  4. its almost....
its almost....
154 Posts 28 Posters 13.7k Views
  • zbrownZ
    zbrownZ
    Parker;210101 wrote:
    welp, it gets a bit better grip with a 215 on it, i cant tell if there spinning or not.... dont know what i can fit on the stock phone dialer rims, maybe you know zac... hoping i can fit a 250 on the stockers
    ha i have no idea, think they are 6.5's
    just throw some 7" slicks on there, lol, they will hook, just be as unstable as a motherf*cker
    Vid?, i know it didn't rain today............?!?
    rx7-8.89@157mph
    12v dodge, twins
    • GrrG
      GrrG
      Grr
      toolbags, im going to chat, and your car is slow parker
      2006 Trailblazer SS- my DD
      • ParkerP
        ParkerP
        Parker
        ummm.... 5.5
        10 Jeep
        10 F450
        08 F250
        05 F350
        86 rx7
        70 F100
        63 Olds
        BlueSRT0483;244555 wrote:
        As proven by Parker... Not everything you read on the internet is true.
        Trafik Jamz;260984 wrote:
        You are right Parker.
        • JoelJ
          JoelJ
          • JoelJ
            JoelJ
            Better pics of welds and headers later today...
            • JoelJ
              JoelJ
              • 91nbtsi9
                91nbtsi9
                91nbtsi
                Did you use flux core wire or what?
                [email protected] -- DSM
                07 Mega Cab 5.9 CTD
                • JoelJ
                  JoelJ
                  no, were attempting to penetrate a 1/4 inch flange with a 135 amp welder. why do you ask about flux core? what characteristics make it look like it was made with a flux core welder?
                  • JoelJ
                    JoelJ
                    • zbrownZ
                      zbrownZ
                      turn down the wire speed just a hair and the spatter will disappear, or just trigger it
                      that is the perfect size welder to be doing what you are
                      what is that 3.5 or 4??
                      rx7-8.89@157mph
                      12v dodge, twins
                      • K
                        K
                        ^3inch
                        • JoelJ
                          JoelJ
                          Zach, my wire couldn't go any lower(3.5/10) without getting continuous burnback. I know how to set a welder ...and It's 3 inch.
                          • zbrownZ
                            zbrownZ
                            obviously.........
                            rx7-8.89@157mph
                            12v dodge, twins
                            • F
                              F
                              fanaticrockford
                              What model welder is that?
                              Looks like the one I'm looking at purchasing Lincoln sp135t
                              The welder is perfectly capable of the job but not with that tiny ass long extension cord.
                              • ParkerP
                                ParkerP
                                Parker
                                the cord is bigger than it looks
                                10 Jeep
                                10 F450
                                08 F250
                                05 F350
                                86 rx7
                                70 F100
                                63 Olds
                                • RexwagonR
                                  RexwagonR
                                  Looks good parker. Cant wait to see that thing in person
                                  • JoelJ
                                    JoelJ
                                    lol, the manual says it will penetrate 3/16... so its not made for that. If either of you wanna come make better welds, your welcome to.
                                    • F
                                      F
                                      fanaticrockford
                                      I'm a beginner welder and can tell you your much better then me Joel. I have been doing a lot of research especially with the Lincoln sp135 which that welder looks to be. So what welder is that?
                                      All I'm saying is that your losing a lot of current with that long extension cord. It may be adequate gauge like parker says but where is it plugged into? I suppose to an outlet? How far away is the outlet from the fuse panel and with what gauge wire?
                                      I can guarantee you if the welder was plugged directly into the fuse panel or to a outlet close by those welds would be better.
                                      • zbrownZ
                                        zbrownZ
                                        I would if i was there
                                        lol, you do realize that means 3/16" full penetration from one side with no joint preparation...............
                                        Good thing you are going for for 100% melt-through on a 1/4" flange when you are welding a 16 ga. tube to it 😕
                                        .little bit of difference going from production welding where coarse machine parameters are set and you are in charge of electrode manipulation only............. don't get more and more into this, the welds look fine, all i am saying is that the machine was not set 100% properly and it wasn't
                                        rx7-8.89@157mph
                                        12v dodge, twins
                                        • JoelJ
                                          JoelJ
                                          good call, never thought about it. Yes its a 135t, if you wanna come take a look at it, you are more than welcome...
