  3. ICE and Detailing
  4. Soundproofing
Soundproofing
23 Posts 13 Posters 4.8k Views
  • PSiedTSiP
    PSiedTSiP
    its exactly like dynamat...
    spanish-rice;237125 wrote:
    • J
      J
      JDMSTi
      www.b-quiet.com check that out....good site!
        brownbread is good stuff, Vblock makes some nice stuff as well...no stench as it is not asphalt based. I can also get fairly easily the products on this page: http://www.theinstallbay.com/product_section.php?pn=22
        Prices are anywhere from $6 to $100, depending on which kit you go with.
        • krzydrftr93K
          krzydrftr93K
          krzydrftr93
          Not sure if it works but I have heard of people using the truck bed liner crap(cant member the name of it) or that foam that puffs up and gets hard(I know people have sprayed this in cracks and panels)
          Matt
          92 Civic HB
          JDM d15b w/14b@8psi
          • 24valvenotak2
            24valvenotak2
            the spray in bed liner doesnt stop much of the rattling at least thats what ive been told. Ive heard spot welding works rather nicely though..
            63vette;288530 wrote:
            • K
              K
              on my old grand prix i used expanding foam on the trunk and other spots were there was metal close together. but you have to hatk your time and do it right esspecially where it is visable. the stuff is ugly
              • JohnWJ
                JohnWJ
                JohnW
                I have used the following:
                Brownbread: works the best IMO but stinks, also melts in the summer.
                Cascade VB2: thin, works about as good as the brownbread, doesn't stink
                B-quiet liquid: visoelastic sound deadener, has to be painted on in several layers with a long dry time between each, but is great for inner trunk panels, inside doors, wierd surfaces, etc.
                Dynamat Extreme: the old standby, works well. expensive though. you can get more for less. you are paying for the brand name
                Hitemp Mastic: 'Roofing stuff' god no. stinks like cat piss. alot. always. forever.
                90 Civic DX hatch
                D16a6/y8 mini me
                • 9
                  9
                  93Pgt
                  thanks for all the info
                    I can get the cascade stuff as well I believe....
                    • JoelJ
                      JoelJ
                      how much would a person need for an entire car?
                      http://www.raamaudio.com/ looking around I have found this site too.. seems to be different than tar-style. I think I might give this stuff a go.
                      • RidinRailsR
                        RidinRailsR
                        i've used brownbread, all types of dynamat....they both work well..
                        i would never recommend using "great stuff" that foam that expands....
                          http://www.s-f-d.com/pdf/casc.pdf
                          let me know what you want, and I'll get you pricing.
                          • 9
                            9
                            93Pgt
                            how much is brownbread
                              found a product from Dayton Audio that is vinyl based that I can sell for $25+ shipping for a 27"x40" sheet
                              • TakeYourTopOffT
                                TakeYourTopOffT
                                TakeYourTopOff
                                When I did my Convertible that I used to do IASCA with I put v-block in it but it had areas that were hard to put matting down so I had put the spray on also and it held up for 6 years and the only time you heard rattle was if i had the trunk lid open and the rattle was from the part of the latch that grabbed the stricker!!!!
                                legacy image legacy image
                                Personal Web Site
                                • M
                                  M
                                  mybadga
                                  • M
                                    M
                                    mybadga
                                    i have done my grand am in fat mat. www.fatmat.com it is basically dynamat extreme without the price of paying for the brand name, you get 2 rolls = 100sf for $100 plus shipping and i had enough to do my whole car and still some left over, not much but some. i dont have a stereo hooked up yet to test it out but i have heard about it from a few people and they said it was pretty good.
                                    • M
                                      M
                                      musthavemuzk
                                      i have 2 layers of peel and seal in my cutlass. been on there for 3 years now. only had a few pieces fall off and those were on the trunk lid. i have 200+ sq ft in there. of course i did everywhere i could get.
                                      i went this route due to money savings over others.
                                      it did stink for a bit though since it is asphalt based.
                                      the expanding foam was used in the trunk lid and helped alot. but be careful as i sprayed that when it was still a little cool. and as the temps rose it expanded more. no bulges or anything, but i did have trouble a couple times opening my trunk since it had come out the holes and started to cure where the lid met the seal or the metal.
                                      but there are lots of options out there now.
                                      hit some car audio forums and see what is used and what works.
                                      remember though that this adds weight. so if you plan on racing know you will be slower if you add alot. if done higher, as in upper half of car it will also throw off things a little bit.
                                      Monty
                                      14.59 at 94.85 still stock
                                      www.pbase.com/musthavemuzk
