  4. Burning Oil....
Burning Oil....
28 Posts 11 Posters 1.3k Views
    does it do it only when the car is warm? or only when the car is cold? or all the time?
    • DWeigsD Offline
      DWeigsD Offline
      DWeigs
      All the time it seems like. The smoke is more noticeable when its cold but i can still smell it and see it.
        valve stem seals?
        • DWeigsD Offline
          DWeigsD Offline
          DWeigs
          I have no clue this is all new to me so whatever you say is kinda weird lol. But im not gonna rule nething out..
            White smoke is burning coolant. It's probably the head gasket. If the car is a non turbo (420A), those are notorious for head gasket failures.
            • DWeigsD Offline
              DWeigsD Offline
              DWeigs
              Could i have a cracked block...
              • TsiTomT Offline
                TsiTomT Offline
                TsiTom
                No.
                Tom Opgrand
                2011 Camry
                  aliengotpsi
                  Turbo, rings, valve seals, how many miles on the car??
                  Kevin Smith
                  Straightlinedetailing.com
                  • DWeigsD Offline
                    DWeigsD Offline
                    DWeigs
                    Its not a turbo so it couldnt be the turbo rings. Also it had 186,000 miles on it. There has never been a rebuild on to my knowledge
                      First of all there is no such thing as turbo rings, I dont know where that came from. Second of all, like I posted in my last post, if your car is a non turbo, which you just said it is, those are notorious for head gasket failures. Now since your car is smoking white like you said, I would venture a guess at it being the head gasket. Go get it replaced. Even if it's not the head gasket, you should replace it anyways because it will need it since those motors are crap.
                        treimche wrote:
                        you should replace it anyways because it will need it since those motors are crap. so much hate:icon_bigsmurf:
                          Not really, the 420A never did anything to me, they just suck, and that's the honest truth.
                          • smtomps1955S Offline
                            smtomps1955
                            i would check to see if you are dumping to much fuel into your motor, when this happens the fuel usually ends up in the oil. it has to do with your eletronic fuel injection, when it starts to go out that is what it does, until it goes out it will dump way to much fuel in your car and thus it wont start at all and be carefull if this does happen because your car will back fire real bad and may start on fire cause the fuel will start leaking out of exaust manifold and down threw exaust piping. the part to fix this is rather expensive, but i dont know remember what the part is call but its located in or arond your fuel pump if i remember right.
                            2003 f150 supercrew
                            2002 Urabus WRX sedan
                            1991 Nissan Hardbody
                            :icon_puke_l:
                              Are you serious?
                                holy shit, this is entertaining....
                                "when this happens the fuel usually ends up in the oil."
                                uhhh fuck my oil pan exploded!
                                  this has to be one of the more idiotic things I've ever read.
                                  • 9 Offline
                                    9 Offline
                                    92TSIpos
                                    wow I feel like a dumbass for even thinking how gas could get into your oil????????
                                    • 9 Offline
                                      9 Offline
                                      92TSIpos
                                      • 9 Offline
                                        9 Offline
                                        92TSIpos
                                          so what you're trying to tell me.......... if that you feel like a dumbass for even thinking how gas could get into your oil?
