  4. its almost....
its almost....
154 Posts 28 Posters 11.4k Views
    tqisking
    Looks good.
    2 things
    #1 that 90 after your regulator is horrible for flow
    #2 the coil is supposed to be mounted vertical not horizontal..
    other than that it looks good..:)
      tqisking;207648 wrote:
      Looks good.
      2 things
      Good call on the coil mount. The high vibration coil can be mounted in any position. I would have never thought of that.
        tqisking
        Not sure if you were being sarcastic or not so here is some proof....and if you were not never mind 😄
        http://www.msdignition.com/forum/showpost.php?p=43998&postcount=4
        msdtechsupport3
        Tech Support Join Date: Feb 2006
        That's a good point. I forgot to ask you if the Blaster 2 coil was mounted vertically or horizontally. Especially with an MSD Ignition box we recommend mounting this, or any other oil filled coil, vertically with the tower pointing upward so that the internal windings remain submurged in the cooling oil.
        MSD Tech Support
        915-855-7123
          Nope, not being sarcastic.
          • ParkerP Offline
            ParkerP Offline
            Parker
            coil is just sitting like that for now.... i need to drill another hole to mount it and go caught up in other shit..... and im not too worried about the 90 degree... fuel line is plenty big... if i have a starving issue... then ill replace it...
            if it makes you sleep better ill replace it.... maybe
            10 Jeep
            10 F450
            08 F250
            05 F350
            86 rx7
            70 F100
            63 Olds
            > BlueSRT0483;244555 wrote:
            > Trafik Jamz;260984 wrote:
            > You are right Parker.
              liar
                tqisking
                Yea your right.....I do not know anything..
                I try to help a guy out and this is what you get...
                You could have 10 right angles in the fuel system I could really care less, I was just pointing out a potential problem just like the coil but I guess you know it all.....
                • ruthless351R Offline
                  ruthless351
                  simma down now!!
                  1. maybe you could of worded that differently. You come across as a know it all.
                  2. Its teh internets! 🙂
                    dude, lighten up. He didn't mean anything as a shot at you.
                    • ParkerP Offline
                      ParkerP Offline
                      Parker
                      i really didnt mean anything by it, i was just in a hurry and replied quick to your post... you actually reminded me to turn the coil up right. i didnt mean to come off as a dick... just in a hurry...
                      on a completly side note the car ran tonight, i think i need to ground my ingition box better because after a few starts the led on the box started flashing and it would not fire.... time to do some research
                      10 Jeep
                      10 F450
                      08 F250
                      05 F350
                      86 rx7
                      70 F100
                      63 Olds
                      • ParkerP Offline
                        ParkerP Offline
                        Parker
                        re grounded the ignition box and she fired right up 🙂
                        10 Jeep
                        10 F450
                        08 F250
                        05 F350
                        86 rx7
                        70 F100
                        63 Olds
                          so whens it going to be on the street? we should have a little meet at tintmaster when it actually stays above 35 degrees.
                            congrats man.
                            • ParkerP Offline
                              ParkerP Offline
                              Parker
                              i was shitting my pants last night when it wouldnt fire up anymore... so i just did some research got some sleep and now its AOK 🙂
                              10 Jeep
                              10 F450
                              08 F250
                              05 F350
                              86 rx7
                              70 F100
                              63 Olds
                              • ParkerP Offline
                                ParkerP Offline
                                Parker
                                on its feet and moving... caution.. very shitty camera phone video, but you get the point
                                http://www.youtube.com/watch?v=lWYxQRq6h3I
                                http://www.youtube.com/watch?v=W_-SSQXjkQs
                                10 Jeep
                                10 F450
                                08 F250
                                05 F350
                                86 rx7
                                70 F100
                                63 Olds
                                • ParkerP Offline
                                  ParkerP Offline
                                  Parker
                                  fuel system hangs a bit low
                                  10 Jeep
                                  10 F450
                                  08 F250
                                  05 F350
                                  86 rx7
                                  70 F100
                                  63 Olds
                                  • GrrG Offline
                                    GrrG Offline
                                    Grr
                                    OOOOOOOOOOOOOOOOOOOOOOO, nice. Probably one of the only fast cars around that actually runs and drives at the moment, good job
                                    2006 Trailblazer SS- my DD
                                    • ParkerP Offline
                                      ParkerP Offline
                                      Parker
                                      this thing hates life below 1200rpm... i mean if the fan kicks on it falls on its face.... not as streetable as i would like it to be.... im having an issue with the brakes, everytime i try to stall the brake peadle goes to the floor and i loose all brakes i let off of the throttle it comes back up, i put a check valve, the work better, but i think i need a vacuum canister, if that dosent help ill just go full manual brakes.... other than that it drives great for having shitty bald tires on snow/ice.
                                      10 Jeep
                                      10 F450
                                      08 F250
                                      05 F350
                                      86 rx7
                                      70 F100
                                      63 Olds
                                        slow
                                        • ParkerP Offline
                                          ParkerP Offline
                                          Parker
                                          MisterCMK;208757 wrote:
                                          my car is slower than yours
                                          fixed*
                                          10 Jeep
                                          10 F450
                                          08 F250
                                          05 F350
                                          86 rx7
                                          70 F100
                                          63 Olds
