150 miles to my last tank?!
You're not out of boost fluid again right?
Sweet-WRX-Lovin wrote:
You're not out of boost fluid again right?Yeah, check out your vtak cleaner too. I heard honda is going to stop selling the vtak cleaner so stock up now.. after this year you will just have to buy a new vtak. (or go grey market for 'tak cleaner... shhh).
Just funnin.. I had a civic ex when I was 17 and didn't know shit about cars and let me tell you, v-tec was the shit.
A way you can check to see if they are putting out the proper voltage, is to use a multi meter, and read the signal wire at the ECU to see if it is fluctuating between 0-1 volt DC. It will bounce all around at idle and normal cruise, but under full throttle it will sit at a value closer to 1v.
Nope, haven't touched the timing since the new dizzy...only thing to change is the 02 sensors. However, I double checked under my hood tonight because I have to order some
-an fittings for my fuel line...and I noticed it reaked of gas...and I notice a little pool of fuel accumulating on my intake manifold. Looked like it might have come out of injector #1....dunno if it's not getting a good seal or what?!?! Stoopid cars. -
PSiedTSi wrote:
if youve R&R'd the injectors a lot maybe its a good idea to replace the O-rings...its a cheap insurance policy if nothing else...Yeah, I'm going to go ahead and get a new injector o-ring set. The old 02 sensors have moved on to a better place. I'm going to replace them and the o-rings and see what happens.
