  4. Burning Oil....
Burning Oil....
28 Posts 11 Posters 1.3k Views
  • TsiTomT Offline
    TsiTomT Offline
    TsiTom
    96Talon wrote:
    Ya when i start the car up you can see the white smoke and if i get on it. I can see some from the rear view mirror.
    Is there a nice cloud of smoke in between shifts?....
    Tom Opgrand
    2011 Camry
    • DWeigsD Offline
      DWeigsD Offline
      DWeigs
      Not that i know of or that i have noticed. So there could be but i dont think so...
        does it do it only when the car is warm? or only when the car is cold? or all the time?
        • DWeigsD Offline
          DWeigsD Offline
          DWeigs
          All the time it seems like. The smoke is more noticeable when its cold but i can still smell it and see it.
            valve stem seals?
            • DWeigsD Offline
              DWeigsD Offline
              DWeigs
              I have no clue this is all new to me so whatever you say is kinda weird lol. But im not gonna rule nething out..
                White smoke is burning coolant. It's probably the head gasket. If the car is a non turbo (420A), those are notorious for head gasket failures.
                • DWeigsD Offline
                  DWeigsD Offline
                  DWeigs
                  Could i have a cracked block...
                  • TsiTomT Offline
                    TsiTomT Offline
                    TsiTom
                    No.
                    Tom Opgrand
                    2011 Camry
                      aliengotpsi
                      Turbo, rings, valve seals, how many miles on the car??
                      Kevin Smith
                      Straightlinedetailing.com
                      • DWeigsD Offline
                        DWeigsD Offline
                        DWeigs
                        Its not a turbo so it couldnt be the turbo rings. Also it had 186,000 miles on it. There has never been a rebuild on to my knowledge
                          First of all there is no such thing as turbo rings, I dont know where that came from. Second of all, like I posted in my last post, if your car is a non turbo, which you just said it is, those are notorious for head gasket failures. Now since your car is smoking white like you said, I would venture a guess at it being the head gasket. Go get it replaced. Even if it's not the head gasket, you should replace it anyways because it will need it since those motors are crap.
                            treimche wrote:
                            you should replace it anyways because it will need it since those motors are crap. so much hate:icon_bigsmurf:
                              Not really, the 420A never did anything to me, they just suck, and that's the honest truth.
                              • smtomps1955S Offline
                                smtomps1955
                                i would check to see if you are dumping to much fuel into your motor, when this happens the fuel usually ends up in the oil. it has to do with your eletronic fuel injection, when it starts to go out that is what it does, until it goes out it will dump way to much fuel in your car and thus it wont start at all and be carefull if this does happen because your car will back fire real bad and may start on fire cause the fuel will start leaking out of exaust manifold and down threw exaust piping. the part to fix this is rather expensive, but i dont know remember what the part is call but its located in or arond your fuel pump if i remember right.
                                2003 f150 supercrew
                                2002 Urabus WRX sedan
                                1991 Nissan Hardbody
                                :icon_puke_l:
                                  Are you serious?
                                    holy shit, this is entertaining....
                                    "when this happens the fuel usually ends up in the oil."
                                    uhhh fuck my oil pan exploded!
                                      this has to be one of the more idiotic things I've ever read.
                                      • 9 Offline
                                        9 Offline
                                        92TSIpos
                                        wow I feel like a dumbass for even thinking how gas could get into your oil????????
                                        • 9 Offline
                                          9 Offline
                                          92TSIpos
