its almost....
on its feet and moving... caution.. very shitty camera phone video, but you get the point
http://www.youtube.com/watch?v=lWYxQRq6h3I
http://www.youtube.com/watch?v=W_-SSQXjkQs -
this thing hates life below 1200rpm... i mean if the fan kicks on it falls on its face.... not as streetable as i would like it to be.... im having an issue with the brakes, everytime i try to stall the brake peadle goes to the floor and i loose all brakes i let off of the throttle it comes back up, i put a check valve, the work better, but i think i need a vacuum canister, if that dosent help ill just go full manual brakes.... other than that it drives great for having shitty bald tires on snow/ice.
that looks sweet parker. nice.
Parker;208752 wrote:
this thing hates life below 1200rpm... i mean if the fan kicks on it falls on its face.... not as streetable as i would like it to be.... .Not sure if you did this or not....lock the distributor at full advance. This will help greatly with the idle and vacuum.
If you have a problem with it starting you can always put in a start retard or a ignition interuptor(sp)....I have done this to a number of cars and never had a negative side effect.
