast....
                        Kevin Smith
                        Straightlinedetailing.com
                          harwood39H Offline
                          harwood39
                          no thanks guys, im doing this cause its cheaper than a swap and i need my car moving ASAP. I am assembling the motor my self, but i am taking it to quality to get the crank done and cylanders honed. There shouldnt be anything else needed since im not tearing apart the head, im just pulling the head off and leaving that the way it is. Than later im going to buy another Z6 to build, already have one lined up. And just a normal rebuild would never cost the same as a B18C swap. Unless i were to fully build the motor, than it would.
                          Kevin, I would buy your motor if it was cheaper, cause a grand for just a motor is too much in my opinion.
                          Fargo, ND 58103
                          701-429-3686
                            harwood39H Offline
                            harwood39
                            OH, and the swap i was going to buy needs a complete rebuild too so its pointless. I would spend the extra dough to build my motor also, but i only have like a month to get it moving. And i cant come up with that kind of money that quick.
                            Fargo, ND 58103
                            701-429-3686
                              ticklemedaly
                              Ya, i know, and completely rebuilding this motor according to all data is 23.3 hours of rebuild, then another 7.7 hours of R&Ring it. Then add on the cost of parts.....
                              $1864 to rebuild, $616 to R&R it, then another $500-$800 for parts. So anotherwords, your looking at the cost of a swap.....BUT since harwood is going to do it himself, well, I dont know how much he trusts his own work in it, but hell be looking at machining costs and parts, which will be a lot cheaper, but there will be no warrenty with it then.
                              Ryan
                                harwood39H Offline
                                harwood39
                                i trust my work on assembling it, the hardest thing with motors in my opinion is valve adjustments, but that was just done and im not tearing the valve train apart at all. I have a shop manual for the torque specs and i have a budy that is a tech at the honda dealer that is helping me. Assembly is pretty basic.
                                Also i have done a couple V8's in shop and small engines(motorcycle, dirt bike, lawn mowers) and i know they are different than my motor but basic assembly is the same.
                                Fargo, ND 58103
                                701-429-3686
                                • YellowEvoY Offline
                                  YellowEvoY Offline
                                  YellowEvo
                                  ok i'll take 900.00
                                  2003 Mitsubishi Evolution 8
                                  2011 Ford F150 Ecoboost
                                    harwood39H Offline
                                    harwood39
                                    Honestly kevin, if it came with everything(tranny, motor, ecu) I would consider it.
                                    Fargo, ND 58103
                                    701-429-3686
                                      YellowEvoY Offline
                                      YellowEvo
                                      how much would you give me for a Y8 Engine>?
                                      • darkelvisD Offline
                                        darkelvisD Offline
                                        darkelvis
                                        I'm going to need some Y8 parts in the near future if you are serious about getting rid of them. 🙂
                                          harwood39H Offline
                                          harwood39
                                          honestly i dont know how much a sohc motor is worth, i know they go for about 500 on HT and ebay for a good one. (thats just the motor)
                                          Fargo, ND 58103
                                          701-429-3686
