  4. Why Miatas?
Why Miatas?
54 Posts 18 Posters 2.0k Views
  • harwood39H Offline
    harwood39H Offline
    harwood39
    ive been in my car, which has a somewhat good suspension(at least the stiffening) now im not saying its top of the line but my car handles awsome. I have also beenin kyles red hatch, and that thing is fricken awsome(omni coils and dampers, pasword 3 point front bar, really good sway bars, lower tie bars, rear strut bar) and its insane.
    also frieteg and some others can vouch for my handling, 93civ is one fo those.
    2730 5th Ave S. Unit C
    Fargo, ND 58103
    701-429-3686
      And it needs all that to try and compete with a Miata in next to stock form. It's an impressive mod list. But you are still failing to grasp the big picture of how much a fwd is at a disadvantage compared to a rwd platform. Noone and I mean NOONE buys a Civic or any other fwd for that matter (modded or not) because of their handling prowess. But that is one of the reasons that the people that like Miata's own or want one.
        harwood39H Offline
        harwood39
        God damnit, now im starting to lean towards a miata if they are that nice. Cause either way, if i stick with my civic(most likely will) its not going to be a good daily driver. Its mostly going to be for track use. But if i could save money with selling my car and picking up a cheap used miata and not need to put all my money into suspension like i do with my car this winter, that may be a better choice for me.
        Fargo, ND 58103
        701-429-3686
          Ther's no such thing as a cheap used Miata. I got mine for relatively cheap. But I had to go to Chicago to get it. And it needs body work. And modding a Civic is far cheaper to boot. Stick with the Civic. Trust me. You can afford that. Besides I like being different than most other people and like that I'm one of the only people I know under 50 that has one.
            harwood39H Offline
            harwood39
            haha, ya i wouldnt want to step on your toes by getting one. And there are plenty in the cities that are under 4500. But anyways, my work thats getting done this winter isnt cheap, its going to cost me all the money i make to finish what i want to get done before the end of the school year. But i wont say what it is cause everyone will just flame me for it.
            Fargo, ND 58103
            701-429-3686
              Now this looks like fun and would be fun to do. I'd have to get another one to do this to though.
                And I didn't say that youd be stepping on my toes. I just like being a little different from everybody else. That's why I didn't buy a Civic and that's why I got out of DSM's
                  harwood39H Offline
                  harwood39
                  Thats my goal with the civic. thats another reason why im sticking with the d-series, you dont need tons of power to road race, and d-series are cheap to fix.
                  Anyways, I guess for shits i will thow up what i am doing to my car before spring(end of may)
                  P29 Pistons(pistons out of a d16a6)
                  ACL Bearings
                  Exedy Stage 1 clutch
                  Road race shifter
                  FAL Flexite rear 3 windows
                  Lexan Sunroof Plug
                  Lexan Roll downs
                  Falken Azenis tires
                  D2 full Coil Overs w/ 36 way adjustable dampers
                  Roll Cage
                  CF trunk lid
                  CF gas door
                  Password 3 Point Front Bar
                  C-Piller bar
                  Trunk Floor bar
                  Sparco Speed seats
                  Harnesses
                  Powerstop Drilled/Slotted Front Rotors
                  EBC brake pads
                  Rear lower Tie bar
                  Eibach Sway bars
                  Energy supsension poly bushings
                  Billet motor mounts
                  Password Front Subframe support
                  Greddy catch can(need due to removed PCV system)
                  Front lower h-brace
                  RSR GTII Cat back exhaust
                  Resonated test pipe
                  ARC Intake
                  Aluminum radiator
                  Road race shifter
                  Omni Clutch master cyl.
                  SS Braded brake lines
                  SS clutch line
                  Road Race Gear Front lip/splitter
                  J-s racing cf air duct
                  Skunk2 Upper front control arms
                  Skunk2 rear lower arms
                  Skunk2 upper rear arms
                  Remove the rest of the interior besides door panels and dash
                  Thats why this winter is going to be expensive, family is buying me parts for my b-day and x-mas, and all my money is going into it.
                  Fargo, ND 58103
                  701-429-3686
                    weshole wrote:
                    Harwood I'll let you drive mine and you'll see why. A Civic is a FUCKIN plow compared to a Miata. It's easier to give the Miata more power than it is to make a civic handle like a Miata. Heck, even the SCCA has a class just for the miata. (spec, miata). Now I'm not flaming on a Civic either. In fact, I like em alot but there's absolutely no way a fwd is gonna outhandle a rwd. (within reason). Did I mention that my car (fully dressed) weighs in at 2100lbs?
                    Can I drive it? I'd even make a special trip to Fergus just to do that!
                      What's it worth to ya?
                        ACL Bearings
                        Road race shifter
                        Lexan Sunroof Plug
                        Lexan Roll downs
                        Falken Azenis tires
                        Roll Cage
                        CF trunk lid
                        CF gas door
                        C-Piller bar
                        Trunk Floor bar
                        Sparco Speed seats
                        Harnesses
                        EBC brake pads
                        Rear lower Tie bar
                        Eibach Sway bars
                        Billet motor mounts
                        Front lower h-brace
                        Resonated test pipe
                        ARC Intake
                        Aluminum radiator
                        Road race shifter
                        SS clutch line
                        Isn't it about that time to make a Civic for sale thread again?
                        It's almost been 20 days
                        • Sweet-WRX-LovinS Offline
                          Sweet-WRX-Lovin
                          RWD + Low Center of Gravity + Short Wheel Base + Lightweight = Street Legal GoKart.
                          One time...
                            You forgot to mention a rather excellent CHASSIS!
                              Dont forget the eyebrows
                              • JohnWJ Offline
                                JohnWJ Offline
                                JohnW
                                sorry.. just reminded me of this.
                                90 Civic DX hatch
                                D16a6/y8 mini me
                                  Nice!
                                    harwood39H Offline
                                    harwood39
                                    I agree with the gokart thing, Miatas remind me so much of gokarts, oh wait they are, just very fast go karts. haha
                                    Fargo, ND 58103
                                    701-429-3686
                                      I dunno, people buy Mini Cooper S's for that reason wes.
                                        God DAMNIT! YOUR RIGHT! I retract that statement. Partially.
                                        • LT1L Offline
                                          LT1L Offline
                                          LT1
                                          it was fun driftin in ur car Wes, hahaha....Kirk almost peed his pants.
