  3. Gaming
  4. Battlefield 2
Battlefield 2
44 Posts 8 Posters 4.2k Views
  • amichezeA
    amichezeA
    out there wrote:
    would you laugh if you read: "there are 10 kinds of people in this world, those who understand binary and those who don't"?
    i didnt get it at first... but then i burst out laughing. thats a good one.
    Fargostreet Trolls wrote:
    i must be stupid
      Extremely stupid questions have been omitted. People think there smart when they got A+.......you can get it out of a cracker jack box now.
      1 - Ok first off, WHICH generation of athlons, slot, socket base, Prescott core Intel Pentiums etc. IN general the Athlons run less core voltage then that of the Intel brethern. However Palomino cores (because of a long pipe line branch predicting tree, FAS support and 1.7 core voltage) did run less then that of even the barton cores.
      2- Synchro Dynamic Random Access Memory
      3- - Another stupid question.
      4- Integrated Disk Electronics, or in current generation (exception of SATA standrard) EIDE - platform introduced by IBM to eliminate the bottlenecks of the constricted ISA bus that was originally used for devices such as Hard Drives, Optical Drives etc.
      5- See above
      6 - Cathode Ray Tube
      7 - Base 2 Mathetmatic system that all computers are based of, in contrast to our base 10 math of numbers 0-9, Binary utilizes a base 2 mathematic scale of 0 and 1, along with the conjunction of standard IEEE form programming standard AND IF OR BUT NOR, etc.
      well lets figure it out, pretty easy to do binary, understand once again it is a base 2 system that factors down, so each number with a designated "1" would represent that value, in orders like so....also mind you that this is a factoring scale, remember to right to left not the traditional left to right.
      1,2,4,8,16,32,64,128,256,512,1024, and therefore
      and in your very old lame joke 10 would = in binary language = 0+2 = 2.
      7 - Internet Protocol
      8 - A "smart switch" that has the ability to direct and designate packets over a TCP/IP network - also with the capability of packet collision detection. Able to utilize varying LAN IP's to designate 1 WAN IP.
      9 - Directs traffic LAN only - with packet collision technique, able to be "smart" enough to direct which pakcets should go where using redundancy techniques.
      10 - same thing as switch, except sends packets out to each unit simutaneously.,
      11 - Physical Network address of your NIC. Alpha numeric address designating the location of your NIC in the particular LAN network.
      12 - And should I tell you? IPConfig/all for the win
      13 - I have a better question, tell me when TRUE MS-Dos was introduced?
      14 - Red Hat, Fedora, Unix, shall I go on?
      You have to be a genius to get your CCNA/A+ don't you now a days? 🙂
        BTW - I will give you $500 to build a PC to make BF2 run smooth. If you can make it run on 1024x768 resolution - have over 80 FPS (Over the average refresh rate of a CRT/LCD Monitor) you can keep the money. It isn't going to happen. As for S3.0 that would be share 3.0 pixel technology where the vertex shaders do computation on the fly - as for 24 pipeline architecture, in correct the 7800 is not the only one out there, new ATI R520 cores do feature it as well. Should really read up before you start babbling out nonsense.
        • O
          O
          spoolude wrote:
          People think they're smart when they have an A+ certification.......you can get it out of a cracker jack box now.
          You have to be a genius to get your CCNA/A+ nowadays, don't you?
          i would correct you on what i feel is important... but it looks like you've just invalidated all the crap you just spewed out, effectively proving that your "knowledge" is just as worthless as mine.
          ati's x1800xt doesn't have 24 pipelines, i don't know who you think you're fooling.
          http://www.theinquirer.net/?article=26720
          by the way, you still haven't posted what your pc has for it's internals and how much you spent on it. do i sense a little intimidation? 😉
          when you do finally tell us all what you have, be very specific, i want it to hurt as much as it can.
            Check out tomshardware.com - Ati R520 core - read up buddy 😉
            as for my hardware
            Athlon 64 3500 - S 939 - L2 Cache = 1mb
            MSI K8n Neo Plat 2 - S939 - Nforce3 chipset
            1024MB OCZ PC PC3200 DDR
            Evga Geforce 7800 GTX (256 MB) - Running 81.51 Forceware Drivers
            WD Raptor 36 Gig (SATA, 10k RPM) - Primary HD
            Maxtor 160 Gig (Sata, 7200 RPM) - Secondary
            NEC DVD+-RW (4x speed only, need to upgrade)
            Samsung CD-RW 42x - Blackplate
            Creative Labs Audigy 2 ZS
            Antec Trueblue 430W PSU
            as for costs honestly I'll have to get all my receipts and calculate it out. But I did you a favor and posted under anandtech.com a thread under the forum General of - BF2 computer for under $500 - please read, your quite the comedian there 🙂
            • O
              O
              you'd better back up that tomshardware.com claim with a link, because i don't see anything on that page about the x1800xt or r520. i have found several pages that say the newest ati flagship card is only 16pipelines. besides, do the math. a 16 pipeline card running at several hundred mhz faster than a 24pipeline card will put up similar numbers (think of the intel vs amd rivalry)
              i also have a 3500 939, and unless you can show me a cpu-id screenshot that says it's a 1mb cache, i prefer to believe amd that it's a 512.
              http://www.amd.com/us-en/assets/content_type/DownloadableAssets/K8_Electrical_Spec_Rev_ENG.pdf
              your pc is not a $2k machine, and if you spent that much, you were a fool.
              my newest machine:
              athlon 3500, 90nm - 180
              asrock agp/pci-e mb - 74
              1gb 2.5 latency pc3200 - 89
              160gb hdd - free when nathan upgraded
              antec case and 350watt psu - 70
              6600gt pci-e - 120
              dvd-rw - free after installing some hardware for someone
              total - 533
              going to keep laughing?
              i know this isn't a 500 machine, but i decided to build another 939 machine just in case i keep this one long enough to upgrade to a dual core in the future. best part about this one? it cost me nothing. i sold my old socket939 3000+ machine to upgrade to something with pci-e and a faster cpu. the socket 462 barton core xp cpu will play any game on the market, and will do it for far less than the 64bit cpu's, so i could have saved about $100 by using an older chip.
              why didn't i buy a 7800gtx? why should i? the 6600gt is the best card on the market when it comes to excellent performance at a good price.
              once again, we come to the point where i show you that i set a goal and had a budget in mind for how much i wanted to spend, so i stuck to it. if i really wanted to build a pc to mop up yours, i could, but i would just be that much more pissed off in 6 months when i could buy everything all over again for half the price.
              you just keep thinking you're on top of the world because you paid top dollar... some of us realize that the human eye can't discern any significant difference between 60fps and 100
              • FlowcusF
                FlowcusF
                Flowcus
                out there wrote:
                if it was really worth my time, i would acquire a copy of everquest 2 and play it to see just how horrendous the max settings at 1280x1024 (because 17" is what most people have) are and then start looking.
                If you really want I have a copy of it I dont play anymore... I could run it on my machine if you want to show you or you could run it on yours. Its so bad it locks my machine up which is sub par for how cheap it was.
                I ride random bitches.
                • O
                  O
                  you're just full of lies. i've been reading anandtech for a while, so i checked to see what might have been said... and (surprise) i found nothing. (searched for bf2 and 500)
                  link?
                  who just got owned?
                  • Afsil80A
                    Afsil80A
                    Afsil80
                    So what servers do y'all normally play on?
                    -Peter
                    1991 240SX
                    • O
                      O
                      i don't play bf2 or bf1942 online, haven't even tried - in fact, i don't really like either of them. my money is on enemy territory because it requires a lot more work then just "capture the flag"
                      • Afsil80A
                        Afsil80A
                        Afsil80
                        Shit, the majority of my points in BF2 are as a lone wolf. Damn near 2/3rds of my points are from neutralizing and capturing control points by myself.
                        -Peter
                        1991 240SX
                        • O
                          O
                          lone wolf? meaning that you capture the flag alone?
                          how about getting through the enemy lines without dying; making your way to the objective without being seen or setting off landmines (which you can't see); setting dynamite that takes 30seconds to detonate and protecting it from being defused until it blows? there are so many variations of maps with enemy territory i couldn't hope to explain the ideas behind them all.
                          • Afsil80A
                            Afsil80A
                            Afsil80
                            Lone wolf means not being a part of a squad, and operating on your own.
                            If I'm sniping, that's what I do. Otherwise, I'm usually playing with the Spec Ops kit or Assault.
                            -Peter
                            1991 240SX
                            • PhatsP
                              PhatsP
                              Phats
                              Yea, i'm usually medic and in the chopper, but out there, what game is this??
                              Sounds good, and pete i'll cll ya and lt you know what server most of us are on, there's like 5 other people we get on a server with.
                              02 GSXR-1000
                              97 540i
                              • O
                                O
                                http://games.activision.com/games/wolfenstein/
                                we've had 14 people playing at the house at one time, it was excellent.
                                it's a free game that was scrapped because there was a problem with the ai (apparently). anyway, there are lots of servers available online with several mods.
                                i think it's way more enjoyable than bf2/1942 or call of duty. it's not so much fun when you keep getting taken down by a sniper every few seconds (bf and 1-2 hit kills), and enemy territory allows your character to take more hits before going down, so you have a chance to respond to being attacked. not only that, but my biggest argument is the lack of creativity in bf. yay, capture the flag... map after map after map...
                                don't misconstrue, the bf games have some neat stuff going for them, but enemy territory still takes the cake
                                • Afsil80A
                                  Afsil80A
                                  Afsil80
                                  Cool, I'll have to send you the one that Eric and I frequent.
                                  -Peter
                                  1991 240SX
                                  • PhatsP
                                    PhatsP
                                    Phats
                                    Huh, that looks reasonable, i may have to check it out, if i don't think it's retarded, i may try to find you and see what server you're usually on
                                    02 GSXR-1000
                                    97 540i
