  4. Burning Oil....
Burning Oil....
28 Posts 11 Posters 1.3k Views
    aliengotpsi
    Turbo, rings, valve seals, how many miles on the car??
    Kevin Smith
    Straightlinedetailing.com
    • DWeigsD Offline
      DWeigsD Offline
      DWeigs
      Its not a turbo so it couldnt be the turbo rings. Also it had 186,000 miles on it. There has never been a rebuild on to my knowledge
        First of all there is no such thing as turbo rings, I dont know where that came from. Second of all, like I posted in my last post, if your car is a non turbo, which you just said it is, those are notorious for head gasket failures. Now since your car is smoking white like you said, I would venture a guess at it being the head gasket. Go get it replaced. Even if it's not the head gasket, you should replace it anyways because it will need it since those motors are crap.
          treimche wrote:
          you should replace it anyways because it will need it since those motors are crap. so much hate:icon_bigsmurf:
            Not really, the 420A never did anything to me, they just suck, and that's the honest truth.
            • smtomps1955S Offline
              smtomps1955
              i would check to see if you are dumping to much fuel into your motor, when this happens the fuel usually ends up in the oil. it has to do with your eletronic fuel injection, when it starts to go out that is what it does, until it goes out it will dump way to much fuel in your car and thus it wont start at all and be carefull if this does happen because your car will back fire real bad and may start on fire cause the fuel will start leaking out of exaust manifold and down threw exaust piping. the part to fix this is rather expensive, but i dont know remember what the part is call but its located in or arond your fuel pump if i remember right.
              2003 f150 supercrew
              2002 Urabus WRX sedan
              1991 Nissan Hardbody
              :icon_puke_l:
                Are you serious?
                  holy shit, this is entertaining....
                  "when this happens the fuel usually ends up in the oil."
                  uhhh fuck my oil pan exploded!
                    this has to be one of the more idiotic things I've ever read.
                    • 9 Offline
                      9 Offline
                      92TSIpos
                      wow I feel like a dumbass for even thinking how gas could get into your oil????????
                      • 9 Offline
                        9 Offline
                        92TSIpos
                        • 9 Offline
                          9 Offline
                          92TSIpos
                            so what you're trying to tell me.......... if that you feel like a dumbass for even thinking how gas could get into your oil?
                              smtomps1955
                              dont believe me ask a mechanic then, i was just trying to help he ask what was wrong and i gave him ideas of what could be wrong. i think its stupid that you can sit and make fun of me for trying to help him out. Dont believe me thats fine.
                              2003 f150 supercrew
                              :icon_puke_l:
                                Oh it is totally possible for gas to get into the oil on any car, but it has to be running extremely rich to where it can not burn off all of the gas, and at that point it would be smoking black, or it would have to be getting flooded out by cranking the car trying to start it for long periods at a time. Now neither sounds to be the case since the car is smoking white.
