  4. Turbo CRX??
Turbo CRX??
21 Posts 7 Posters 712 Views
    SORRY FOR THE PICS, taken with phone. someone resize them for me PLZ!
      Why are you posting Matt's car? Can't he?
        so he's gonna have to rev to 9k just to get that thing to spool
          aliengotpsi
          probly never spool it with that T4 housing... if you do it will not be fast due to the lag between shifts...
          But if he wants to sell it id maybe buy it..
          Kevin Smith
          Straightlinedetailing.com
            i thought those holsets were supposed to spool quickly?
              aliengotpsi
              http://store.straightlinespecialties.com/product_info.php?products_id=190
              This could be the most technologically advanced bolt on turbocharger available today. Capable of producing more than 500 horsepower at the wheels and able to run in excess of 35 pounds of boost. This Holset HX-35 also comes standard with a "Map Width Enhancement" groove. This groove is machined into the inlet of the compressor housing to allow air to be fed to the second set of blades on the compressor wheel. This increases efficiency and overall air flow by more than 10%. All Holset turbochargers come standard with a 360 degree thrust bearing. This HX-35 turbocharger will bolt on to your stock manifold and downpipe without any additional modifications. Compressor housing is only available in a 4" Inlet and 2.5" Outlet.
              The reason the spool on a dsm is cause of the exhaust housing... they fitted a DSM Housing so it would bolt on..
              my .02
              Kevin Smith
                ah gotcha...
                  This is matt. Bryce i don't have an account and for some reason it wont let me create one. and for the people that think it won't spool it will spool late for some people but it will be fine for me. there are alot of people with ls motors spooling 10 lbs at 4000-4500 rpm depending on manifold, downpipe, exhaust etc... so on the b16 i would guess to get 10 lbs at maybe 5000 since i'm lowering vtec engeagment to 4800 rpm. And plus lag is like traction control. hehe
                    i thought we already discussed the traction thing...it doesnt matter when it comes on or somethin....i think gsr was explaining it one day...youll just break loose once it spools bottomline...
                      this is matt. I was joking around.
                        Well if you can't make a accout just use my extra account. 🙂
                        Username: drifterextreme
                        Password: Pmed!
                          hope that turbo work good for ya. if you need something differant you know were to go
                            Do you have any specs on exactly what that turbine housing is?
                              Here are the specs on the holset HX35w.
                              -12 cm^2 turbine
                              -.55 AR
                              -t3 flange(divided)
                              thats all i could find on the turbo, hope this helps.
                              this is matt btw
                                -12 cm^2 turbine
                                -.55 AR
                                -t3 flange(divided)
                                .55AR turbine or compressor, and are you positive its T3? 12cm housing is HUGE! You'r probably gonna have issues spooling this thing but i guess you wont know until you try it. Cant say i've seen anyone use the Holset turbine side on anything yet.
                                  turbine. there is a huge thread on honda-tech about the turbo.
                                    I know all about the turbo but cant say i've seen anyine use their turbine.
                                      joel what is the part number? 7 digits starts with 35
                                      also hx-35s have had 9,14,16, and 18 cm housings
                                        3590104 thats the number
                                        matt
                                          all see what i can dig up tomarrow
