  4. E85 fuel...is it a good thing???
109 Posts 29 Posters 11.8k Views
  • JimJ
    JimJ
    Just spend the money on real race gas... its not that big of a difference; if your worried about saving a dollar or two on gas, you shouldn't be racing.
    If you have to richen it up to run E85, you would be losing power....
    Just buy race gas and lean it out...
    • torbsT
      torbsT
      true true...i was just curious if it would work, cuz it would be great if it did work, but it doesnt...o well...i guess i was just hopin that it was a miracle fuel or somthin...
      • harwood39H
        harwood39H
        harwood39
        i think it would be worth it for the street, if your car is set up for it. Just thinking that you would be able to run more boost and in turn make more power.
        2730 5th Ave S. Unit C
        Fargo, ND 58103
        701-429-3686
        • JimJ
          JimJ
          Hmm... did you not read the posts previous to yours?
          • SmitEvoS
            SmitEvoS
            E 85 = sucks c16= kick ass
            • O
              O
              if you have to burn more fuel, then you're going to spend more... so it would cost more to run e85. not to mention the cost of adding parts... trust me, i had this conversation with nick and kevin a while back
              • P
                P
                But you still had to try it didn't ya? Haha. Tell us how it worked out for ya.
                • S
                  S
                  seanjohn
                  Through a little more research I found out that the stoichiometric coefficient for ethanol about 9.0:1, meaning you'd have to burn almost 1.5 as much just to get the same amount of power. But, that would only be if you are burning 100% ethanol. If you ran 20% ethanol, 80% 91 octane you'd have an octane rating of almost 94 and need about a 12.4 to run correct air fuel. Seems like this wouldn't be to hard with a properly tuned car.
                  • O
                    O
                    it's not hard to run e85, it just takes more. to be more specific about the problems i had... normally i idle just fine at -30% with my afc, but i had to richen up to -22% to get the vacuum needle back into the proper place. when i did a couple of 3rd gear pulls, i had to richen the entire curve 3-7% (something like that) to maintain the same knock counts as with my 92octane settings. sure, with e85 you can get better octane and run more boost... but there are so many other factors that need to be considered.
                    also keep in mind, these numbers are at +/-19psi on the 14b
                    • S
                      S
                      seanjohn
                      I really think a good tune with 20% E85 would be a good idea...guess I'll give it a shot!
                      • P
                        P
                        If you have to richen the car up there is no power to be gained.
                        • torbsT
                          torbsT
                          well...now that the idea of e85 working isnt true, im wondering if this stuff called xylene and tylene (sp?) work. a lot of ppl use it in dsmtuner as an octane booster...seems like they use it in a 10-15/85-90 mix with gas because xylene has an octane of 117 and tylene has an octane of 114...im not sure how much they cost around here exactly, but it would be great if you could make your own "home made" race gas, so you could run a little bit more on the street if you want, cuz we live in ND/MN and nobody seems to have over 92 octane at the pump around here (correct me if im wrong, cuz im not totally sure)...have any of you tried either of those to things?...later
                            I use Touelene (sp?) on the street. It reduces my knock
                            • SmitEvoS
                              SmitEvoS
                              cheaper to buy 110 octane 3.30 a gal
                              • torbsT
                                torbsT
                                where do you get 110 octane at?
                                  the advantage of Tuolene is that it is unleaded so doesn't mess w/ my O2 sensors. Tuolene isn't too badly priced either if you buy it in larger quantities (Fargo Glass & Paint can get upto 55 gallon drums, I buy it by the 5 gallons..special order)
                                  • O
                                    O
                                    xylene and toluene are available at any chemical supply or paint place, they're basically paint thinner. i personally like xylene because it's +/- $6/gal and, like chuck said, it's unleaded.
                                    if you're going to use xylene or toluene, use a higher %; something like 1gal to 3gal of 92octane, and then reset your ecu
                                      I like Toluene as it is found naturally in gasoline. In fact the F1 cars of the early-mid 80's used to run on 85% toluene back when they ran turbo 4 cylinders. Obviously we don't have F1 engines in our cars as noone is making 750 HP/liter, but at least we know it can be run in a gas engine as it is present in gas already.
                                      • torbsT
                                        torbsT
                                        how much is toluene by the 5 gallon?
                                          comes to like $5.75/gallon or something like that
