  4. its almost....
its almost....
154 Posts 28 Posters 13.7k Views
  • ParkerP
    ParkerP
    on its feet and moving... caution.. very shitty camera phone video, but you get the point
    http://www.youtube.com/watch?v=lWYxQRq6h3I
    http://www.youtube.com/watch?v=W_-SSQXjkQs
    BlueSRT0483;244555 wrote:
    Trafik Jamz;260984 wrote:
    You are right Parker.
    • ParkerP
      ParkerP
      fuel system hangs a bit low
      • GrrG
        GrrG
        OOOOOOOOOOOOOOOOOOOOOOO, nice. Probably one of the only fast cars around that actually runs and drives at the moment, good job
        • ParkerP
          ParkerP
          this thing hates life below 1200rpm... i mean if the fan kicks on it falls on its face.... not as streetable as i would like it to be.... im having an issue with the brakes, everytime i try to stall the brake peadle goes to the floor and i loose all brakes i let off of the throttle it comes back up, i put a check valve, the work better, but i think i need a vacuum canister, if that dosent help ill just go full manual brakes.... other than that it drives great for having shitty bald tires on snow/ice.
          • MisterCMKM
            MisterCMKM
            slow
            thrash;315544 wrote:
            Ford is back :)
            • ParkerP
              ParkerP
              MisterCMK;208757 wrote:
              my car is slower than yours
              fixed*
              • GrrG
                GrrG
                go full manual, ill never have power brakes again after switching to a properly set up manual system.
                • W
                  W
                  weeman
                  it looks really good parker!! keep up the good work!
                  Haauup.....tiptip?
                  • MisterCMKM
                    MisterCMKM
                    Parker;208760 wrote:
                    fixed*
                    'tis true
                    Ford is back :)
                    • MisterCMKM
                      MisterCMKM
                      Parker, one thing to think about would be a hyrdroboost setup for the brakes.
                      Ford is back :)
                      • ParkerP
                        ParkerP
                        uses power steering... i dont have it...
                        • no_slow_clapN
                          no_slow_clapN
                          no_slow_clap
                          that looks sweet parker. nice.
                          EVOLUTION VIII
                          ryanherington;4648360 wrote:
                          I think I'm gonna stop by Autozone and get a "worthy-amount" meter. My car might not put down enough worhty, and I don't wanna get in the way.
                          • T
                            T
                            tqisking
                            Parker;208752 wrote:
                            this thing hates life below 1200rpm... i mean if the fan kicks on it falls on its face.... not as streetable as i would like it to be.... .
                            Not sure if you did this or not....lock the distributor at full advance. This will help greatly with the idle and vacuum.
                            If you have a problem with it starting you can always put in a start retard or a ignition interuptor(sp)....I have done this to a number of cars and never had a negative side effect.
                            • ParkerP
                              ParkerP
                              actually we were having trouble starting it , the ignition box was set for a 20 degree retard below 800 rpm, i turned that off and she fires up right away and after she warms up a bit idles like it did on they dyno...
                              • gsrEKG
                                gsrEKG
                                gsrEK
                                nice napa hose son hahahahah
                                2009 Yamaha Zuma 125, gas HOG
                                2008 Honda Fit daily
                                A s2k
                                1991 Honda civic DX Mint SOLD
                                1988 Mitsubishi Mighty max
                                BlackEJ8;233529 wrote:
                                • ParkerP
                                  ParkerP
                                  looks better than one of those flexible pieces of shit..
                                  • bubbaB
                                    bubbaB
                                    Nice to see it's up and running...waiting to see this beast go down the track...
                                    • ParkerP
                                      ParkerP
                                      it will make it 2 feet past the christmas tree with the stock rear end 😞
                                      • bubbaB
                                        bubbaB
                                        Haha...thats what I was thinking too...
                                        • ParkerP
                                          ParkerP
                                          welp, looks like its going to have traction issues, (go figure) doing about 40ish and stomped it down, nothing but smoke and a scared shitless driver... im not evebn going to try it from a dead stop, i want to drive it at least a week before i have to replace my rear diff.... and this is before spray :rolleyes:
