  4. This bolt is a bastard.
18 Posts 10 Posters 704 Views
  • 94NDTA9 Offline
    94NDTA9 Offline
    I can't get a wrench, socket, swivel socket, or even a crows foot on it.
    How shall I get this off? It's a tranny bolt by the way.
      Loosen an engine mount and tilt the engine.
      • 94NDTA9 Offline
        94NDTA9 Offline
        I might have to, but I don't want to.
        I allready tilted it a little.
        • Seven1S Offline
          Seven1S Offline
          Seven1
          What size is it?
          • 9 Offline
            9 Offline
            97lt1
            Me and brian got his tranny out tonight and that bolt wasn't actually that bad, we used a 9/16 stubby wrench. I will call you tomorrow and help you get it out.
            • lord_deastofactL Offline
              lord_deastofact
              if you still havn't gotten it, I suggest try using extensions. they work wonders on crappy spots and angles like that.
              Minute ricer!
              • 9 Offline
                9 Offline
                97lt1
                You can't even get a socket on that bolt.
                  How far did you guys get on Brians car last night?
                  • Sweet-WRX-LovinS Offline
                    Sweet-WRX-Lovin
                    You tried swearing at it ALOT right? 🙂
                    One time...
                      That is some fine engineering right there... LOL I had a S10 pickup that I needed to loosen the engine and tilt it up to get the starter out, that was pretty sweet as well.
                      • 94NDTA9 Offline
                        94NDTA9 Offline
                        Sounds like a shit ton of fun.
                        Stubby wrench sounds like the way to go. I don't have one, but i'm sure I could get one.
                        If that doesn't work, then I guess I'll have to try lowering the engine a little too.
                        I have no idea how I'm going to get my hand up in there, lol.
                        • wa2fastcamaroW Offline
                          wa2fastcamaro
                          I know what your feeling, delt with that bolt a couple times already. I can't remember exactly how I got it out now, but usually for bolts like that I use the craftsman sockets with the swivel built into it, because it provides for extra clearence than using a regular socket and a swivel. Or I just lop off a chunk of a extra wrench to make it work.
                          I don't know how many tools I have cut, welded and modified over the years to make my life easier.
                          Mike
                          Boys and Their Toys Auto
                          Phone: 701-371-5615
                          E-mail: [email protected]
                          • M Offline
                            M Offline
                            musthavemuzk
                            all i got to say is GM.
                            my 90 cutlass supreme 3.1 i have to rock the motor forward to work on the back of the motor at all. plugs, wires, O2....alt is fine though.
                            as compared to the alt on the 3.4 DOHC engines where you have to dig way under the motor for that shit.
                            and then to top it off you are pretty stuck with what you can do to them to make them bigger or badder. i mean jeez if i was getting more from all that work it would be fine, but i am not.
                            Monty
                            14.59 at 94.85 still stock
                            www.pbase.com/musthavemuzk
                            • 94NDTA9 Offline
                              94NDTA9 Offline
                              After a grinded "popular mechanics" wrench, and about 10 minutesof finger tip finangling...I got the fucker.
                              Yes, some swearing did help.
                              • 94NDTA9 Offline
                                94NDTA9 Offline
                                Well, I got it out a couple of hours ago.
                                And this made me happy.
                                The old converter in this SOB felt like it weight almost 50 lbs.
                                This new one weighs maybe 25 lbs.
                                Thats a good amount of saved rotating weight! I can't wait untill my tranny comes back!!
                                  That's probably because the new converter doesn't have as much fluid as the old one.
                                  • 94NDTA9 Offline
                                    94NDTA9 Offline
                                    I know, but still, It was a bigger difference than I thought it would be.
                                    I'm going to weigh them when I fill both of them.
                                    • M Offline
                                      M Offline
                                      musthavemuzk
                                      reduced rotating mass has to be a good thing. even it it is only 10 lbs. right? right!
                                      Monty
