  4. Opinions needed. If you have one, tell me.
50 Posts 15 Posters 1.6k Views
  • 94NDTA9 Offline
    94NDTA9 Offline
    torbs wrote:
    ah, ok. didnt know that
    Not to mention the engine, stock comes with 10.5:1 comp ratio AND lightweight internals built to spin fast, not hold boost.
    Plus, the cheapest s/c set up imagineable would still be more expensive than a H/C set up.
    Turbo set ups for LT1's are mostly custom (arm, leg, first born) and the kits out there are expensive as well because there are only one or two out there.
    Oh yeah,
    Brian's a pussy.
      adog
      Personally, for daily driver use, I would keep the nitrous system, since most H/C setups producing the HP you would like are probably a bit more aggressive than I would like to drive around. If it were me, I would go with forged rods and pistons first. The decision really hinges on your definition of streetable. I have to say I kind of envy you LT1 guys with nitrous, since your intake manifolds allow large wet shots without catching on fire like the LSx series occasionally do.
        bottles are for babies.
        seriously though, I think its fun to sit in car that lopes back and forth at idle, sounds like it is going to fall apart just sitting there, and is so loud it feels like you have a sinus infection at wot.
          what about goin blown then?
            same problem...
            "Plus, the cheapest s/c set up imagineable would still be more expensive than a H/C set up."
              goddamn domestics lol...well man...between the things you are asking, i say go h/c then...
              • 9 Offline
                9 Offline
                97lt1
                I say go for the H/C package. I'm think I know which one you are looking at and I know you won't be dissappointed.
                I'm also looking at H/C packages.
                  dude boost and "goin blown" are 1 in the same man...boost is just less specific and brings it down to creating positive pressure someone how forced into the motor(or somethin like that) 🙂
                  • camzaro28C Offline
                    camzaro28C Offline
                    camzaro28
                    Oh yeah,
                    Brian's a pussy.
                    haha, just go with some AFR 215's and a 242ish cam, with a 3600 fuddle stall. possibly some 3.73's.
                    either way ur gonna end up spending atleast 3 grand after parts and tuning just for H/C. spray 100 shot on top of it
                    jig 4 prez
                    • Sweet-WRX-LovinS Offline
                      Sweet-WRX-Lovin
                      Start pimpin' out every girl you know and buy an intercooled ATI procharger. If I had a V8, this I would have to have.
                      http://procharger.com/gallery/showtemp.php?market=2&idx=1223
                      His power level isn't "amazing" but the car is hardley touched besides the charger. Sounds like from the gallery info that his tuning might not be optimal either.
                      One time...
                      • 94NDTA9 Offline
                        94NDTA9 Offline
                        The only ATI that would work on my car would yeild about the same amount of HP (without a rebuild). The car actually did have an ATI on it before I bought it, but I got the price knocked off with hi selling it to someone else. I wish I could have kept it, but I couldn't afford that much at the time, I was 16, and it was plenty of car at the time.
                        Thats the supercharger that was on my car. I beleive the kit costs $3600
                          camzaro28C Offline
                          camzaro28
                          with that S/C you will be doing a rebuild after 20k miles. u can spray a 100 shot daily into the car and run it 50k miles.
                          dont do boost on these cars unless u have unlimited cash or lower the compression b4 u put the blower on it. its that easy
                          jig 4 prez
                            Sweet-WRX-Lovin
                            Well, you are asking the wrong person here. Butt, and yes I said butt, my old man is a machinest and race car driver for over 30 years, I personally would build a cheap as possible motor running super high compresion (cheaper over the long run vs. a supercharger) but running race gas. If you aren't willing to make this sacrifice I have no hope for you. And BS on the supercharger rebuilding at 20K miles. If you have an ass monkey tunning your car maybe. I have no idea what I'm doing compared to my old man and I could get WAY more mileage out of that.
                            One time...
                            • D Offline
                              D Offline
                              dynotune
                              Heads/Cam all the way!!! If you got the jack do like a 393 lower half and some trick flow heads or if you don't, just go with the ported heads/ cam. They make great power, and coupled with the right gears, the extra RPMs help ALOT. Add a little spray on top and you'll be well into the 500 club. Fuel economy isn't too terrible bad (I have 427 LS1s getting 29.5 MPG in C5s)- you should still be able to expect 18-21. Labor is intense although- I highly suggest yanking the mo to do the swap. While your in there, you should at least do rods/ pistons while you can. F-bodies are a bitch to work on, but the results can turn out impressive when done. ATI kits are nice as well (I know a guy who can hook you up...) but depending on how far you want to go, you'll have to get forged internals anyway. N2O is harder on things (look at your bearings after spray vs. supercharge/ turbocharging) but it's pretty good bang for the buck especially if you already have the setup. DO NOT go above 12:1 or use race gas- it's not necessary at all. Every pt of compression usually nets only about 4% add'l power- not hardly worth running race gas. My $.02
                              DynoTune Speed & Performance
                              Mobile chassis dyno service
                              www.dynotuneusa.com
                              (605) 753-1101
                                camzaro28C Offline
                                camzaro28
                                well wrx guy if i was to tell u something about ur wrx, i wouldnt know to much at all to tell u. but just do some research for urself on some camaro LT1 boards and see how many guys are running blower/turbos, and see how many of them lasted. im not blowing smoke up ur ass about it.
                                and yeah i know it harms the rings. but like i said it takes time and alot of spray of course, on a good running motor.
                                sean go with H/C setup, dont venture into boost with an LT1 unless u can afford it twice. just a mild setup will net u 380ish. then spray 100 on top of it, and it will be a healthy motor.
                                jig 4 prez
                                  Sweet-WRX-Lovin
                                  I'm from the wrong school I guess on this one. If you can't go all the way, then go cheap as possible and wait till that shizat blows up and do it again. My old man got second in the NATIONAL CHAMPIONSHIPS two years in a row on $500 or less motors. But he does know what he is doing and labor is free. If I were you I would go all out, but that is me. I wouldn't have bought a 34k+ car if I didn't believe in this philosophy. (sorry about spelling, been drinking, imagine that) And I don't care about research on boards, I've seen the real thing in real life for as long as I've been alive, if you do it RIGHT, there isn't anything to worry about. And that means covering all your bases.
                                  One time...
                                    camzaro28C Offline
                                    camzaro28
                                    i see me and u have a different philosphy. and i will go from what other guys that drive the same car as me do. i will let the guys that have the money do the trial and error and see what works. and what doesnt is a blower/turbo on a LT1.
                                    if i am gonna do something, i will do my best to do it right the first time. and i definetly wont do something like a 3-5k investment if it hasnt worked for others
                                    so ur saying go blower, because it is double the price??
                                    jig 4 prez
                                    • 94NDTA9 Offline
                                      94NDTA9 Offline
                                      No offense, but I'm going to wait till you havn't been drinking to corect yourself or retract your statement.
                                      There are plenty of machinests and expereinced racers running LT1's. 20K on a STOCK INTERNAL LT1 is pretty much the norm, for people running boost of equal knowledge level, or more, of what your old man knows.
                                      I'm sorry, but you are simply in the wrong on this.
                                        Sweet-WRX-Lovin
                                        Same car has nothing to do with it. I'm saying blower not because it is simply twice the price or something like that, but because it has a sweet payoff if done right. Plus the payoffs are expandable as you upgrade your engine, especially on a V8. It's exponetial compared to a four cylinder of course. And if you scorch the motor it is very cheap to rebuild it with just a service manual, a decent set of wrenches, a torque wrench, yes a few other odds and ends, and some patience. I've built A LOT (more than a hundred) of V8s by hand, it's not that hard. If you are even considering going a little nuts or all out. V8s are cheap to rebuild unless you are going absolutely crazy (rollercams, ported heads, high rise intakes, valve magic, and exotic deck, head, rod, or crank work, etc.). All I'm really saying is seriously consider what you are really trying for in the end and put NO time limits on reaching those goals. If it takes longer to save up for a charger so what. What you have in the end is well worth it. I don't plan on making major power with my car for a LONG time. If it takes me 10 years so what, I'll have it sooner or later. I guess my opinion is don't sell yourself short for short term power when you can use most of that money towards a real big power setup in the relatively near future. Anyway this has probably gotten out of hand so go with whatever you feel is best.
                                        One time...
                                          Sweet-WRX-Lovin
                                          Me drinking has nothing to do with this. My old man is a fucking GENIUS (and I am being actually humble) when it comes to mechanical things of any kind. I'd put him against the absolute best in the WORLD at anything to do with engines. I could care less what some part time free lance mechanics (or full time for that matter) think or experience with engines. He could get it to work, and work well for a long time. Lecture all you think you need to. I gotta go to Denny's now, be back to talk about this later 🙂
                                          One time...
