  4. look what UPS dropped off....
42 Posts 13 Posters 2.0k Views
  • ErikE Offline
    ErikE Offline
    Erik
    Better make that two of 'em. The big ones.
    They call me, old man...
    • sitn2loS Offline
      sitn2loS Offline
      sitn2lo
      99slowGSX wrote:
      Holy Crap, He Has Nos!!!!!!!!111!!!!
      what he said.. 😄
      Yukon Denali on 22's
      • krzydrftr93K Offline
        krzydrftr93
        We're all screwed now!!! 🙂
        Matt
        92 Civic HB
        JDM d15b w/14b@8psi
        • 9 Offline
          9 Offline
          97lt1
          Now you are going to be in the 12's. If you need any help just give me a call.
          • 94NDTA9 Offline
            94NDTA9 Offline
            Coppy Cat.
            I'll let you use my slicks again, you'll need them.
            • camzaro28C Offline
              camzaro28C Offline
              camzaro28
              i have to buy new tires anyway, so i just gonna buy some bfg's d/r. and some decent tires for the front. but if they dont hold up, ill take u up on that offer
              jig 4 prez
                I will still beat you:p
                  camzaro28C Offline
                  camzaro28
                  we'll have to see :eek: , but i doubt u will
                  jig 4 prez
                    That should be a good race. 99slowgsx, you don't want to get beat by a V8, do you? 😄
                      one turbo away honey......:)
                      • 9 Offline
                        9 Offline
                        97lt1
                        You could also borrow my tires too if you needed to.
                        • 94NDTA9 Offline
                          94NDTA9 Offline
                          I thought you were spinning big time at the track....
                          • 94NDTA9 Offline
                            94NDTA9 Offline
                            next spring, I would like to line up with you. I think it would be pretty even steven.
                              I heard your pretty quick.......my only chance may be from a dig.
                              • 94NDTA9 Offline
                                94NDTA9 Offline
                                I would want to do it at the track. I should hook up pretty good, but I havn't run my combo at the track, so who knows how it will do. I'm just looking for some people level with where I'm at.
                                Brian and I should line up too.
                                • 9 Offline
                                  9 Offline
                                  97lt1
                                  That's because I need to fix one of the valve stems. One of the valve stems was to far into the rim and I couldn't add any air to it (it was at like 14 psi). I think I would of hooked better if they were both at about 18 psi. I guess I will find out next year.
                                  • 9 Offline
                                    9 Offline
                                    97lt1
                                    What combo are you running. I thought you just had exhaust.
                                    • 94NDTA9 Offline
                                      94NDTA9 Offline
                                      CPT race tranny, 2800 Tq converter with m extra high 2.2 STR designed for nitrous, Denny nitrous drive shaft, Strange 12 bolt, Long tubes, CAI, MAllory 658 hiFireexhaust NX 150 shot, racetronix 255, QA1 adjustable suspension, front and back, chrome moly spohn components (LCA's, Panhard) LCA relocation brackets, subframe connectors. It should hook like no ones business. Not all of this is here, or installed, but it WILL be done. I'm aiming to dip into the 11's. 11.5 would keep me happy, and that will be my goal using only the 150 shot. I plan to launch it hard, because my drivetrain is more than built enough to take it.
                                      I'm not doing H/C this year, I will save up for an AFR stroker over next year or two, then maybe a nice DP set up withing 3 years.
                                      • 9 Offline
                                        9 Offline
                                        97lt1
                                        This winter I will be doing gears and CAI and maybe a electric waterpump. I'm going for 12's.
                                        • 94NDTA9 Offline
                                          94NDTA9 Offline
                                          Sorry, I forgot EWP and 3.73 gears in the 12 bolt.
                                          Is yours an auto? I think you will have trouble ithout a stall.
