  4. look what UPS dropped off....
42 Posts 13 Posters 2.0k Views
    Nice! Wet? What shot you gonna run? 150?
    • camzaro28C Offline
      camzaro28C Offline
      camzaro28
      100 for now. 150 only at the track once i get fuel pump in.
      i need tires b4 i even hook it up. so that wont be till next year
      jig 4 prez
      • ErikE Offline
        ErikE Offline
        Erik
        Better make that two of 'em. The big ones.
        They call me, old man...
        • sitn2loS Offline
          sitn2loS Offline
          sitn2lo
          99slowGSX wrote:
          Holy Crap, He Has Nos!!!!!!!!111!!!!
          what he said.. 😄
          Yukon Denali on 22's
          • krzydrftr93K Offline
            krzydrftr93
            We're all screwed now!!! 🙂
            Matt
            92 Civic HB
            JDM d15b w/14b@8psi
            • 9 Offline
              9 Offline
              97lt1
              Now you are going to be in the 12's. If you need any help just give me a call.
              • 94NDTA9 Offline
                94NDTA9 Offline
                Coppy Cat.
                I'll let you use my slicks again, you'll need them.
                  camzaro28C Offline
                  camzaro28
                  i have to buy new tires anyway, so i just gonna buy some bfg's d/r. and some decent tires for the front. but if they dont hold up, ill take u up on that offer
                  jig 4 prez
                    I will still beat you:p
                      camzaro28C Offline
                      camzaro28
                      we'll have to see :eek: , but i doubt u will
                      jig 4 prez
                        That should be a good race. 99slowgsx, you don't want to get beat by a V8, do you? 😄
                          one turbo away honey......:)
                          • 9 Offline
                            9 Offline
                            97lt1
                            You could also borrow my tires too if you needed to.
                            • 94NDTA9 Offline
                              94NDTA9 Offline
                              I thought you were spinning big time at the track....
                              • 94NDTA9 Offline
                                94NDTA9 Offline
                                next spring, I would like to line up with you. I think it would be pretty even steven.
                                  I heard your pretty quick.......my only chance may be from a dig.
                                  • 94NDTA9 Offline
                                    94NDTA9 Offline
                                    I would want to do it at the track. I should hook up pretty good, but I havn't run my combo at the track, so who knows how it will do. I'm just looking for some people level with where I'm at.
                                    Brian and I should line up too.
                                    • 9 Offline
                                      9 Offline
                                      97lt1
                                      That's because I need to fix one of the valve stems. One of the valve stems was to far into the rim and I couldn't add any air to it (it was at like 14 psi). I think I would of hooked better if they were both at about 18 psi. I guess I will find out next year.
                                      • 9 Offline
                                        9 Offline
                                        97lt1
                                        What combo are you running. I thought you just had exhaust.
                                        • 94NDTA9 Offline
                                          94NDTA9 Offline
                                          CPT race tranny, 2800 Tq converter with m extra high 2.2 STR designed for nitrous, Denny nitrous drive shaft, Strange 12 bolt, Long tubes, CAI, MAllory 658 hiFireexhaust NX 150 shot, racetronix 255, QA1 adjustable suspension, front and back, chrome moly spohn components (LCA's, Panhard) LCA relocation brackets, subframe connectors. It should hook like no ones business. Not all of this is here, or installed, but it WILL be done. I'm aiming to dip into the 11's. 11.5 would keep me happy, and that will be my goal using only the 150 shot. I plan to launch it hard, because my drivetrain is more than built enough to take it.
                                          I'm not doing H/C this year, I will save up for an AFR stroker over next year or two, then maybe a nice DP set up withing 3 years.
