  4. Car sputters
Car sputters
33 Posts 11 Posters 2.5k Views
  • krzydrftr93K Offline
    krzydrftr93
    Thanks for the help 🙂 I will check this stuff out and ill let you know if it stops or not. Thanks again
    Matt
    92 Civic HB
    JDM d15b w/14b@8psi
    • darkelvisD Offline
      darkelvisD Offline
      darkelvis
      check plugs, wires, dizzy, and timing/timing belt. 🙂
      • youngin2nrY Offline
        youngin2nrY Offline
        youngin2nr
        my car did it for awhile until i replace the catylatic convertor and flex tube. Now the mazda flows smooth. Check that too.
        :3gears: -> :drink: -> :poon:
          krzydrftr93
          Ok this probably seems really dumb but how do you know if the wires are bad or not?
          Matt
          92 Civic HB
          JDM d15b w/14b@8psi
            Disconnect each spark plug wire off and measure resistance between the 2 ends of the wire. Resistance should be less than 25000 ohms on each wire.
              seanjohn
              Exactly what my car did. Rotor cap, take it off and take a look at it now before the problem becomes more serious.
                TEG2LOW
                Even if the plugs have spark the won't always fire under load, so replace em if not any of the other problems.
                  krzydrftr93
                  Ok..I just got the new plugs and wires on, took it for a spin and its still doing it. Anyone know what else it might be?
                  Jake-did you have this same problem with it?
                  Matt
                  92 Civic HB
                  JDM d15b w/14b@8psi
                  • tntmstrT Offline
                    tntmstrT Offline
                    tntmstr
                    check your distributor cap and rotor, replace your fuel filter, check ALL of your engine grounds that's what i would start with..........................................or u can always bring it to tintmasters and i'll fix it
                    kyle posting at work
                    Jason Christopherson
                    Store Manager
                    Tintmasters
                    Fargo, ND (701)239-TINT
                    www.tintmasters.net
                      krzydrftr93
                      I dont want to have to pay labor to have it fixed when I can do it myself if I just find out what it is. Sorry
                      Matt
                      92 Civic HB
                      JDM d15b w/14b@8psi
                      • nuckinfutsN Offline
                        nuckinfutsN Offline
                        nuckinfuts
                        hey yea i had the same problem when i had the car, a buddy of mine said that he had the same problem too, he just said that there was oil in the distributer cap and all he did was clean it out and it worked just fine. i just never got aroumnd to doing that before i sold u the car.now my new car is stating to do it too so ill try it out and let u know.
                          seanjohn
                          I swear to god it's your distributor.
                            krzydrftr93
                            If its the distributor, I would have to replace both cap and the rotor right??
                            Matt
                            92 Civic HB
                            JDM d15b w/14b@8psi
                              seeming as how that is what a dizzy really is....yeaaahhh. Just ebay it up and buy a new dizzy.
                                http://cgi.ebay.com/ebaymotors/96-97-98-HONDA-CIVIC-DISTRIBUTOR-1-6-D16-VTEC_W0QQitemZ8024947439QQcategoryZ33690QQrdZ1QQcmdZViewItem
                                Theres a really cheap Dizzy thats ending soon, just save the time and buy it.
                                  krzydrftr93
                                  Thanks, but I will just buy a brand new one. I would rather have new parts or aftermarket parts. And would that dizzy even work on my car considering its a 1.5 d15 NOT 1.6 d16
                                  Matt
                                  92 Civic HB
                                  JDM d15b w/14b@8psi
                                    dose it have Vtec? then yes...it would
                                      seanjohn
                                      All vtec dizzy's are the same. Check out distributorking, I believe he is a vendor on ebay. Great prices great products.
                                        nuckinfutsN Offline
                                        nuckinfuts
                                        no its nonvtec
                                          Civic VX is Vtec, its that economy Vtec engine. Vtec e or something like that, but none the less...its Vtec.
