  4. its almost....
its almost....
154 Posts 28 Posters 13.7k Views
  • ParkerP
    ParkerP
    re grounded the ignition box and she fired right up 🙂
    BlueSRT0483;244555 wrote:
    Trafik Jamz;260984 wrote:
    You are right Parker.
    • RexwagonR
      RexwagonR
      so whens it going to be on the street? we should have a little meet at tintmaster when it actually stays above 35 degrees.
      • B
        B
        congrats man.
        • ParkerP
          ParkerP
          i was shitting my pants last night when it wouldnt fire up anymore... so i just did some research got some sleep and now its AOK 🙂
          • ParkerP
            ParkerP
            on its feet and moving... caution.. very shitty camera phone video, but you get the point
            http://www.youtube.com/watch?v=lWYxQRq6h3I
            http://www.youtube.com/watch?v=W_-SSQXjkQs
            • ParkerP
              ParkerP
              fuel system hangs a bit low
              • GrrG
                GrrG
                OOOOOOOOOOOOOOOOOOOOOOO, nice. Probably one of the only fast cars around that actually runs and drives at the moment, good job
                • ParkerP
                  ParkerP
                  this thing hates life below 1200rpm... i mean if the fan kicks on it falls on its face.... not as streetable as i would like it to be.... im having an issue with the brakes, everytime i try to stall the brake peadle goes to the floor and i loose all brakes i let off of the throttle it comes back up, i put a check valve, the work better, but i think i need a vacuum canister, if that dosent help ill just go full manual brakes.... other than that it drives great for having shitty bald tires on snow/ice.
                  • MisterCMKM
                    MisterCMKM
                    slow
                    thrash;315544 wrote:
                    Ford is back :)
                    • ParkerP
                      ParkerP
                      MisterCMK;208757 wrote:
                      my car is slower than yours
                      fixed*
                      • GrrG
                        GrrG
                        go full manual, ill never have power brakes again after switching to a properly set up manual system.
                        • W
                          W
                          weeman
                          it looks really good parker!! keep up the good work!
                          Haauup.....tiptip?
                          • MisterCMKM
                            MisterCMKM
                            Parker;208760 wrote:
                            fixed*
                            'tis true
                            Ford is back :)
                            • MisterCMKM
                              MisterCMKM
                              Parker, one thing to think about would be a hyrdroboost setup for the brakes.
                              Ford is back :)
                              • ParkerP
                                ParkerP
                                uses power steering... i dont have it...
                                • no_slow_clapN
                                  no_slow_clapN
                                  no_slow_clap
                                  that looks sweet parker. nice.
                                  EVOLUTION VIII
                                  ryanherington;4648360 wrote:
                                  I think I'm gonna stop by Autozone and get a "worthy-amount" meter. My car might not put down enough worhty, and I don't wanna get in the way.
                                  • T
                                    T
                                    tqisking
                                    Parker;208752 wrote:
                                    this thing hates life below 1200rpm... i mean if the fan kicks on it falls on its face.... not as streetable as i would like it to be.... .
                                    Not sure if you did this or not....lock the distributor at full advance. This will help greatly with the idle and vacuum.
                                    If you have a problem with it starting you can always put in a start retard or a ignition interuptor(sp)....I have done this to a number of cars and never had a negative side effect.
                                    • ParkerP
                                      ParkerP
                                      actually we were having trouble starting it , the ignition box was set for a 20 degree retard below 800 rpm, i turned that off and she fires up right away and after she warms up a bit idles like it did on they dyno...
                                      • gsrEKG
                                        gsrEKG
                                        gsrEK
                                        nice napa hose son hahahahah
                                        2009 Yamaha Zuma 125, gas HOG
                                        2008 Honda Fit daily
                                        A s2k
                                        1991 Honda civic DX Mint SOLD
                                        1988 Mitsubishi Mighty max
                                        BlackEJ8;233529 wrote:
                                        • ParkerP
                                          ParkerP
                                          looks better than one of those flexible pieces of shit..
