its almost....
tqisking;207856 wrote:
Yea your right.....I do not know anything..I try to help a guy out and this is what you get...
You could have 10 right angles in the fuel system I could really care less, I was just pointing out a potential problem just like the coil but I guess you know it all.....
dude, lighten up. He didn't mean anything as a shot at you.
i really didnt mean anything by it, i was just in a hurry and replied quick to your post... you actually reminded me to turn the coil up right. i didnt mean to come off as a dick... just in a hurry...on a completly side note the car ran tonight, i think i need to ground my ingition box better because after a few starts the led on the box started flashing and it would not fire.... time to do some research
on its feet and moving... caution.. very shitty camera phone video, but you get the point
http://www.youtube.com/watch?v=lWYxQRq6h3I
http://www.youtube.com/watch?v=W_-SSQXjkQs -
this thing hates life below 1200rpm... i mean if the fan kicks on it falls on its face.... not as streetable as i would like it to be.... im having an issue with the brakes, everytime i try to stall the brake peadle goes to the floor and i loose all brakes i let off of the throttle it comes back up, i put a check valve, the work better, but i think i need a vacuum canister, if that dosent help ill just go full manual brakes.... other than that it drives great for having shitty bald tires on snow/ice.
that looks sweet parker. nice.
Parker;208752 wrote:
this thing hates life below 1200rpm... i mean if the fan kicks on it falls on its face.... not as streetable as i would like it to be.... .Not sure if you did this or not....lock the distributor at full advance. This will help greatly with the idle and vacuum.
If you have a problem with it starting you can always put in a start retard or a ignition interuptor(sp)....I have done this to a number of cars and never had a negative side effect.
