Tein Flex with EDFC setup for sale-honda
for sale-
selling a setup of tein flex w/edfc that was on a 93 civic ex i beleive will fit 88-00.... used for less than 1k .... please buy this asap.... heres some specs....:: Spring Rate Front: 9/504 (kgf/mm, lbs/in)
:: Spring Rate Rear: 5/280 (kgf/mm, lbs/in):: Ride Height Front: -25(mm),-1(inch)
:: Ride Height Rear: -35(mm),-1.4(inch):: Adjust Range:
:: Ride Height Front: -19(mm),-0.7(inch) ~ -69(mm),-2.7(inch)
:: Ride Height Rear: -2(mm),-0.1(inch) ~ -68(mm),-2.7(inch)-Full-length adjustment and height adjustment for separate setting of the height and spring preload.
-16 levels of damping force adjustment (compression and rebound together).
-Teflon coating for rust prevention.
-Newly designed spring seat and spring seat lock for easy height adjusting.
someone please buy these asap, im asking 1200.... they go for 1500 new on ebay and these have only had 1k miles on them!!!!!!
Goodluck on the sale. Bump for a damn good suspension.
Ry
good suspension... bump
bipedbear wrote:
one week only special..... 750 picked up with EDFCthats more of a better price that you'll find someone to buy. goodluck again.
Ry
this will fit those years integras too. Just will have different spring rates.
ry
btleier wrote:
are you sure eg, and ek have the same suspension?88-00 civics and integras had the same suspension style, just different spring and shock rates. 01-05 civics and 02+ rsx have similar suspensions too. Everything bolts up, but have different ride qualities due to handling tuning and vehicle weights.
Ry
LT1 wrote:
what all cars does this fit88-00 civics
ef, eg, ek, eh, ed, ej, em
90-01 integras
dc2, dc4, db, 1990+ daI'm positive itll fit:
eg, ej, em, eh, ek, dc2, dc4....the others may be different slightly and there might be others, havn't actually looked at them that closely. All I know is that Honda didn't change the suspension design for many years.....and in 01 when they went to the Macpherson struts in the civics is when they had problems with them leaking very early on. Actually had some TSB/Recalls i believe. The older design was perfect in long lasting, most of them lasted a good 100K miles or more before needing replacement. now the new 06 civics have a new suspension with torsion bars in the rear. Me not happy.
